Newbie rider... was given an'87 Cannondale SR500. I want to restore it. Need advice
Bikes: '87 Cannondale SR500
Howdy all. I'm a new road bike enthusiast brought on by a knee injury that forced me to give up high impact activities. With 4 kids and a single income, I was happy when a friend gave me his '87 SR500 Cannondale. It rides good for all I know. Had it out on 4 15-20 mile rides and I liked it. I did take it in to my LBS in which I got a couple new wheels, break pads, chain, and a tune-up for $150. I am very handy and want to restore/learn to fix this bike myself and save $$$. I've read a lot of the threads here and gleaned lots of good resources on DYI.
What I am specifically wondering about are parts. For example, I need to replace the hoods, cable stays, and want to find the matching (turquoise, this was an '87!) paint.
All of my riding friends have nice, new (expensive) bikes so I think it would be nice to ride up in my beautifully restored vintage Cannondale.
I would appreciate any help/advice in this area.
Kim
Kim
Still learning
Is it the Hojo's color scheme turquoise with orange decals, like mine below? If so, then it is a Shimano 105 group. You can get 105 aero hoods and plastic cable guides on ebay. The cable guides are otherwise unobtainium, although some wag here is using a 3D printer to make them.
Paint match would have to be done by an automotive paint supplier. Check with your local body shop. There are lots of examples of cannon dales in this forum and some have been fully powder coated with new decals. That would set you back at least $150.
Quoted: 659 Post(s)
Liked 595 Times
Welcome! You've come to the right place. You picked a sweet bike that will fit in just fine with newer bikes and can be upgraded accordingly.
Quoted: 24 Post(s)
Liked 5 Times
well if money is tight, i think your capital would be better spent if you just set it aside to buy a new bike down the road.
its going to cost $150+ for a repaint/decals and other parts. for $300-500 total you have a lot of high quality vintage steel options out there.
the SR500 is a nice bike but at the end of the day it's an aluminum frame- which imho makes it more a rider than a collectible. spend money to keep it rideable, dont put money into it for aesthetic/fashion reasons. now if money wasnt a concern, then yes rehab/refurbish it all you want....
Bikes: '86 Cannondale SR400, '86 Pugeot PX10, '92 Bianchi Axis, '95 Bianchi Campione d'Italia, '00 Fondriest X-Status, '08 Specialized Roubaix, '13 Cannondale CAADX
I'd vote you delay spending to improve the bike's looks. Focus on function and building experience first. Those miles will help you set priorities and discover what you like and don't like. Check out books and online sources for maintenance and mechanical advice if you want to wrench on it, and don't forget that the right tools help.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
The original white hoods are unobtainium (OOP). You can find them on ebay, but they tend to go high. A cheaper option is to just pick up a set of generic aerolevers with hoods. I have bought a lot of sets from a seller on ebay for $8 a pair or less, shipped.
I'd delay some on the paint, as to do it right, it tends to be spendy. The original cable guides are also unobtainium. I tend to harvest them off a donor Cannondale frame I keep around. I bought a set from the 3D printer guy, he sent me a key chain instead…..
Focus on the key mechanicals instead (sounds like you are well on your way already in that regard).
Quoted: 24 Post(s)
Liked 5 Times
@zazenzach why torch the OP's enthusiasm? His questions were specific, not an aluminum vs. steel debate. Does it make you feel better to dis a Cannondale? Yes, most prefer lugged steel bikes in the C&V forum, but there are many Cannondale enthusiasts as well.
point is though, OP has stated money is tight for him. in light of that fact, you need to prioritize things. OP would be much better served by saving up for a higher quality and more pristine steel bike down the road.
id be saying the same thing if this was a mid-range steel frame too. repaints are costly and time consumming and on tight budgets, often not worth it.
Casually Deliberate
Kim
Kim
As for matching the paint, I second the suggestion to look at a body shop. If you just have a few scratches or scuffs you want to prevent from getting worse in the meantime, check out some of the different nail polish lines especially Essie and OPI. We had a dark blue bike in the shop that needed some very minor spots covered up and it turned out I had some polish that was nearly a perfect match.
Quoted: 17 Post(s)
Liked 42 Times
These old Cannondales are stellar riders, Kclymon. The power X-fer is about 100% pedal to the macadam, and they can climb vertical walls with no effort on the part of the rider whatsoever. Well, that could be a SLIGHT exaggeration, but with the '87, you have the best of BOTH worlds with a steel fork and no real harshness that people typically associate with aluminum.
My only concern is your wheel set - The bike came with pretty decent wheels - (See spec below) - but if a bike store provides and tune-up AND a new wheelset for $150, it is unlikely that the wheels are especially good - and good wheels ARE important. Do you still have the original Wolbers perchance?
- Auchen
- Auchen
Wow, thanks everybody! All had great points of view and advice. A lot I need to consider... Sure, I'd love to purchase a new bike- saving some money, slowly, while I feel out the sport and the road on my vintage Cannondale. In the mean time, I like the suggestion of making sure the mechanical parts are working and not look to restore quite yet. I think I will try to match the paint so I can at least do a DYI job on the front fork. I will need new hoods though as the original ones are like sticky playdoh. Yuck!
Thanks again- Kim in SoCal
Auchen,
I misspoke. I didn't get new rims/wheels(?), I'm still learning all the correct terms. I got new tires. But, I just looked at the wheels and all I can find stamped on them is ARAYA 700c JAPAN. Those aren't the originals I suppose. Have you heard of that brand?
And you're right, I have never done any serious kind of riding before (besides joyriding with the kids on some random bike) and I was amazed immediately at how it rode up hills. I felt like I could almost go vertical and it would not be a problem...okay, slight exaggeration. Kim
Oddjob2, it's all turquoise with white decals, seat, tape & hoods- No orange.
I think I may go to a black seat, tape & hoods until I make the decision to restore it. I have a feeling white may be hard to keep clean.
Quoted: 17 Post(s)
Liked 42 Times
Auchen,
"Immediately" up the hills?
Yes indeed! I have an '87 SR-400 (same frame) but that was my epiphany regarding C'dale as well. I was really impressed by it.
- Auchen
- Auchen
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
Kim,
You can buy brand new black replacement hoods for your gooey melted ones. Around 10.00.
You have a very nice and sporting vintage bike as your first ride. It'll have no trouble keeping up with your friends' newer bikes. If they have new carbon fiber bikes, there's realistically about 3 lbs difference. Improve your fitness first, then look into improving the bike.
Quoted: 791 Post(s)
Liked 1,775 Times
This is a truely great American made classic of a bike that with a little work and a few components can be rehabed into great bike.
Well worth spending a couple of hundred on or more with a nice wheelset the ride and performance rivals many modern bikes with a $1000+ price tag.
Quoted: 659 Post(s)
Liked 595 Times
SR's rock. And they are getting increasingly difficult to find. There is a reason for this. There is a premium attached to them. I have found it frustrating finding and obtaining them in my area. This is why I bought a frame (a Criterium Series) thanx too our own Bobotech.
If you want a classy ride that others will look at and reminisce, this will turn heads. Later on you can upgrade but really, this bike will fit in and keep up with modern riders if you do your part.
Kim, Best advice I can give is to ride it as is to determine what you'd want to change in the future. Concentrate on how well the bicycle fits you. Bicycles are like shoes, a good fit is very pleasurable, while a bad fit is torture.
Brad
Brad
Quoted: 472 Post(s)
Liked 1,028 Times
And meanwhile put many miles under the BB and get the fit right. I've studied bike fit (gobs of info out there, not all consistent) and applied that to my bike a little at a time. I've returned from many rides to make a minor adjustment (seat height, bar angle, lever position, saddle position, etc) then go ride another 30 miles seeing how that works. Over time I've dialed it in and am very comfortable and convinced it's the right bike. Once you'v'e done that THEN you can spend the money getting it painted. If, by chance you find that the frame is the wrong size or just does not suit (or truthfully, you hate road riding), you can move it on and have saved the money.
As to 'all those other guys on their new carbon frames' I'm also convinced that many (most???) people want to buy their way into speed and flash. Many are not willing to take the time and endure the pain to get fit, loose weight, get their seat, hammer their legs, stretch their backs out, work out their neck muscles and lean on their hands until their body is used to this stuff. So they drop $$$$$$ on gear and kit and flash so they look the part. Its easier to buy gear 3 pounds lighter than loose 3 pounds behind their belts. As folks have said, be proud of your great C'dale and go get fit and dial in the bike. If those guys have adverse opinions about your ride then they are just not busy enough. Go ride your way and enjoy.
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Kim, I believe I have a set of the same 105 levers with black hoods that are in fair to good shape. As a C&V welcome to our mostly friendly and supportive forum, I'd like to offer them to you for free and zero obligation. It's great to have a newbie join us with such enthusiasm and excitement about riding.
I haven't noticed anyone suggest posting pictures yet. Seeing your bike, specific parts, paint problem areas, etc., will help us to best guide you on the most cost effective way to achieve your ascetic and mechanical goals. This group has a deep and wide knowledge base. We can trouble shoot and help you solve pretty much any challenge on your C-Dale.
Welcome to C&V and email me pastorbobnlnh@gmail.com about the 105 levers and hoods.
Bob
Bob
Thanks! I will try to get a picture up this afternoon.
And I feel better about my 'old' bike compared with my friends new ones after reading your posts. I DO like the Cannondale- I like that I saved it from the landfill. I like that I am not blowing a bunch of money on something new (not necessarily better).
I am just gonna ride, improve my fitness and learn what the road and my bike wants to teach me.
~Kim
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Congrats and welcome. Check for posts by rccardr for inspirational Cannondale builds. The early SR and ST Cannondales are desirable, collectible and worthy of any restoration, upgrade or modification.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
IIRC, weren't the Cannondales back then painted in Imron paint?
My Brother's Black Lighning looked nice, but he always complained the the paint chipped easily on it....
