Combining Fields
Bikes: Specialized Secteur, Specialized Roubiax,S-Work Roubaix, Specialized Amira S-Works
Quoted: 24 Post(s)
Combining Fields
We has a local Crit that every year combines the women’s 1/2/3 field with the men’s 60+ field. They gap the start and obviously score them separately. Last year there were 8 men and 9 women. In 2016, there were 9 men and 8 women. So, very small fields.
I’ve raced it this way two years now and have never felt like it was unsafe or that the combined fields influenced the outcome of the race in anyway. I race women’s cat 3. However, many of the local women are upset by the combined field saying it’s unfair and punishes women. But I can see why with such small fields why the promoter does it.
What are your thoughts?
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I don't think there should be races with fields of less than 10, personally, and they should combine fields more often.
I realize it's one thing to say that as someone stronger in a field versus someone weaker in a field, but at the same time you're being scored separately so if someone in your field is strong enough to ride away with someone in another field, then that's sort of your problem anyway.
With all that said, though, I'm not sure about combining women's fields with men's, regardless of their field size. I'd want to combine men's 60+ with another master's field and just let all the women race together, but again, I'm in neither of those fields so...
Quoted: 131 Post(s)
Note that the men's race dynamic doesn't really change in a field combined with women. The men race the men regardless of whether they started with women or not.
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
Here the promoters have started saying if there are not at least 10 in W1/2/3 they will be combined with the Cat 3 men. Some hate it, but the fastest women like it saying it's better preparation for bigger races than just riding away from a few other ladies.
Quoted: 842 Post(s)
Liked 469 Times
Race day is a long day so anything to shorten that time works for me. The first things that get cut out are 3's, or Masters 3/4/5 races which typically have good representation.
Quoted: 24 Post(s)
Where are you from?
Quoted: 18347 Post(s)
Liked 4,497 Times
So, go to Alberta, and the old Geezers can ride with the hot young babes? Unless they embarrass one.
You said "gap start", so I assume the rules discourage mixing pelotons. So, they are just using the same course at the same time. Nonetheless, there likely is some passing happening on a short course.
So, I could imagine it could be annoying passing the slower riders
How many races do they run? How long does each race last?
I think if I was doing it, I'd try to match rider performance, and then mix pelotons with a single mass start, unless it is as special national qualification race like state finals.
Quoted: 24 Post(s)
out walking the earth
The problem with this is there are times when there are multiple races in the same field, and no way to distinguish who is who. I lost a race to TKP's coach back in the day because I was racing against him and the 35+ guys, while another guy in the break was seemingly dying. Only he knew he and I were in the 45+ race and I was only concerned with winning the race. I got attacked and countered and down the stretch I lost the battle. And then this guy outsprinted me for the 45+ win.
The NYS and NJS state RR were actually the same race, and then had 40+ and 50+ combined. So they were pulling four separate races from one field. Gets confusing in hurry from a tactical perspective.
In NYC it's been standard issue to combine masters and women, but it never works very well. I hate to sound sexist, but so it goes, they mostly get in the way, and in the case were pretty sketchy. One women ended my buddies career causing a crash that shattered his elbow. It, of course, could happen in any number of ways (I have two surgeries caused by men, and one by my own ineptitude!) but in his case it happened that way and left a psychological mark. Issue is the courses aren't selective so they can sit in and then just tend to get in the way. Rotate up but not pull through...stuff like that.
W**** B*
Bikes: Several
Quoted: 103 Post(s)
I think combining men and women's fields at least make it easy to determine the people you're not racing. But that's about the only benefit.
Are you a woman in the lead pack and a dude attacks? If no woman follows, simply ignore it and enjoy the draft of the group pulling it back.
In the example given, it's much more likely the W1/2s are attacking and the 60+ men are watching it go. In P vs P, the men are likely faster. But I'm not sure how often that's true when it's W/P/1/2 vs M60+. Hell, WP/1/2 are probably faster than most M4/5s and some 3s.
I can see why promoters do it. Larger fields mean more drama, more racing, and allows them to get more fields in a shorter amount of time. Meaning shorter duration of closed roads, less corner marshal time, less Police fees, etc.
In one of my crits, with a pretty technical course, I jumped off the front with about 40 seconds left in the race. To my chagrin a woman was slowly going right through the apex of the turn as I arrived. I lost time because of it. It didn't make a difference because I still won. But it could have made the difference between first and second, or getting caught or not. It was just bad luck. But that can also happen in races were they don't pull dropped riders.
CanadianBiker32
"The 33"-Road Bike Racing
4
04-12-17 11:55 AM
BengeBoy
Road Cycling
58
09-22-10 11:54 AM
