Light setup for 7-8 hours of night riding
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
Trying to sort out light options for 7-8 hours of night riding.
I have a cateye volt with extra battery. I can run that at 300 lumens for about 7 hours.
I have lezyne super drive 1500XXL. that will cover the 7-8 hours at 250 lumen.
I also have a anker flashlight mounted to my helmet. That’s less important since it’s just there for that little bit of light I need if I’m turning my head to look or turn.
This is a gravel night ride in a forest so no streetlights. And long ride so not going fast so not like I’ll outrun my lights.
does 300 lumens seem enough? Other options? I don’t want to go the dynahub route.
Quoted: 151 Post(s)
Liked 42 Times
I could also do something like Lezyne MEGA DRIVE 1800I with their infinite power pack
mosquito rancher
Magicshine makes one model (Alty 2000) with a removable battery pack. They used to sell a model with a removable "raw" 18650 cell, so you didn't need to buy a proprietary product from them. As far as I know, this is the only self-contained light with a swappable battery pack. There are a lot of bikes with separate battery packs where you could obviously swap packs. There are some lights that can operate while hooked up to an external USB battery pack, but this isn't well-documented. Not all do.
300 lumen doesn't sound like enough to me, but in any case, lumen is a rough stand-in for the more relevant metric, which is how far your light throws its beam, and whether you'll outrun that at your typical speed. Some beams are more diffuse, some more focused. I'm guessing that for riding through a forest, you'd want a little more diffusion than on the road.
Adam Rice
Adam Rice
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Peter White has a few pages outlining what his lights do, patterns, etc. here. There was another guide I used when I was looking for a battery model, but I was concerned about commuting use rather than trail.
For 7-8 hours of power, it's hard to beat a dynamo, especially for more than occasional use.
Likes For Unca_Sam:
Palmer
Quoted: 1672 Post(s)
Liked 1,832 Times
I have a Fenix BC21R which uses common, easily replaceable (like a typical flashlight battery replacement) 18650 batteries. With a charged one in the housing and a spare Panasonic 3400mah battery packed along, I can pretty much 400 lumen all night long and bounce to 1000 on the downhills - plenty for me.
Someone else need more lumens/lux/candlepower? Shucks, Panasonic 3400mah 18650s are under $8 each. Pack along several and turn the wick up.
Quoted: 151 Post(s)
Liked 42 Times
Yeah. I don’t think 300 would be ideal. The cateye volt I have is a volt 700. I could carry 2 extra batteries and I could run at max 700 lumens and that would get me to 6 hours. And I could lower the mode as i got close to dawn. That could work. Maybe. Or I could carry lezyne 1500xxl. Run that at 1000 lumens until it dies. ~2.5 hours unless I switch to 600 lumens when it starts running low. Then switch to cateye volt 700 running at max and have the extra battery.
Quoted: 151 Post(s)
Liked 42 Times
Quoted: 3465 Post(s)
Liked 1,470 Times
I bought one of these on Ebay, shipped from China. When I bought it, cost was about $5 or $6. But that was pre-Covid, now shipping is very slow and costs higher.
No internal battery, I plug it into a USB powerbank. On low power it draws 240 milliamps, 1.2 amps on high power.
Small powerbanks do not provide enough power. When you plug it in, it is off, push the button once and it is on high power but if your powerbank will not supply enough power, it goes off without the ability to set if for low power (the second push does that). So, the smallest powerbanks do not work
I have no clue how many lumens, but I have plenty of light for bike trails on low power setting. Flashlight type of beam, round beam. Not a low and wide beam like the better bike lights for road riding. That may be an advantage if you are going up and down on a rough trail, but the narrow beam might not work that well if you have to do very much negotiating over rough spots.
I bought it for bike touring, I almost never have a headlamp turned on for that. But there are tunnels, and evenings to the pub that might require a headlight. And I carry a power bank in my handlebar bag when touring.
Should I assume from your screen name that this is in Florida, thus flatter than a billiards table? And that it is on a fairly straight gravel trail? In that case, a wider flatter beam would be better than a flashlight beam. Is this part of a brevet or something like that?
You said forest, in that case a beam that is up higher like a flashlight beam may have some benefit, as in forests sometimes you have branches hanging down. And if your beam is low and flat, it might not light up a tree branch that you are about to ride into.
Quoted: 151 Post(s)
Liked 42 Times
I ended up ordered the LEZYNE Multi Drive 1000 Headlight. It was a decent price on competitive cyclist. And I ordered an extra battery. I can run it at max 1000 lumens for 6 hours with that setup but likely will be able to toggle to the 500 lumens setting when I’m riding in a group.
Quoted: 630 Post(s)
Liked 369 Times
You want this:
https://www.amazon.com/Micro-USB-rec.../dp/B07WFDRPW8
With at least two of these:
https://www.18650batterystore.com/products/samsung-50e
Here's a good review:
https://budgetlightforum.com/node/68190
Quoted: 151 Post(s)
Liked 42 Times
You want this:
thanks. That’s an interesting option. I had also looked at the fenix bc30 which takes two 18650 batteries but hadn’t seen many reviews of it.
Quoted: 4560 Post(s)
Liked 2,803 Times
I'm pretty satisfied with the NiteRider Lumina Dual 1800. The wide beam really helps, from the dual LEDs and lens to shape the beam. Even at the 350 lumen minimum setting it's very good. Pretty comparable to a motorcycle headlight. I run video most rides and when I review video later I realize my bike headlight is as good as the vehicle headlights alongside me.
(There's a 100 lumen steady mode but they suggest that only as a walking light, not for riding -- although I've used it on that setting on slow rides on the MUP at night.)
Not cheap at $150 or so, but after more than six months of regular use on long nighttime rides, I have no serious complaints.
I wish the mount was a little quicker to attach/detach. The quick release between the light and mount is fine. But the thumbscrew lock for the mount, and choosing shims to suit the handlebar diameter, makes it a chore to switch between bikes.
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
I agree that more than 300 lumens would be a much better choice, but I would definitely add a helmet mounted light as well. I use it for my commuting night rides. I love that I can point the light anywhere I need it. If you see an imperfection in the gravel path, you can shine it there to figure out how to negotiate that possible obstacle.
Quoted: 980 Post(s)
Liked 776 Times
Quoted: 7354 Post(s)
Liked 2,488 Times
I agree with the dynamo advice, as I've been using dynamos for a few years. You don't notice how much trouble goes into charging a headlight until you stop. Then you realize it's like banging your head against a wall. Taillights are easier to deal with since a bright taillight can run daily on a single charge for weeks.
However, dynamo lights aren't very bright. This isn't a problem for me. I seem to do OK with low intensity lights. I'm not sure what my lights put out but 300 lumens is my guess. I can ride comfortably at 12 or 15 mph at that speed. Whether this is good enough for you is something only you can say. Some people are not satisfied unless they have 1,000 lumens, and that sounds crazy to me, but to each their own. However I will point out that if your beam is not "shaped," then you need more lumens. And that is to say if it is shaped, you need fewer lumens. I like shaped beams of the German type. There is a sharp cutoff at the far edge of the beam, and most of the light goes to the far edge. I do not light up the trees or the road's shoulder, and the light does not shine in the eyes of pedestrians or motorists or cyclists. This is how I get away with a low-lumen light. I do not have exceptional night vision.
If you do want a high intensity light, you could get a super-high intensity light, say 2,000 lumens, and run it at half power so the battery lasts long.
Another solution is to use an external battery, and that requires a light that can run off an external source.
Liked 1,470 Times
And if I was negotiating difficult terrain on gravel where at times I was slower than jogging speed, then a helmet mounted light could come in handy, as the dyno powered headlights will dim at very slow speed.
On a gravel trail, you are not going to have headlights from cars and will not be in street light areas, those things dull your night vision. So, you should have good night vision, except where you might have to cross highways with cars that have bright headlights.
I have used both of the lights I cited above on gravel rail trails, but there was very little up and down, so the light beam stayed where I wanted it. For those I did not need a helmet mounted light, but I did have to watch for any broken branches hanging down from trees. That said, I had a headlamp in my handlebar bag that I could use if I had a mechanical on my bike.
People even do the Tour Divide race with dyno powered lighting, so that is certainly possible, but I am not sure which lights they use.
That said, I would never suggest someone spend the kind of money you would need for a good dyno powered lighting setup for a one night ride that lasts several hours.
My IQ-XS provides the type of beam below, this is from the B&M website for the IQ-XS.
Likes For Tourist in MSN:
Quoted: 151 Post(s)
Liked 42 Times
my current plan is to run the lezyne multri drive 1000 runs off a battery pack. It can run 1000 lumens for 3 hours. I won’t need it max all the time. It will run 500 lumens for 5:30 hours. And I will carry an extra battery pack. Helmet I will either have my cateye volt 700 or a flashlight. I don’t need a lot of light there. I’m not using these for mountain biking or any crazy fast descents. Sure if frequently did very long night rides I’d consider the dynamo hub option.
Quoted: 151 Post(s)
Liked 42 Times
For those interested. I ran the lezyne multidrive for my race and it worked great. If I was alone I bumped it up to 1000 lumens if needed. In a group I toggled it to 500 lumens. One battery pack lasted me the entire time so either I was, at times, toggling down below 500 or the lezyne lowered its output automatically when the battery was low. I can’t find in the documentation where it’s states it will do that.
regardless. It worked well for me. One of my friends had some bad luck and a rock damaged the cable for his light so he was stuck with a helmet light only.
Likes For biketampa:
The Fenix BC30 V2.0 is a self-contained light that uses a pair of 18650 cells.
Quoted: 426 Post(s)
Liked 274 Times
I like the wide light (mine is more of spot light ) mounted under the computer. How much and where did you get this light ?
Jedi Master
Surprised nobody mentioned the B&M battery powered headlights. It's what I use on my bikes that don't have dynamo lights.
Liked 2,488 Times
The Ixon Space provides 150 Lux! I might buy one next time I need a battery light. An important point for these lights is that I believe these lights can run while being charged. Not every light can.
