New cross bike
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
Just going to let him ride. Might lose a chain. Enough folks here say a clutched RD is needed.
I need to know what I don't know. I'm smart enough to know this is new territory. I expect I can sell all this stuff in Feb and make out OK. I just wanted junior "on-par" or close enough to the equipment the others have, so equipment is not really an excuse. I buy a mechanical is an excuse, as is a few places over equipment But the full cross experience can be had with both his bikes. So going to chill - a wee bit.
If you child is military or you're military, contact the guys at Irish Cycles. They do a lot of cross and also run a military / veteran discount. Look for them at irishcycles.com .. Write them though, that is the way to get them to work with you. Big in North East and down in Carolinas.
Liked 371 Times
I'm off the market for a few days.
Liked 371 Times
Got this today.
Quoted: 1975 Post(s)
Liked 232 Times
Got this today.
Attachment 584127
Attachment 584127
Liked 371 Times
In this case, similar to others, road post is alloy ~99g. Thinking is Ti or carbon will offer a bit more flex and be less likely to snap for cross, although I doubt it likely with either material.
Liked 232 Times
I agree on the frame. Not always the parts. We never sat down and had a father son talk about carbon vs metal (except for spokes and spindles) and as such that txt relieved his frame-of-reference - coming from road.
Liked 371 Times
Got the race build in about 17lbs.
Pretty sure I could hit the UCI limit with a few changes, we'll see about next year.
IMO better to not have "all your eggs in one basket", and have a second bike in case you crash the 1st or flat ,
then your helper in the pits will hand you the other bike. .. minimum time lost,
also good on muddy races ride it until soon too heavy with mud then swap.
Liked 371 Times
We are still playing with the shifting/brake rub etc. and I have semi-metallic pads in the mail I'm told work better. That may be mechanic disc inexperience. I get discs are a requirement for cross, but certain they are not worth it when compared to the DA rim brakes for road.
I went to a DA chain and I see SRAM has stamped SRAM chain only. Likely going to move to Shimano type (Wolf Tooth) ring on front.
The pulleys were also narrow/wide so I swapped them out. Why would pulleys need to be narrow/wide?
The PDX crowd's race days, has a single speed race, I would think it a cheap bike to gain handling skills on ,
mainly because less to break off or damage..
they used to come to the coast, use the county fair grounds, for Halloween weekend, a costume party-race..
Bend OR, has more money population, etc. , so they shifted the out of Portland races to there..
It's more likely not raining there that weekend, too..
Liked 371 Times
Cross races are every weekend where he lives (CO) and the equipment may be his largest issue right now. Which is why I started an equipment thread. Maybe later - pit crew.
Handling skills cross from road riding pretty well, it is more getting used to the equipment limits/function.
stuntmatt
35
10-28-12 06:07 PM
LindyRides
10
11-01-11 09:56 AM
junkyardking
3
06-18-11 12:33 PM
