52/42 or 50/39
View Poll Results: Chainset to use
Miranda 52/42
2
16.67%
Shimano 50/34
10
83.33%
Voters: 12. You may not vote on this poll
52/42 or 50/39
Old 04-06-21, 05:03 AM
willmarksni
willmarksni's Avatar
Bikes: Genesis Core 20, Carrera TDF
52/42 or 50/39
I am fixing up a Carrera TDF 2012 that I picked up for £10 in awful condition (a decent frame & handle bars, with a mangled chainset attached). I don't want to spend much money on it and don't need to win any races, although I might enter a sportive eventually. I've used a bunch of old parts I had lying around (wheels, brakes, new cables, cassette) and bought new bits and pieces (tyres, tubes, brake pads, rear derailleur, head set, front fork, chain).
I need to replace the chainset and the viable options are a Miranda 52/42 and a Shimano 50/34. I'm riding on the Antrim Coast Road which is fairly flat, and am fairly fit, even if I'm a little overweight.
Any advice?
(Save up and buy a new bike is what I expect to be told, but something more specific to the chainset is what I'm hoping for. Thanks guys.)
willmarksni is offline
Old 04-06-21, 05:47 AM
gregf83
Quoted: 1186 Post(s)
Liked 289 Times in 177 Posts
If I was visiting your area with a bike I would use the 50/34 as I see there are some steep climbs (Torr Head) that look interesting. No real advantage to the 52/42.
gregf83 is offline
Likes For gregf83:
Old 04-06-21, 07:37 AM
willmarksni
Perfect. Good point. Thank you!
Old 04-06-21, 08:09 AM
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times in 163 Posts
Depends what gears you're using in the freewheel but I agree that going for the larger size chainrings will not offer any benefit. What size are the crank arms?
Moisture is offline
Old 04-06-21, 09:49 AM
CAT7RDR
Quoted: 822 Post(s)
Liked 1,960 Times in 943 Posts
If your plan is to enter more demanding sportives, a compact crankset will be your friend when you approach climbs later in the ride.
CAT7RDR is offline
Old 04-06-21, 11:15 AM
willmarksni
Crank arms are 170mm. For no reason other than that seems fairly standard/the size I'm replacing. Happy to take advice.
Old 04-06-21, 11:18 AM
willmarksni
Thank you. Most people seem to be voting compact, which is reassuring.
Old 04-06-21, 05:47 PM
Leinster
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times in 207 Posts
Since whatever cassette you end up with will probably have an 11 on it, you're highly unlikely to need a ring bigger than a 50. The only reason to go with the 42/52 would be to remove the outer ring and set it up as a 1x.
Leinster is offline
