Addiction LXXVIII
#7176
VFL For Life
Bikes: Velo Volmobile
Quoted: 28605 Post(s)
Liked 1,856 Times
It could have been you.
#7177
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
It is so quiet here this morning its kinda creeping me out a little.
#7178
Quoted: 10236 Post(s)
Liked 5,183 Times
Smallest chain ring and smallest cog and my chain is resting against the chain stay. Is something off?
#7179
Should Be More Popular
Quoted: 22594 Post(s)
Liked 8,925 Times
#7180
Liked 8,925 Times
#7181
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Effectively cross-chained. Have you tried riding it in that configuration? Often it doesn't work. There's no reason, as you can get that ratio elsewhere. As I recall, the rule for chain length is big ring/big cog and add a link. Somebody please correct me if I'm wrong.
#7182
Mostly Harmless
Bikes: Have two wheels
Quoted: 13711 Post(s)
Liked 4,525 Times
#7183
Liked 8,925 Times
#7185
Mostly Harmless
Liked 4,525 Times
#7186
Liked 5,183 Times
Are you saying I’m riding cross chained in that configuration? I would have thought that with only two chain rings, the smallest chain ring and smallest cog would be fine, nor does it look like it’s causing the chain to be at any angle vs largest chain ring and largest cog.
#7187
smelling the roses
Liked 901 Times
#7188
Mostly Harmless
Liked 4,525 Times
Modern drivetrains tolerate cross-chaining pretty well. It looks like R7000 on @bampilot06's bike.
#7189
So it is
Quoted: 11400 Post(s)
Liked 4,748 Times
The chain is too long for that gear choice, and it's by design. Little/little gear ratio can be has with the big chain ring and a more suitable cassette cog, as seedsbelize said. In this case, the cross chain isn't angle, it's the physical capabilities of the bike.
#7190
Mostly Harmless
Liked 4,525 Times
#7191
Mostly Harmless
Liked 4,525 Times
Likes For rjones28:
#7192
So it is
Liked 4,748 Times
#7193
Liked 5,183 Times
I’m not good at quoting everybody. But thank you for clearing that up. My CAAD was the old three chain rings and I typically rode the middle chain ring, when I switched to this I just assumed it was similar and didn’t think anything of it. I was concerned because in that picture the chain looks to long, but if I go big and big it looked appropriate and I didn’t think I could take any more links out. Appreciate the help.
#7194
VFL For Life
Liked 1,856 Times
#7195
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Had my best/ longest run since banging up my heel a while ago. Felt awesome.
In other news, a local race company seems to be intending to run an actual live & in-person sprint/Oly in mid-July.
Likes For Bah Humbug:
#7196
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#7197
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#7198
Liked 5,183 Times
I recall you saying that you were getting some chainslap previously, and I mentioned that it was probably too much chain - this certainly looks like too much chain. Well, either that or the RD doesn't have a cage long enough to take up the slack of the gearing range, but I wouldn't think that Cervelo/Competitive would make that kind of mistake. Do the Shimano sizing that rjones mentions - big/big +2.
https://www.youtube.com/watch?v=LC8_ndnXJUY
#7199
Liked 9,456 Times
In general, I like to avoid the small chainring - front shifting has gotten really good, but it's still no comparison to what a rear derailleur can do. Being down at sea level and with very little elevation nearby, I'd probably never use the little chainring unless I was pedaling in to hurricane headwinds.
#7200
Liked 5,183 Times
I honestly thought it would be worse for the rear derailer if I was large chain ring and on the 4 5 6 cog. Atleast that was my logic.
