I broke a brake lever today.
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
I broke a Weinmann slotted lever on my 75 Raleigh International today while stopping. No crashes resulted and I’m okay, that’s the good part. I’ve always liked the look of these levers, so too bad for me. I’ve never thought about this before but if I had, this broke right about where you’d expect it to, at the peak of the curve where one of the slots is. I’d have liked to find another one like it to replace it with, but honestly, with its hollow construction this really looks like it should break. It is a 46 year old part though so that’s got to count for something. Is this a thing with these levers? Has anyone else had this happen?
Quoted: 1372 Post(s)
Liked 1,751 Times
First time that I have seen that happen. I might have an orphan lever, yours if you want it (not sure if I do, though). I can check next time I go to my lake cottage (today, probably as it is time to hook up the water lines).
Likes For randyjawa:
Quoted: 323 Post(s)
Liked 690 Times
If you do happen to find one I’m interested. I’ll certainly cover the shipping costs.
Likes For P!N20:
Quoted: 4512 Post(s)
Liked 6,385 Times
We did, several years ago I got an SC for my kid, full o-haul, same levers, one was bent, I tried to straighten it, snap!
I got a single just like you.
His was gold, well loved, turned out great, went to Leroica in 17 and got a ton of attention at the motel and in the show on Saturday, it was bonkers.
Quoted: 1106 Post(s)
Liked 1,328 Times
Of course it broke(there).
It's old, and badly designed. Removing metal *and* introducing stress-raisers right where the tensile stress is greatest...add time and exposure to the elements...
Have a good look at the other one. If that breaks when you're braking you could cut the inner part of your finger to the bone. I'd install a pair of un-slotted Weinmanns myself.
Likes For oneclick:
Liked 1,751 Times
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
While riding, I have broken two cranks, three rear axles, a pedal cage, three frames, a front hub flange, and a few spokes and cables, but never a brake lever, and fortunately never a chain. Over the years I have had unslotted Weinmann levers otherwise like yours on several of my road bikes.
Quoted: 3811 Post(s)
Liked 6,707 Times
Wow! If we ever meet in person, please go easy when shaking my hand.
Likes For nlerner:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
At least it was the right brake that broke.
Disraeli Gears
I have a soft spot for those Weinmann "waffle iron" pattern levers (with or without the "quick-release" feature) myself, but I only have the plain ones.
Likes For Charles Wahl:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I bought a Super Course last year with the exact same lever breakage, so I'm in the same boat right now!
Quoted: 323 Post(s)
Liked 690 Times
Liked 1,328 Times
They (and their clones) can be improved - widen the pivot ears and take a wedge off the very top of the lever where it meets the body (you may have to move the lip of the body in with a little percussive persuasion). The first makes it feel tighter & crisper, and the second gives you a bit more travel.
Quoted: 323 Post(s)
Liked 690 Times
I wonder if there’s ever been a bike built with the “death fork”, the “death stem”, and the ”death brake lever”?
Likes For Pcampeau:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Throw in a Helicomatic to raise your chances a bit more...
Commence to jigglin’ huh?!?!
Quoted: 1641 Post(s)
Liked 831 Times
Back then, not too many really cared or even understood the problem with introducing stress risers when designing components. Even if you bring it up, they might say, anecdotal evidence shows that their parts had been working on bikes without problems for many years, so what's the point. This lever had lasted like 40 years without breaking, which would most likely had been given the "gudenuf" rating from its maker and sellers......
Us C&Vers should always consider the limitations of the old stuff we install and use on our bikes and not be too surprised when we see such failures on components designed in a different, long past era.
Quoted: 4806 Post(s)
Liked 3,929 Times
Perspective - all aluminum breaks if it is indeed used long enough. You can overbuild it to last longer than a lifetime but it will still break. And that failure will probably be during use. By contrast, non-exotic steels last a very long time if routine stresses are kept below a level known as the fatigue limit.
I try to replace aluminum parts when I feel they have served their lifetime. I see retired aluminum parts as preferable to ones that died on the job. 46 years -a good credit to Weinmann but really good design (IMO) is one where a non-critical element fails first and makes replacement necessary.
Likes For 79pmooney:
Disraeli Gears
I had a crank arm snap on my commuter, and took a painful fall. Luckily just bruises and nothing serious. The Japanese crankset was almost 40 years old at the time.
When I showed the broken arm to my mechanical engineer colleague, he recommended replacing the other non-broken arm too, since it would likely fail as well.
I was skeptical, thinking they came out of different molds, what are the odds of both sides having same failure? So I ignored the sage advice, and after cursory inspection, only replaced the broken NDS.
Sure enough, a few months later the other drive side arm broke in almost same location. Lucky to get away with minor scrapes and bruises...
Point being, I would check that other remaining brake lever very closely.
Liked 1,296 Times
