SRAM Cassettes
Bikes: Canyon Endurace
Quoted: 1042 Post(s)
Liked 933 Times
SRAM Cassettes
I usually default to Shimano but since my 9-speed format is starting to age a bit I find the selection of my favorite Shimano 9-speed cassettes starting to thin out a little. Yes, I can find new higher end Shimano 9-speed cassettes but when the cost of a SRAM 950 comes in under $30 it gets my attention. I have no reason to believe there is anything wrong with SRAM cassettes, I was just reaching out for opinions. I am thinking that since I use SRAM chains that there might be a slight compatibility advantage(?)
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I've had a number of Sram groupsets and have used both Sram and Shimano cassettes with no noticeable preference to either.
Likes For GlennR:
Quoted: 1464 Post(s)
Liked 1,489 Times
I've also never noticed any difference between Shimano and SRAM cassettes, and use them interchangeably. Same with chains.
Given the current challenge with finding parts, I'd encourage you to buy whatever you can get your hands on. These things are getting harder to find across the board right now.
Quoted: 1103 Post(s)
Liked 1,045 Times
I've had equal luck with both brands and buy the one that has the gear range I want for my bike in the weight and price range I like. Never really noticed a shifting difference.
Clark W. Griswold
Quoted: 4434 Post(s)
Liked 4,083 Times
I have been using the SRAM PG-990 for years with no issues and have used other SRAM cassettes on Shimano stuff just fine.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 259 Post(s)
Liked 379 Times
I'll echo what others have said. I wanted an 11-28 cassette for my Shomano Ultegra drivetrain but my LBS couldn't find a Shimano, so I'm now riding with a SRAM cassette on an otherwise Shimano drivetrain and it works fine.
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,539 Times
Sram, Shimano, Sunrace..... I can never tell a difference in performance.
I don't know if this applies to the 9-speed cassettes as well but I find with the 11-speed versions that Shimano tend to space the gears more evenly. SRAM seem to go for smaller jumps at the higher gear (small cogs) end, gradually increasing the gaps. Whether you prefer that or not is obviously down to personal preference but I've gradually come to appreciate the logic. I have a compact chainset and I find that if I stay on the smaller chainring then, at the speed that I typically ride at, it's easier to find a gear that I want. In the old days I tended to get on to the big chainring and stay there until I needed to change down so at first I found the SRAM cassette annoying. Now I've got used to it I'm quite happy.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,649 Times
I have used a number of SRAM cassettes and can't tell the difference between them and any others.
Timely thread for me, as I was looking for an 11 speed 11-36 cassette. I have a Shimano group set, but to the best of my knowledge, they don't have an 11-36. SRAM does, but I was wondering about compatibility.
On Your Left
Liked 2,434 Times
i currently have an 11-40 cassette on this bike, using a long cage RT-R8000 derailleur. Also using a road
Link to extend the derailleur further out. I’ve had trouble with bending the whole contraption from just pedaling. Then I can’t access the 40 tooth. It’s happened several times even after hanger, road link and derailleur are replaced. Maybe if I take the road link out, it would help
Sunshine
Quoted: 11034 Post(s)
Liked 7,584 Times
