Strava power estimates
Quoted: 54 Post(s)
Liked 6 Times
Is there anyone with a power meter that has calibrated it against the strava average power estimates from the app? Just curious how (in)accurate they are.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Consider that Strava doesn't know if you have a headwind or tailwind, if you're in an aero tuck, or sitting bolt upright, if you're wearing a skinsuit or a parachute, if you're in a group or solo, if you're riding gatorskins or corsa speeds, if the road is silky smooth or gravel, etc., etc., etc.
In short, pretty much useless.
Likes For rubiksoval:
Quoted: 54 Post(s)
Liked 6 Times
Yeah I figured that the precision would be lousy but is it also inaccurate? Strava does seem to know what way the wind is blowing though since it lists that on my rides along with the outside temperature.
Bikes: bikes
Liked 1,429 Times
Yes. For all of the same reasons unless you ride with the exact same clothing/equipment on the exact same course in the exact same position every time. And maybe up a long, steady climb. That'd probably be the best for accuracy.
Quoted: 18883 Post(s)
Liked 10,646 Times
How accurate it is defends on a lot of factors and some of them change. How useful it is depends on what you want the numbers for.
In general the guesstimated average power over the course of an entire ride isn't that bad. It's not respected enough for bragging rights at the pub unless your friends use a Strava power meter too. Most people who buy a direct force meter do it to measure their effort during intervals and other workouts. Strava is absolutely not reliable for this purpose. If you want it for calories, it's probably better than what you'd get from HR.
Quoted: 1815 Post(s)
Liked 1,693 Times
The power estimates it gives when I do mountain bike rides are a joke. It takes much more effort to do 15 kph on singletrack than it does to do 25 kph on the road on my road bike
yet my road rides give much higher estimates than my mountain bike rides
Quoted: 2952 Post(s)
Liked 3,106 Times
It's completely meaningless.
Likes For caloso:
Quoted: 20808 Post(s)
Liked 9,450 Times
And you have your bikes set up in Strava as mtb and road, respectively? I don't have a PM on my gravel bike, but once I change the ride info to the gravel bike from my road bike, which is the default, the average typically isn't too far off of what I'd guess based on HR and RPE.
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
Strava power estimates are pretty useless, a joke...I mean like Seinfeld would've shot an entire episode on them if the show was still around.
Quoted: 54 Post(s)
Liked 6 Times
So I have a MTB as well as the road bike and both are in strava as such. part of why I asked the question is that on moderate MTB rides I would get average power estimates about 20% higher than for much more intense road rides. Also for reasons I cannot explain, they are usually 10-20% lower on the road on cold days (40-50 F) than on war ones, even when the effort feels higher.
If they are consistent and repeatable (and have some decent correlation with a real power meter) then I might use it to gauge how my effort was relative to how it felt, but right now I am leaning towards it being not useful even for that purpose.
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
It usually estimates my power really low, so it must be way off.
Kidding aside, the power readings bear no resemblance to reality. They might be spot on every once in a while, but that's the old "stopped clock is right twice a day" effect.
Liked 9,450 Times
But you sound like you want a power meter, so just get a power meter.
Likes For WhyFi:
It would be better if it wasn’t there. I have ridden the same bike with and without a power meter and Strava isn’t even in the ball park. Way low for me (not sure the formula understands what a block a 200cm rider really is 😏. As mentioned many times above, lots of reasons this is the case—Strava isn’t bad, the problem just requires data it doesn’t have.
Liked 3,106 Times
I remembered that a couple of years ago I did an experiment where I was riding into a steady headwind. I ran Strava on my phone so it just estimated power. Then I uploaded the same ride from my Garmin which had power data from my Quarq PM and compared the estimate to the actual power data. It was off by a ton.
https://www.bikeforums.net/19545157-post30.html
Likes For caloso:
Quoted: 54 Post(s)
Liked 6 Times
Caloso, thanks, that's exactly the sort of actual data I was hoping to see. Photobadger, I hope I have the same problem with underestimates, I am ~190cm tall and I can't really be as weak as Strava says (I hope)
Liked 9,450 Times
That said, it seems like you would like a power meter, so go buy a power meter (I'm an enabler ).
Quoted: 54 Post(s)
Liked 6 Times
I think a power meter would be fun, but based on my use of the heart rate monitor (and even my cadence sensor) it just isn't worth the money. Plus I need to get new wheels first anyways as my old ones are getting noodly.
I wonder if there could be a business case for renting out power meters to non-racers like me who want to take a look but not invest. Swapping a crankset in would be pretty easy in many cases, pedal-based meters would be even easier.
Liked 9,450 Times
Quoted: 680 Post(s)
Liked 947 Times
Even when it gets imported power data it is off. the day I managed 203 watts average I exported that from my bike and strava had the ride from my garmin without a power meter. strava showed the usual 120 or so average power but the imported ride with the power meter data showed about the same. the graph showed the power data but the average was only slightly higher then without a power meter.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
With correct overall weight in Strava, while going uphill without any blustery wind.........it's not too bad. Otherwise, can be useless.
It doesn't know local wind. So outbound it may show you doing 300w at 23mph in a nice tailwind then inbound only 100w at 15mph in a headwind.
*grain of salt*
*grain of salt*
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
No value.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Liked 9,450 Times
Liked 10,646 Times
