Best technique for riding down an icy hill without studded tires?
Quoted: 5224 Post(s)
Liked 3,581 Times
studded tires really donīt help with mushy snow right? only on icy road? How much traction does one get on icy hills (going down) with studded tires on a 1990s 8 speed 26 mtb with panniers and a fat rider? I crashed twice already going down hill due to the road being too slippery but I canīt get around it because my place is on top of a hill.
Liked 3,581 Times
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,600 Times
Thread moved form General Cycling to Winter Cycling.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Snowy / Icy conditions, wear 'regular' winter boots, with BMX-style flat pedals, and drop the saddle so that you can use your feet as 'Flintstone' style outriggers.
If I was going to be riding in the snow / ice on the regular, i'd look in to a fatbike, or at least an MTB with the biggest tires I can fit.
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
Imagine yourself on this icy hill on 2 instead of 4 wheels. Cheers.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Roadkill
I had a bike path that had a drainage problem and regularly got coated in ice when the rest of the ride was dry. Go off to the side and take the grass/gravel if you can.
Otherwise, studded tires help some, but if there's enough snow or slush on top, you'll still slip a bit, just not as severely as ice and no studs. Take it really, really slow.
https://m.youtube.com/watch?v=HfDZixZFzms
1) "First" of the season. Even in cold climates, people forget how to drive when the first snow falls.
2) Everybody in the collision has locked their wheels. The only car that avoided the collision and survived was the taxi who kept his wheels turning.
Actually, I think you may come out better on two wheels. When you do fall, between you and your bike, there will be a lot more surface contact that you will not slide a long distance. This will give you time to run or crawl out of the way before the next car comes.
Quoted: 5888 Post(s)
Liked 3,471 Times
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
Depends on many things. Do you have to stop or slow down at the bottom of the hill? Is it at all curvy, or can you just go straight down? how long and steep is it? What kind of ice?
Oh, and it depends on your skillz, too.
Quoted: 1062 Post(s)
Liked 665 Times
Just noticed this thread. There's a hill at the end of my street that's often solid ice in the mornings during February. I can negotiate it with my studded tires, but I realize that the cars can't stop, and their strategy is to hope for the best and stop when they hit the small portion of salted road at the bottom. So I hop over to the sidewalk, which is also solid ice, but no cars.
Sr Member on Sr bikes
Dan
Once when I cycled to work after a night of ice rain, a coworker asked if I found it slippery. I said "Only when I get off the bike."
After that day, I carried cleats.
Advice to the OP: Get studded tires or Grip Studs, or Slipnot bike tire chains. Your risking a fall isn't worth not spending the money and worrying about it.
Lower the seat enough so you can slide both boots on the ice, tripod style. Gentle rear braking is OK. You can go a bit sideways to control speed. Did this all the time when I was 13. Nowadays, the studs go on in December, off in March, which is a good deal easier.
100% Certified Beast
Quoted: 273 Post(s)
Liked 15 Times
how do you manage this when thereīs like zero traction to begin with? Unless you have spikes in your shoes or some type of crampons.
[IMG]https://i4.photobucke
Quoted: 5 Post(s)
I would point that sucker straight ahead, not use brakes (they will make you slide) and pray to make it to bottom. Now, if I had a choice with hill, get off bike and walk it.
Obviously won't work in zero traction. Given some snow or other source of surface roughness it can work, or at least did when I was thirteen. Winter boots with sharp tread can gig in pretty well at -10 or so. Black ice is pretty hopeless, though.
