Wearing tyres in?
Wearing tyres in?
Old 03-22-20, 12:29 PM
venomx
Quoted: 64 Post(s)
Liked 7 Times in 5 Posts
Wearing tyres in?
Got my hybrid bike last week and on the back tyre the tread has worn away slightly in the middle all the way round, is this normal?
venomx is offline
Old 03-22-20, 12:45 PM
02Giant
Quoted: 1638 Post(s)
Liked 741 Times in 495 Posts
Completely. There is more weight on the rear, it will show wear prior to the front. Some replace the front when the rear is worn out, placing the old front on the rear, as having a better steering tire is preferred.
nine mile skid on a ten mile ride
02Giant is offline
Old 03-22-20, 04:14 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
Is this a new bike that shows tire wear in one week? That would not be normal.
JanMM is offline
Likes For JanMM:
Old 03-22-20, 05:08 PM
tFUnK
Quoted: 430 Post(s)
Liked 460 Times in 318 Posts
Well, that depends on how much have you been riding, how much you weigh, and what kind of tires they are.
tFUnK is offline
Old 03-22-20, 05:35 PM
freeranger
freeranger's Avatar
Quoted: 427 Post(s)
Liked 699 Times in 436 Posts
You may be relying too much on your rear brake. On pavement, the front brake is more effective at slowing you down. Now, grabbing a handful of front brake on a road with gravel or sand on it isn't such a great idea. Learn to use both in conjunction with each other, but rely less on the rear brake. Also--how high are you running the tire pressure. Try running them 5-10 lbs. less than the max stated on the side of the tire. The max is just that-the max you'd want to run them, and you most likely don't need the max. You'll get a feel for the brakes and what tire pressure works bests for you as you become more familiar with the bike.
freeranger is offline
Old 03-23-20, 12:51 AM
venomx
Quoted: 64 Post(s)
Max psi is 118 and I've got them to about 100psi
I am heavy and weigh 95kg
The tread is fully still there on the outsides just not the very middle of the tyre
Here is the tyre
venomx is offline
Old 03-23-20, 01:25 AM
headasunder
Quoted: 75 Post(s)
Liked 19 Times in 14 Posts
using the rear brake will have a negligible effect on rear tyre wear unless you are locking up the back wheel post a pic of your front tyre a lot of tyres have very little tread pattern on the top of the tyre to begin with. As mentioned the rear bears the brunt of your weight + is also the driven wheel so wears a lot faster.
headasunder is offline
Old 03-23-20, 01:34 AM
venomx
Quoted: 64 Post(s)
Here is the front tyre
venomx is offline
Old 03-23-20, 02:45 AM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 533 Post(s)
Liked 312 Times in 236 Posts
In the middle of the tire there is a mold release line that is not intended to function as tread and usually wears of extremely fast. That tire is designed to essentially to be slick, and the slight siping on the sides probably does nothing at all either. Don't worry about it. When worn the tire will appear squared off in the center.
cpach is offline
Likes For cpach:
Old 03-23-20, 02:47 AM
venomx
Quoted: 64 Post(s)
Nice one thanks
venomx is offline
Old 03-23-20, 02:56 AM
alo
Quoted: 529 Post(s)
Liked 255 Times in 185 Posts
The tires don't have tread in the middle.
Sorry, somebody else posted while I was typing.
alo is offline
Old 03-23-20, 03:23 PM
rmacdona
Bikes: 1987 Cannondale ST600, 1988 Fisher Mt. Tam, 1989 Cannondale SR800, 1998 Cannondale T500
Liked 8 Times in 6 Posts
+1 Use the mold release line as reference.
rmacdona is offline
Old 03-24-20, 08:49 AM
leob1
Quoted: 292 Post(s)
Liked 106 Times in 69 Posts
the only thing not normal is calling tires tyres.
leob1 is offline
Old 03-24-20, 09:26 AM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 582 Times in 399 Posts
OP is in GB.
sweeks is offline
Likes For sweeks:
Old 03-24-20, 04:43 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
the only thing not normal is calling tires tyres. 😀
Fixed that for you. 😀
JanMM is offline
Likes For JanMM:
Old 03-24-20, 05:07 PM
San Rensho
Quoted: 383 Post(s)
Liked 133 Times in 91 Posts
Here is the tyre
Thats not worn. You can still see the seam in the middle of the tire. Yes that will go away fairly quickly, but you have a couple of hundred miles before the seam is even worn. What to look for on rear tires is if its "squared off". The tire is no longer a semicircle, but completely flat in the middle.
Oops, I guess I should read previous posts before I respond.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
Last edited by San Rensho; 03-24-20 at 05:11 PM. Reason: redundunce, misspelling intentional
San Rensho is offline
