Too big and strong for the frame. Suggestions?
No, I’m not. It’s Mr. Spadoni the Youngest, who is 6’ 3” and tips the scales at something north of 200. He calls me today, after he had ridden to work. His question today was about the frequency of seat tube / bb separations. Seems he had just suffered his second one in a little over a year.
While he has ridden vintage bikes in the past, these failures have come on a lower end fixed gear bike that he has written for the last two years. The switch to fixed came after he realized that he did not have the temperament to fiddle with shifters and cleaning chains. With the fixed, if he had air in the tires, he would get to work on time.
The bike came from a local shop, and they have stood behind everything that he has broken, in addition to the frames. But clearly he needs to upgrade before the shop has had enough and clamps him into a work stand or something else to maintain their profits.
so here’s the question: do I try to find another frame and we build up something solid? Or does he just buy something new? Likely it would still be fixed, as he likes the feel of the ride. In either case, it will be parked on the street so it can’t be too high end, and he does need fenders. I am kind of inclined to the first option but need help in keeping things simple because I an not the one that will do most repairs.
any suggestions.
any suggestions.
Quoted: 211 Post(s)
Liked 199 Times
I would look for and buy a Schwinn Varsity or Continental from the 70s
Virtually unbreakable !!!!!!!!
These are 10 speeds but he can keep it in one gear.
5th gear is a great all around gear.
Good Luck !!!
Good Luck !!!
Likes For bikemike73:
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
This has Cannondale written all over it. Tall guy, big guy.
I’d find any Cannondale frame he takes a liking to, the ST Tourers that I like came in big size jumps. I use a 23, I’d suggest a 25 for your son, if he likes the SR Sports frames, they’re more varied, I think (but not sure) they were sized in 2cm increments.
They have vertical drop outs, which is good, because no wheel slip, and is bad, because chain tension. You can find eccentric hubs, and more expensive, eccentric bottom brackets. That will get your the chain tensioning adjustability you need.
I have a couple Cannonballs, love how they don’t flex. After they were welded the whole frame was heat treated as a piece, a true monocoque frame build. The strongest frames were made between ‘85 and about ‘91/92, way overbuilt.
Likes For Chr0m0ly:
Schwinn Varsity? I'm not entirely kidding. There's always some big manimal dude in every cycling scene. I remember one of those dudes BITD who used to show up to the racer training rides, on a Schwinn Varsity. This was a big muscular guy, and I guess the few extra pounds of iron didn't make much difference. He actually kept up pretty well in a paceline on the flats and rollers. Of course once the real hills started he got dropped instantly. Still we all thought it was pretty impressive. Anyhow, them Varsities is tough, which I think is how the guy rationalized it.
There were other big dudes, ie track sprinter types, that just rode normal race bikes. Maybe they had SP instead of SL. Some had custom bikes, which is the optimum, but probably overkill for a commute bike. Another solution is a more modern OS steel frame. I'm not a small person myself, though I'm south of 200, and to me OS is the greatest thing since slice bread. I'm currently riding 725 OS Mercian mostly. Looks traditional with lugs and brazing, but it sure feels a lot more solid to ride. How important is keeping it C&V? For less money, some kind of modern TIG'ed gravel bike or something might serve the same purpose, and a number of these are nominally sort of retro styled.
A lot of what breaks bikes is poor technique. Maybe Mr. Spadoni the younger can learn to spin more? I guess there isn't really much to be done with a fixie though.
I see that I was beaten to the punch with the Varsity recommendation, so make that a +1. Continentals too.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
You make it sound like he's a grownup who knows what he wants. Just go a little less low end this time
Genesis 49:16-17
Genesis 49:16-17
Quoted: 800 Post(s)
Liked 753 Times
I think a 90s hybrid with horizontal dropouts (I'm just guessing there are some out there...maybe not?) or an old MTB/ATB bike with horizontal dropouts would work fine. Just make sure to avoid the mountain bikes with u-brakes on the chainstay, usually models from 1986-1988. If he's that strong and heavy he might be better off with the smaller and stronger 26" wheels.
Quoted: 838 Post(s)
Liked 1,082 Times
My thought is that he’s just got low end bikes. I can’t imagine any vintage steel bike in decent condition having a single issue with someone just over 200 pounds. Find any frame that fits him and throw a nice fixed gear wheelset on there.
Likes For polymorphself:
Quoted: 634 Post(s)
Liked 444 Times
Low end fixed gear = low end high tensile steel frame. Your options are to convert an old vintage higher end road bike or beefy frame (old Schwinn as mentioned above) or get him something like a Surly Steamroller or Soma Rush frame and build it up. When you say parked on the street do you mean he stores it outside overnight or just when he's at work?
Likes For tricky:
Quoted: 634 Post(s)
Liked 444 Times
The Drive Side is Within
Any pics?
I’m that height and 215, though I don’t ride FG. Never had a problem.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Quoted: 1944 Post(s)
Liked 2,164 Times
I did have a chuckle about learning proper technique as to not break a frame peddling. I have never heard that before.
John
Quoted: 800 Post(s)
Liked 753 Times
Quoted: 634 Post(s)
Liked 444 Times
Cheap option: move his fixed gear parts over to a vintage frame or keep breaking the same cheap fixie and having the shop replace it.
More expensive option: Soma or Surly frame but take off or tape over the decals
All that said, frames can still break, especially under big strong folks, but he would get more life out of a quality frame.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Not true. I had a Kool Lemon Continental in 25" many decades ago and sold it to a friend's kid brother. Guy was a stick, but the seat tube broke clean through just above the bottom bracket shell.
Quoted: 2363 Post(s)
Liked 1,749 Times
Um, the chain on a fixed gear doesn't need cleaning? Who knew?
And why can't he ride a single-speed?
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
U-brakes are ok in general, but could be inconvenient using single speed or fixed gear if you want to change the ring/cog tooth total, since the rear axle shifting will move the rim w.r.t. brake pads, potentially beyond the range of adjustment and inconvenient to have to shift the pads anyway.
Otto
Otto
Likes For ofajen:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Subjecting an old low-end bike to the rigors of fixed gear pedaling and "braking" via a big, tall, strong guy is certainly a recipe for destruction. My vote is also go higher up the food chain. Or make it a single speed with a free wheel and employ brake calipers. That should make the stresses of the frame drop considerably as it will be ridden in a much more traditional manner.
The old Cannondale SR or ST frames sound good to me. They're welded, super beefy, and have fragile paint which is a great theft deterrent as he can find one that's a bit rough and not have to worry about it. Or he can get a welded steel frame with thick tubing as weight doesn't matter here.
Could he try and be kinder/gentler/smoother in his riding?
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Mid 90's Giant Iguana. Put smooth tires on it. Beefiest fork ever and very sturdy. Also has all the attached fittings necessary for fenders, racks, etc.
Cannondales? The early aluminum tin cans?
Likes For USAZorro:
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 335 Times
My choices
All steel
GT mountain bike frames
Trek Lugged Mountain Bike and Hybrid frames
Mid 90's Nishiki mountain bike frames.
Early 90's steel hybrid frames from just about everyone
Likes For mechanicmatt:
Quoted: 1627 Post(s)
Liked 630 Times
Old Cannondale, all day, every day. Or a Surly Long Haul Trucker if you want to spend five times as much and have a much heavier bike
If I'm gonna need a chain tensioner though, I may as well have a rear derailleur, same price as a tensioner (Maybe less). You can build to up as a five speed and let him decide whether or not he actually wants to shift it. He doesn't have to.
Why a fixed and not a single? Got me there. That’s his choice
Quoted: 246 Post(s)
Liked 335 Times
Oh I forgot!
Redline Monocog. That's what he needs.
Thanks for all the feedback.
Thinking right now
Single speed with freewheel for less frame stress.
Cannondale could be an option as even a complete bike is cheaper here in PDX than the Surly frame. But as aluminum, rear spacing is Not adjustable.
Varsity is bombproof but man Varsities are going for way more than I would expect, even during a bike boom.
lets see what Young Spadoni says to all of this......
Thinking right now
