70's (?) Velosolex Etoile - restoration
My Workshop = Happy Place
Bikes: Schwinns, and many others.
Quoted: 42 Post(s)
Liked 224 Times
I have owned this bike longer than any of my current 20+ restorations. It has sat in the back of my basement, unloved, for years.
Purchased through a friend from an upstate CT bike shop in 1990, it was even then a homologation of N.O.S parts I was told. I put many miles on it back then with those dangerous shoes which had a slot to grip the pedals. (No quick release!)
In 1999 I bought a new Specialized and so it has sat for 24 years.
I finally decided it was TIME. Everything was disassembled cleaned regreased, adjusted and reassembled. I took it for a 2 mile ride and it works as it looks. I will ride it gain when the roads clear here in snowy CT.
The ONLY thing I purchased was new 25c tubular tires for safety, and replaced the lever rubber covers. All else original. Much patina still intact.
Sorry for the amount of pics and if they are TOO BIG. I love the process of capturing it clearly as well. My professional self won't let that go. (These are how I add them onto my Professional Gallery Website.)
As I saved it. VERY neglected. Tires = JUNK.
Now... there is very little online about Velosolex Etoile bicycles. I forum a post HERE ON BIKE FORUMS which has a curious owner asking the same.
Funnily he states his serial number is '62147F'. MINE is '62147EL' on rear dropout. Thoughts?
Thanks for viewing and any info you may have. otherwise it's simply a display post! I do this work to keep me sane. You understand.
Coop
Coop
Likes For SharpByCoop:
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Looks lovely!
Quoted: 3814 Post(s)
Liked 3,345 Times
WOW, what a fabulous job!
Thanks so much for sharing it.
frame-
lugs: BOCAMA Super-Profesional (offered both with & without cutouts)
crown: Vagner DP+
shell: Raccords Gargatte Freres
ends: Huret Ref. 230 & 231 rear, 234 & 235 front
[1974 catalogue page]
readers will notice that dropout in catalogue illustration lacks the "blister" at the rear edge of the dropouts on the frame. this was added ca. 1973-1974 to give extra wall thickness to hole for adjuster screw but does not appear in catalogue as manufacturer reused an earlier illustration for catalogue of 1974.
serial -
'62147F'
'62147EL'
could not help but notice that when one reverses the last to numerals one gets the single most likely year of manufacture
possible that the "621" may be a model number
the letters could indicate either a form of serial or the identity of the framebuilder... [wylde speculation! ]
fittings -
interesting to note that all of the bits are of first quality save for the Normandy Sport hubs & Lightrace (Gourgaud) headset
the odd appearing saddle pillar is a seldom encountered Huret item which is shown in the catalogue page posted above
the only real temporally inappropriate fitting is the topmount shifters which did not come in before 1982
tried without success to read marking on pedal endcap. if it reads "SPIDEL" or "Lyotard" they are model 65 which is rare, valuable & top-of-the-line BITD
thank you again for posting this wonderful project!
frame-
crown: Vagner DP+
serial -
'62147F'
'62147EL'
fittings -
Likes For juvela:
Quoted: 42 Post(s)
Liked 224 Times
juvela WOW! So appreciative of your time spent sleuthing this for me.
VERY informative and impressively accurate!
1. BCM lugs, Vagner crown, RGF shell, Huret ends; ALL exactly as noted. You know your sources!
2. Blister checks out in deference to the diagram. Whodathuunk.
3. Identical Serial number HAS to be a model identifier instead? Letters are mystery. (If someone else reading this now or in future, please educate us.)
4. Don't know anything about the hubs or headset. I recall at the time it was sold to me at a BARGAIN. Not surprising it would use more economy parts.
5. That seat post is exactly the one shown in the Huret catalog with the two bars as an upper clamp.
6. Topmount shifters probably added from newer stock even if the frame was built earlier. Like I was told, the shop used up NOS to get this done. Ditto on hubs and rims.
7. No, these original pedals are dependable and common MKS. Another non-costly item added to finish the build.
Because this is sentimental to me, THIS is one I will ride a bit and keep in better condition. First time removing and installing tubulars. (Thank goodness for Youtube!)
I appreciate you. Big thanks!
Coop
Coop
Quoted: 42 Post(s)
Liked 224 Times
Here are some in-process shots of the corrosion I had on rims, and the sanding and steel wool on spokes it took to restore.
I used strips of red 3M cloth vertically on the rims and then used a paste polish afterwards. Then a sealer.
You may laugh, yet I have had LOTS of success sealing up raw aluminum parts with a simple clear floor polish. it goes on quick and gives it a durable coating.
I have used it in my position in the marine/rowing world as maintenance for years, on old carbon fiber and fiberglass to seal them up quickly, and some metals.
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1226 Post(s)
Liked 3,554 Times
Lovely bike. I'd just like to know how you did your pictures so neatly in your post.
There were 135 Confentes, but only one...Huffente!
Quoted: 42 Post(s)
Liked 224 Times
AdventureManCO and others: In regards to photography, I posted a display tutorial in the GENERAL forum.
Inexpensive Studio Photography Setup
(I did so on your prompting, so info would not get buried in an obscure post, OR limited to Vintage Bikes.)
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
Nice bike! We don't get enough non-Peugeot/Motobecane/Gitane French bikes here. Was this the same company that made the motorized bicycles?
Quoted: 42 Post(s)
Liked 224 Times
Bicycles were probably an add-on because of their name status. Didn't happen.
Liked 3,345 Times
this is something have long wondered about...
as to whether or not the company produced their own pedal cycles
Likes For juvela:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
Looks like lots of hard work and a beautiful result! Congratulations!
FWIW, IMO it deserves gum-wall tires when those new black-walls wear out. More congratulations for sticking with sew-ups!
Thanks for the polish and photo tips, too.
Quoted: 42 Post(s)
Liked 224 Times
Fredo76 Thank you so much! I am pleased you looked carefully.
Here's the deal for my choice on the BLACK sew ups. it CAME with gumwalls.
But.... every time I see an aged set of gumwalls the lighter (gumwall) looks miserable. They don't age as well.
I KNOW I will not ride these to wear out. So I chose them to endure a lifetime of LOOKING good.
YMMV! Thank you.
Coop
YMMV! Thank you.
Coop
I owned a Velosolex Etoile, acquired waaaaay back in the summer of '72 or '73 from a bike shop in Oceanside Long Island where I was working as a mechanic. The shop was only around a few years, jumping on to and crashing with the bike and bust. Velosolex was positioning itself as an alternative to Peugeot, which was the hot bike of the moment. My shop didn't carry this model (too expensive) but I ordered it from the distributor. These pictures bring back a ton of memories. The original derailleurs were the Simplex Super LJ Gold, front and rear, with the magic retro-friction downtube shifters. The gold finish matched the Mafac breaks and levers. The seat post was the Satri Galet fluted and the crank was the Nervar. Frame was standard 531 db. I still have the fork from this bike though it's currently mounted to an old Carlton frame. I'm not even sure when I moved on from this bike but I think I sold it sometime in the late 70's in Seattle.
[QUOTE=juvela;23132927]-----
I donl't think so. As a student in 80s I collected Velosolex (or Solex as we used to call them) motorised bicycles. They were made under licence in what then was a former Yugoslavia in 50s/60s. I had bought, repaired and repainted and sold on quite a few of these, using one or two as parts donors and buying some parts like engine block seals etc from a dealer up in Austria.
Never ever I've seen a bicycle made by Velosolex, nor did the owner of the dealership. I'd say third party build these and they just re-stickered them. Mistral was one of their models in 70s I believe.
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
GREAT bike. Thanks for posting it.
Quoted: 42 Post(s)
Liked 224 Times
Good stories and info. Thank you.
I DID take it for a 15 mile ride and it ran as promised.
It will go in my rotation this Summer.
Coop
Coop
One last note - I don't recall every component on the bike but I do remember that it was 100% French components - Ideale saddle (that I never had the patience to break in) and i'm pretty sure the hubs were Maillard.
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 65 Post(s)
Liked 305 Times
Beautiful.
I came upon a rough looking Velosolex bicycle at a swap meet in '21. I have two of the smelly motorized tur...er...bikes and thought it would fit right in. Alas, the seller thought it was gold and I walked away. I wasn't looking for another bike, just Sturmey Archer parts.
My 1977 4600, built for the US market, along with my two knuclehead grandsons on their E-ATVs.
Likes For bikamper:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 300 Times
As to the OP bike, what a lovely hunk of eye candy. So many unique touches.
