Old Guys and Descending
#51
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,985 Times
I really admire the down hill decent speeds here. I know I can't/won't attempt them. Just be sure you understand the risks.. carry on.
https://www.verywellhealth.com/how-d...-older-2223520
You break your hip, you get pneumonia, then you die. lol
I think that study skirts confusing causation with correlation. As it notes, people with health issues are more likely to fall and break a hip, and also more likely to die of that same health related issue. My guess is that people in our demographic are a bit different.
But yea ... slowing down is a good idea. It's not the pain or even the expense that stops me ... it is the possibility of never being the same.
Likes For Biker395:
#52
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Low-speed accidents can be deadly as well. A friend died three years ago when his front wheel caught in a storm drain, on level ground at the end of his regular ride. Snapped his neck.
#53
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
I try to keep speeds to be able to panic brake within the distance I can see around the curves. It's very easy to take corners at a speed that would be a disaster if the road ahead was blocked or full of debris. One of the local riders mentioned the automobile signs for curves -- A sign for a "25 mph" corner is about the speed I can go and see far enough ahead. I could probably go 35+ around that same corner if the pavement was good, but it's too fast to stop.
I'll go full speed on long, straight downhills without driveways and with trimmed back shoulders. That's up to the low 40mph range.
I've practiced very hard braking with just the front brake, so I can stop pretty well. (I once fishtailed when I grabbed both brakes hard. The rear wheel locked up. Letting off both brakes kept me from crashing.)
Likes For rm -rf:
#54
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times
While I've cycled most of my life, I didn't consider myself a serious recreational cyclist until I was around 56 years old (will be 66 next month). I've never been very aggressive on descents. Reached the low 40's several times but, for me, it's more terrifying than exhilarating. So, since I've never been super aggressive anyway, I don't think I've gotten any more cautious on the descents I do ride. It's even possible I've gotten a small bit more aggressive (or maybe it's confident from repetition) since I've gotten more serious about cycling.
#55
Quoted: 626 Post(s)
Liked 701 Times
Funny to see this thread pop up now. I recently move to the North SLC area, where there are some really fun hills. Back when I rode DF bikes (uprights), my fastest descent was ~56 mph. It was a long straight hill with a lot of runout, so I could push as hard and fast as I wanted until gravity took over.
I switched to recumbents in 2011 when I was living in Seattle. There was one hill, a little over a half mile long, that was 12-15% grade, and I would hit 64 mph at the bottom as I was leaning into the left hand sweep before hitting a nearly identical uphill climb (took me three tries to get up before I didn't have to get off and walk!).
I recently got a velomobile, and managed 65.6 mph going down a relatively short, steep hill here. I think if I get the more aerodynamic race cap, and close off the footholes, it would be good for 70 on that hill.
I ride (and race) motorcycles, so the speed itself doesn't bother me much. I've seen over 160 mph indicated on my motorcycle many times on the track.
Likes For Notso_fastLane:
#56
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,985 Times
https://www.youtube.com/watch?v=q7IWYp2eLrc
#57
Quoted: 8279 Post(s)
Liked 9,033 Times
Sam Whittingham had the top speed record for a human powered fully faired recumbent for years. His record was about 83 mph, unassisted. He also said he had the record for the fastest crash. IIRC he wasn't badly hurt.
#58
Quoted: 626 Post(s)
Liked 701 Times
They broke that record this year. Just shy of 90 mph at 89.7! That's hauling! And on level ground. I'm bombing down a hill to get anything over about 30.
#59
Liked 9,033 Times
#60
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
But by all means, everyone should be as cautious as they need to be. No shame in that!
#61
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Gulp, that's crazy fast! If you want to come south a little bit, Squaw Peak Road off of Provo Canyon is a fun descent. So also is the Alpine Loop. But be careful, they are narrow and winding and there are a lot of really stupid drivers around...
Likes For Clipped_in:
#62
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
I did a good bit of descending yesterday in the NC mountains on some fairly steep stuff...and the roads were wet......I was so happy to have my new disc brakes!!!!
Ride your Ride!!
Ride your Ride!!
#63
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
Sometimes a guy just needs a bigger gear. This part of the descent is the fastest and steepest straight which is one-third of a mile at seven percent. I am in 50 on the front and 11 in the rear.
#64
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I don't think I've been over 50 mph on my bike since I started riding again, mostly because I can't ride up the hills that would enable those kind of descents. But I'm getting stronger, albeit more slowly than I would like. As a racer, the only limit was air resistance. In the Northeast speeds could get high, with steep hills, good, straight lines or sweeping bends, and good roads.
Even so, as fast as we went, I always felt more comfortable going really fast on skis. No blow-outs, critters, other riders, or loose rocks that weren't there "yesterday" to contend with.* Being able to take a run or two to get a feel for the current conditions and new bumps, before letting loose makes a big difference to the relative risk. That's still true now, though I'm not on pre-prepared, closed trails. Skiing is the only 50+ I've done without a motor since BITD, and that's fine. It takes many months to heal what took a few weeks when younger. I hated my last long down-time, and that was in '05!
* Independent suspension also makes a big difference. (Anyone here remember Franz Klammer's Olympic gold DH run?)
#65
Quoted: 1020 Post(s)
Liked 463 Times
Dying is not my worry, once you are dead you are dead and that’s pretty much the end, physically speaking at least.
My concern is about sustaining a major injury that would negatively impact the years remaining in my life.
I am more cautious descending now that when I was younger...I still like bombing it downhill though; that’s one of the truly fantastic feelings when riding.
My three Colnagos are very sure footed in fast descents. The Bottecchia is a bit twitchy. So I “choose” my descent speed depending on which bike I am riding that day.
Likes For eja_ bottecchia:
#66
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
For me, the risk/reward ratio of a fast descent is simply too high. My road bikes have top gears around 95 to 96 gear-inches, which means I spin out (120 rpm) just below 35mph. I am much more interested in how fast I can climb than in how fast I can descend, and I often drag or pump the rear brake gently to check speed on a long descent.
Likes For John E:
#67
Going fast on a straight is no big deal. I did my fastest ever at 53 mph, at age 66 this year. I take the corners slower because I have slid out from sand in the corners and it hurts. I've got permanent road rash scars to show for it. I have knee replacements and don't want to damage them. I've passed cars on the descent from 14,000 foot mount evans.
#68
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
#69
It's a 28 mile ride from Idaho Springs to the top of Mt Evans. I've done it six times, but the last was when I was 53. My best time was 2:35. Look up Bob Cook memorial hill climb. There's a race every year.
Likes For DaveSSS:
#70
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
According to my GPS I did 51.4 MPH today.
Strava mathematicians decided that it was really 53.2 MPH.
Either way, it was my second fastest recorded speed ever.
I'm 55.
-Tim-
I'm 55.
-Tim-
Likes For TimothyH:
#71
Bikes: Specialized Roubaix Exp ert Road and Specialized Stump Jumper FS Mountain; De Vinci Caribou touring, Intense Tracer T275c, Cramerotti, Specialized Allez, Condor
Quoted: 166 Post(s)
Liked 99 Times
I think I go down hill fast but then I ride with my 30 something sons and realize - I don’t anymore! I still get down pretty quick on mountain bike trails, but roads, not so much.
#72
At 77 I can't get up to the same speeds I used to hit. I regularly get over 40 on group rides and used to hit over 60 mph on the "Markleyville Death Ride". 40 seems pretty tame after 60+. My eyes were pretty big at 60 for several minutes. It makes it a lot easier to compete on Strava on downhills as the comfort zone is pretty high. Also to develop skills in hitting apexes you have to ride pretty fast.
#73
I have a pet theory that after a couple of close calls of this nature, squirrels get addicted to the adrenaline rush of the near miss and seek it out. Makes 'em extra squrrely.
#74
My fastest ever was 98kmh (60mph) at age 62. Five years later can't imagine how I did that. Won't be surprised if 50mph never happens again. Glad I went for it last time my nerves and reflexes were up to it. Just didn't feel like a big deal at the time.
Yes, the pros get scared. Federico Bahamontes won the '59 TdF and was King of Mountains 6 times. Also KoM in Giro and Vuelta. Known as the Eagle of Toledo. He was terrified of descents. Was known to drag his foot on the pavement (if there was pavement) in downhill hairpins. He is the notorious one but lots of pros ride scared. Fearless descenders like Lemond or Hinault are exceptions. Riding down at the limit rarely makes any difference at the finish, no reason for a pro to take chances.
The new generation of tires seriously do have more grip. Wider tires the pros are using have more grip. This has not made descents faster. Hopefully more grip has made everyone safer. Larger part of safety is backing off before it is too late.
#75
Quoted: 195 Post(s)
Liked 207 Times
[QUOTE=deacon mark;21015177]So I naturally get more interesting viewing cycling with the TDF going on and leads me to a question. I like most of the group here I believe find those crazy descending speeds they go are unbelievable. So I ask this question to us over 50 are you much more cautious than you were years ago and how much slower would we be taking those long descends.
When racing it's all out and I never noticed how fast I was going. Now I'm a lot older the idea of waking up in the hospital has less appeal than it did once. (40 mph).
