Buying a Crankset-Based Power Meter These Days
Old 09-27-20, 01:50 PM
Metallifan33
Metallifan33's Avatar
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times in 48 Posts
So, for various reasons, I'm in the market for a crankset-based, dual-sided, PM (Shimano compatible). I've looked for
  1. Pioneer - They shut down their op and sold to Shimano earlier this year apparently. ("out of stock. Discontinued")
  2. 4iiii - Every option is "out of stock"
  3. Stages - You guessed it; "out of stock"
  4. Shimano - I've heard there are some issues (from GP Llama specifically).
At this point, I'm thinking I'm just going to have to wait it out, but I thought I'd check here and see if you guys have any ideas.
I'm looking for dual power and Shimano compatible. The bike is a 2020 Domane (with the newer style BB).
Thanks!
Metallifan33 is offline
Old 09-27-20, 01:57 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22572 Post(s)
Liked 8,918 Times in 4,152 Posts
Several of my friends LOVE their Power2Max crank-based PM.
I am suspecting that the global pandemic is affecting supply chains and making it tough to find much of anything.
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 09-27-20, 02:07 PM
Metallifan33
Quoted: 218 Post(s)
Thanks datlas ! I'll check 'em out.
Old 09-27-20, 02:13 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
I have a pile (ok, trio) of Quarq DZeros and DFour91s that have been flawless, and apparently available in DUB format through Competitive Cyclist at least. You'd need the spider and arms, and make sure to get a compatible bottom bracket if you go that way, but it's my first choice in PMs.
Bah Humbug is offline
Old 09-27-20, 05:07 PM
Princess_Allez
Quoted: 173 Post(s)
Liked 57 Times in 40 Posts
Have you tried Powermetercity.com ? I just bought a Stages gen3 R7k 105 a week ago.
Princess_Allez is offline
Likes For Princess_Allez:
Old 09-27-20, 05:15 PM
WhyFi
WhyFi's Avatar
Quoted: 20808 Post(s)
Liked 9,450 Times in 4,668 Posts
Power2Max or Quarq. You don't really need dual-sided so much as you want full power (as opposed to the double of one side). P2M (and Quarq, I assume) can give you quasi-dual-sided (it costs a little extra coin for P2M) but I don't see much value in it.
WhyFi is offline
Likes For WhyFi:
Old 09-27-20, 06:00 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
I'll third Power2max. Not from personal experience, I went with pedals for reasons that don't apply to you. But I did my homework and P2M was a better choice in several ways that probably do apply to you.
And @WhyFi is right about total power being measured vs dual sided. I'll cosign that advice too.
Seattle Forrest is offline
Likes For Seattle Forrest:
Old 09-27-20, 06:55 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quarq can give pseudo-balance, yes. But also yes, you don't actually care. Unless you're rehabbing a serious injury, it's a non-factor. You do care about total power, and I do think a single spider PM is better than two crankarms for that purpose.
Old 09-28-20, 07:49 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
Used SRMs are always an option too.
topflightpro is offline
Old 09-28-20, 08:30 AM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1759 Post(s)
Liked 488 Times in 313 Posts
Is the Easton Cinch any good? I have one, and it seems fine, but I don't really know anything about powermeters.
kingston is offline
Old 09-28-20, 08:48 AM
MoAlpha
Bikes: Shmikes
Quoted: 10148 Post(s)
Liked 5,841 Times in 3,145 Posts
May I be your friend? I love mine too. They are Shimano compatible, multiply configurable (4 and 5 bolt) relatively cheap, and available.
MoAlpha is offline
Old 09-28-20, 08:55 AM
datlas
datlas's Avatar
We can still be friends.
datlas is offline
Old 09-28-20, 08:58 AM
Atlas Shrugged
Quoted: 1245 Post(s)
Liked 1,321 Times in 673 Posts
we can still be friends.
+1 p2m
Atlas Shrugged is offline
Atlas Shrugged
+1 p2m
Old 09-28-20, 09:01 AM
himespau
himespau's Avatar
Quoted: 4224 Post(s)
Liked 2,944 Times in 1,803 Posts
Has anyone come out with powermeter pedals that work with SPD yet? I really like may Campy triple with square taper bottom bracket and no one seems to make crank-based meters that work with that.
himespau is offline
Old 09-28-20, 09:05 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
That's the question. I bet they'd sell a lot if they were priced competitively. I'd probably buy 2 pairs.
Shimano needs to get on that ASAP. Especially since they pretty much ruined any crank-based powermeter used on their 4 arm designs.
rubiksoval is offline
Likes For rubiksoval:
Old 09-28-20, 09:09 AM
datlas
datlas's Avatar
Apparently there is a hack/bodge you can do with Assiomas to retrofit onto SPD, I imagine there is a YouTube video that shows you how. I don't think anyone has an off-the-shelf version yet though.
datlas is offline
Old 09-28-20, 09:10 AM
kingston
Jedi Master
kingston's Avatar
The only ones I've seen IRL are the assioma duo xpedo hacks.
kingston is offline
Old 09-28-20, 09:11 AM
himespau
himespau's Avatar
You and me both.
himespau is offline
Old 09-28-20, 09:25 AM
RChung
Perceptual Dullard
Quoted: 914 Post(s)
Liked 1,131 Times in 487 Posts
I've never understood how one would use that information even if rehabbing from a serious injury. I've had to rehab from two semi-serious injuries over the years that I've had a (total power measuring) power meter and I'm not sure how that information would have helped. Can you explain? I also have a friend who had to have one leg amputated slightly above the knee. How could he have used specfiic sided information to aid his rehab?
[Edited to add:] Both injuries left me with obvious bilateral asymmetries. One involved sciatica, which weakened my entire right leg and foot. The other involved a bike accident, where I received brain trauma and significant losses on my left side (but, unhappily, also broke my right ankle). I had power data prior to each incident, so I could see a huge loss in my total power (in addition to the obvious difficulty walking up stairs or being able to control my bad leg and foot). In each case, when I was able to get back on the bike, I just worked on returning my total power to where it was, and walking up and down stairs without dragging the bad foot.
RChung is offline
Old 09-28-20, 09:50 AM
MoAlpha
Bikes: Shmikes
This is a good point. Presumably, riders with two legs would set progressive targets for the weak side and monitor progress.
Anecdotally, I’m a neurologist with a research background in neurorehabilitation and partial atrophy of the left quad from an old disc herniation. All I do is force myself to use that leg hard on the bike and in the gym and watch the bulk come slowly back over the years.
MoAlpha is offline
Old 09-28-20, 10:23 AM
datlas
datlas's Avatar
Plus, that gives you a handy-dandy excuse for cycling mediocrity. Got one for me??
Back on topic, I agree that the dual sided data is probably not actionable so of very little value other than "knowing" your efficiencies. It won't change anything. I know someone who works for a certain company that rhymes with "ages" and he admits that they sell double-sided meters purely for customer satisfaction, and that single sided are all anyone really needs.
datlas is offline
Likes For datlas:
Old 09-28-20, 10:39 AM
MoAlpha
Bikes: Shmikes
Plus, that gives you a handy-dandy excuse for cycling mediocrity. Got one for me??.
Haha, Don't forget I'm ten years older than you are too.
How about, your genetics are associated with other, more real-world-fitness-promoting, traits and you'll dance on all of the fast peoples' graves?
Actually, at >7000 mi/yr, you don't need many excuses.
MoAlpha is offline
Old 09-28-20, 11:02 AM
himespau
himespau's Avatar
That looks like a decent (and relatively affordable) idea. Hadn't see that before, thanks.
himespau is offline
Old 09-28-20, 11:07 AM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Are you asking what I would do, or are you passive-aggressively setting up the expectation for having a peer-reviewed journal study?
