Weak cantilever brakes
Bikes: Giant Escape 1
Quoted: 136 Post(s)
I ride a cross bike (Norcross Blue) as a road bike. This bike has cantilever brakes and they are quite weak. I've heard this is normal for cantilevers. I really have to squeeze very hard to come to a stop at the bottom of a hill, for example. I also ride a hybrid with linear pull brakes and they are much better. I like having good reliable brakes so I need to either find a way to make the cantilevers better or replace them. What do you suggest?
https://sheldonbrown.com/canti-trad.html
The Geometry of Cantilever Brakes
Also, Swiss Stop or Kool Stop pads.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Yeah, might be your brake pads. I've played around with Avid Shorty 4's and they seem to give as good a stopping power as the caliper brakes on my other road bikes.
Quoted: 18378 Post(s)
Liked 4,512 Times
In another thread (and more or less what Sheldon Brown states)
A long Yoke cable ==> hard to pull.
A short Yoke cable ==> easy to pull.
So, try a bit of adjustment.
Quoted: 1581 Post(s)
Liked 1,189 Times
Quoted: 175 Post(s)
Step 1: fiddle with the adjustment
Step 2: buy better pads
Step 3: fiddle with the adjustment again
Step 4: replace them with mini-v brakes. Either TRP CX 8.4 or the much cheaper Tektro 926.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
[h=1]First I'd try new pads. I like Kool Stop Mountain pads, black and salmon. They work fine on road bike rims. Properly adjusted they will probably make a big difference.[/h]
In my experience......
This:
Then this:
Then this:
Seriously though, the can work well but can also be a pia to set up properly.
Then this:
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
Definitely adjust the yoke and thereby the angle the crossover sits relative to the lever. Pads obviously.
I'd also have a look at your cables and casings. Sloppy, poorly cut or poorly seated housings will yield squishy brakes. Have a look at thise, as well.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Though I hate setting up canti brakes. Mini V-brakes, or classic V-brakes is what I always go for. Just make sure they work with the levers, or get the appropriate levers. On an old MTB I got 2nd hand V-brake levers and brakes - didn't want to mess with the cantis, no way!
Quoted: 136 Post(s)
Thanks for all the advice. I guess this gives me a winter project. I will look at the pads and possibly replace those. I will shorten the yoke. And if that fails, I will replace with a different kind of brake.
Liked 1,189 Times
The CX8.4s are identical in materials/construction, save for slightly shorter arms.
