Review - Shimano Biopace Crankset
Quoted: 515 Post(s)
Liked 87 Times
Figured I'd give one of these oval chainring setups a try. Its a shame that these never quite picked up on the market.
While the smaller chainring is more subtle, its effect becomes particularly noticeable when you shift to the larger chainring. It feels weird at first, but your body quickly adapts and learns how to make the most out of the change and crank rotation.
When pedaling on regular circular chainrings, you might find that the top half of the pedal stroke puts you into a more effective position to crank out some extra power versus going from the bottom half back up to the top. As such, the cranks actually move faster down than they do back up.
as such, the chainrings increase in diameter at the top half of the stroke, and then decrease at the bottom half. The end result is that power delivery is noticeable smoothed out - it is now one, smooth continuous movement, taking full advantage of the powerful part of the pedal stroke and "conserving" this energy in order to speed up the crank revolution through the less efficient area of the pedalling stroke.
While it is rather subtle in the smaller chainring like I said, in the larger one I feel noticeably more efficient and definetly a little bit faster. The sensation is almost as if the cranks are pedaling themselves when you are rolling on smooth pavement. Its a very natural feeling that's gentle on your knees and apparently helps to increase the blood flow in your legs. Im definetely quite happy with these compared to my original Sugino circular crankset.
Oval rings are an age old idea. There must be a reason they keep failing in the marketplace, get reintroduced as new and improved and fail again. Failure is not bad in this case, it simply demonstrates market demand was not enough to sustain the idea. Biopace came on two of my mountain bikes back in the 80's and after experiencing knee issues with them, they were replaced with round rings, which leads me to believe each user reacts to them differently, which goes to demonstrate that no one thing is the right thing for all users. Glad you like them!
Quoted: 515 Post(s)
Liked 87 Times
I think that was mainly due to how they were marketed.
Perhaps the crank arms were not the right size according to your inseam. I've heard lots of different people stating how easy they are on the knees.
I understand that its not for everyone though. Maybe you just pedal at a higher or lower cadence than what these oval rings are designed for? I find that they work best at a specific cadence. Could be why.
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 1112 Post(s)
Liked 836 Times
My 1984 Nishiki International Ole's large front cog is oval (I replace the smaller one with a smaller circular one for our Colorado hills). I never think about it until threads like this. Perhaps it is not oval enough, but I can't feel any difference between it and my other round-cogged bikes.
Quoted: 732 Post(s)
Liked 420 Times
Shimano's marketing department (I'm guessing here about the origin of their approach, but it was someone pretty smart), having noticed that the vast majority of riders buying racing-style bikes in the early '80s were sport riders, asked Shimano's engineers to come up with an improved design for non-racing riders, who tend to use lower cadences than racers. Thus, the egg-shaped oval chain rings with two focus points.
They failed in the marketplace for one primary reason: Shimano proceeded to spec BioPace rings throughout their component groups, and while the sport riders were generally happy with them, racers hated them for their lumpy feel at high cadences. Guys writing for bike magazines heard their racer friends complaining and damned the rings to the depths (having praised them to the skies when they were first introduced).
Quoted: 553 Post(s)
Liked 355 Times
Biopace and modern oval chainrings are not the same thing. Biopace had the clocking of the "oval" wrong and made the gearing lower in the strongest portion of the pedal stroke and higher in the weakest part of the stroke. This put more stress on your legs and joints at the point where they were least prepared to deal with that stress. https://absoluteblack.cc/home/menu-1...20rings%20work.
Likes For dsaul:
Quoted: 515 Post(s)
Liked 87 Times
The design of earlier iterations of oval rings was based on the assumptions that racers would benefit from increasing the gear ratio in the section of the pedaling circle used for applying power and decreasing the ratio in the other sections and that the sky's the limit for the eccentricity of the chain ring.
At any rate, i think a racer can also benefit from this tech..
The chain rings defientrly increase in diameter at the stronger part of the pedal stroke, not the other way around.
Bikes: 1984 Schwinn Supersport, 1988 Trek 400t, 1977 Trek TX900, 1983 Bianchi Champione del Mondo, 1986 Trek 400 Elance, 1978 Raleigh Supercourse, 1991 PDG Paramount OS, 1971 Schwinn Sports Tourer, 1985 Trek 670
Quoted: 332 Post(s)
Liked 280 Times
I seem to keep getting bikes with those things, I give them to the co op.
Tim
Tim
Quoted: 553 Post(s)
Liked 355 Times
I dont understand the purpose of spinning in such a high cadence though. It simply means you are not in the right gear, and that you're spending more energy going slower... or perhaps the bike isn't geared right for your needs. Or perhaps the crank arms are too small for your legs.
From looking at my crankset, (I have two biopace sets)
Then someone has clocked them differently than they were intended. In your pic above, the small ring has been clocked one bolt hole off as evidenced by the small tab that should be aligned with the crank arm.
You don't understand a lot of things, but you go on giving advice as if you do. What cadence do you think is efficient? My most efficient cadence is between 93-105rpm for road riding
Quoted: 207 Post(s)
Liked 294 Times
Had a bike with them once, decades ago. Don't know if it was biopace or some other oval, but found I prefer regular round chainrings. The ovals just felt too much "off and on" (for lack of a better description) to me. Gave the bike to my brother-in-law, who doesn't ride a lot, but still takes it out occasionally.
Likes For Mulberry20:
Likes For mack_turtle:
Sunshine
Quoted: 4852 Post(s)
Liked 2,079 Times
Disco Infiltrator
Quoted: 2230 Post(s)
Liked 889 Times
Are we still putting hot air in this guy’s balloon? His cover was blown a month ago
Genesis 49:16-17
Genesis 49:16-17
Quoted: 732 Post(s)
Liked 420 Times
Someone opined in an earlier post that Shimano got the clocking completely wrong. It's true that BioPace is inappropriate for racers and others maintaining cadences of 90 rpm and above (which is what Rotor Rings, etc., are designed for) but not for casual riders and many sport riders, who tend to go for lower cadences of 60 to 80 rpm or thereabouts. Those are the riders who can benefit from BioPace rings, and there are a lot of those riders out there.
The bike I ride the most has Biopace chainrings, just to make it more odd and irritate bike snobs.
Likes For Podagrower:
Bikes: are fun to ride
Quoted: 29 Post(s)
Liked 23 Times
My first mountain bike and bike that I bought with my own money was a 1990 Giant Sedona that was shod with Biopace chainrings. I replaced them within a year for round rings. The pedaling was just weird. Fast forward to 2009-ish and I took a gamble on oval Rotor rings on my Salsa. Way better and smoother power delivery. Shimano could have developed Biopace a little more. I now have two other bikes with oval chainrings - Wolftooth and Absolute Black and they're both great.
Cyclochondriac
Quoted: 247 Post(s)
Liked 165 Times
The effect is 'more subtle' in the smaller chainring because you've mounted the smaller chainring wrong. See that little nub on the inside perimeter of the small ring at around 5:30? That nub should go under your crank arm.
Likes For icemilkcoffee:
Quoted: 247 Post(s)
Liked 165 Times
Of course, Biopace is useless for pro riders who have perfected their circular strokes and never overstomp 6 o'clock. That would be 0.005% of the riding population. The rest of us definitely benefit from the genius of Bio-pace.
Quoted: 515 Post(s)
Liked 87 Times
optimal cadence is dependent on a number of factors. I think past 105RPM means you're in too low of a gear, as it becomes more difficult to efficiently trasnfer power past this stage.
A lot of people misunderstand the reason behind the Biopace design. Intuitively you would think you want higher gearing where your leg is strongest (around 3 o'clock), and lower gearing where your leg is weak (12 and 6). If you are seated and grinding at a very low cadence, this is true. However, if you are either standing, or spinning, what ends up happening is that you will typically 'overstomp' 6 o'clock. Meaning you continue to stomp downwards even at or past 6 o'clock. When you are spinning very fast, like going downhill, sometimes you can feel your butt bouncing off the seat with every stroke. This is because you are overstomping 6 o'clock. That wasted energy goes to lifting our butt off the seat. Same with standing and pedaling. A lot of times you have to consciously tell your feet to 'lift up' at 6 because the tendency is to stomp the pedal into the ground. Biopace was designed to counteract this tendency by increasing the resistance when you get close to 6 o'clock.
I would imagine that some types of more serious competition cycling could also benefit from this design.
I had one way back when it first came out. I rode for 3 years with medium fast groups and lots of miles 6,000 a year. It didn't slow me down or anything negative but I don't think it helped in any way either. It was just something different that I was trying. The only thing I remember is that it never felt good to spin and I didn't spin much anyway. After 3 years the experiment was over and gone. I would never recommend that anyone get an oval chainring, it does nothing.
Sunshine
Liked 2,079 Times
Likes For mstateglfr:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 1,959 Times
That doesn't seem to be deterring anyone from posting here, though.
