Forgive me fellow C&Vers, but I have sinned
#101
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4679 Post(s)
Liked 5,797 Times
Orange is faster, fact.
#102
Liked 5,797 Times
Just realized I have a side by side pic of the forks (old and new) before I swapped them out.
#103
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
#104
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
#105
Liked 5,797 Times
#106
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,095 Times
Yeah next time we ride together I’m prepared for Gugie to have a boom box bolted to that thing.
#107
Quoted: 2338 Post(s)
Liked 2,822 Times
or just bouncing in the milk crate
#108
Liked 2,822 Times
steam punk vibe....maybe more visible brass
#109
Quoted: 3810 Post(s)
Liked 6,690 Times
Likes For nlerner:
#110
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I hear yeh, Guge. i resisted dick brakes for so long but eventually I gave up... and it turns out i really like them. It might be time for a bunch of the baby boomers in this forum to move on to another forum and leave the true vintage bikes to a younger cohort of enthusiasts.
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
#112
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Likes For Charles Wahl:
#115
multimodal commuter
Liked 574 Times
Well, C and S are both sibillants, aren't they?
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
#117
Bikes: Yes
Liked 3,868 Times
I was more concerned about how the brakes work. You know, with drum brakes, the pressure on the drum slows you down. With rim brakes, pressure on the rim. Etc. All I know is I'm not trying them.
My Bikes
My Bikes
Likes For Andy_K:
#118
Keener splendor
Nice work, Gugie. I'm glad you're coming to the dark side, finally. I was worried you'd be caught in a landslide of motobecanes and raleighs in your atelier.
#119
Bikes: Bakers dozen is the limit!
Quoted: 87 Post(s)
Liked 445 Times
Nice set up Mr G! Think a fork like that would work wonders on a couple of my bikes, and I'm sure others out there. Hey if you repainted the entire bike, you could cover up the tigs with filet brass, then not so many people would know of your sin.
#120
Jet Jockey
The Ritchey Breakaway Cross came with a Ritchey Comp Carbon Fiber fork with an AL steerer. I don't know why they replaced such a nice fork with tank. If you want to stick with steel, I'd buy a Soma lugged CX fork. Much nicer.
I have that exact same bike, but mine has a Ritchey WCS Carbon fork with a CF steerer. It is my favorite bike in my stable. Not my favorite travel bike...my favorite bike, period.
Good night...and good luck
#121
Jet Jockey
Oops, I see you already have a fork.
By the way, the key to packing that bike is to pack the handlebars in a separate suitcase. If you do that, it's really easy. The hardest part is getting the handlebars and all the attached hardware in there.
#122
Liked 5,797 Times
At any rate, next Saturday will be the first time on a plane in over a year, and the first time with this bike, so I'll know soon enough!
#123
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Completely non-vintage, but I want to show it off.
ex-Backroads touring ti frame. Fun for me as one of the last projects when I worked for Airborne ti was to build up a batch of 200 bikes for Backroads. When AB went under, the european distributor took the chinese factory contacts and started Van Nichols. This particular bike is an 08 and was sourced via VN, but almost certainly welded in the same factory.
I've built this one up with a 59mm offset fork to create some mid-trail handling characteristics. I hate STIs, but put them on anyways. My plan soon will be to build a 650b rear wheel once I decide on a hub. The bb drop is 65mm and there is clearance for 42c tires, so I'll actually be higher than either of my other 650b conversions. Kinda my dream bike for the past 15yrs.
#124
Quoted: 4511 Post(s)
Liked 6,378 Times
Today's ride, 47 miles with @Andy_K over roads old and new, paved and gravel, flat, climbing, and downhill. In all cases it's superior to the unicrown fork it came with. More flex on bumpy roads so less shock delivered to the upper body, lower trail, which made it easier to keep a line on some switchback downhills, and more stable with a front load. I packed about 4 lbs in each bag, more than I'd carry on a tour, no issues. I like this Ortlieb fork pack system, so easy to take on and off.
I realize I'll need to remove the bags and plastic T-thingies so y'all can see the fork, maybe later.
#125
Liked 5,797 Times
