Fixed gearing ratio options
Quoted: 17 Post(s)
Hello
I’ve been riding 48x19 fixed for a long time, casually. Recently been riding more for fitness and would like to try a different gearing. I’m in nyc and to get a 17t cog for the experiment would cost me 30 bucks and I don’t believe I have the tools to get the lock ring off, so installation cost too. For a potentially failed experiment, nor can a I find one on good old craigslist
I can get a 52 tooth chainring for 10 bucks, and that looks like an easy Allen key job and just a smidge lower ratio than the 48x17. Am I missing anything? If I recall from some Sheldon reading a larger chainring is apparently more efficient
any other wanted or unwanted side effects I should be aware of?
also do chainrings have varying sizes like the 1/8 or 3/32? Both have 5 holes so to the best of my knowledge should be any easy swap
Quoted: 17 Post(s)
Well my main question is now this, would I need a longer chain? I can move the rear wheel forward a good half inch, maybe a touch more.
Quoted: 897 Post(s)
Liked 9 Times
You can get the lock ring and drive sprocket off with some channel lock pliers, or other improvised tools, I would think.
Switching out the cog would be your best bet. Existing chain SHOULD work. You can get a 17 cog for a lot less than $30.
If you swap the chainring, you'll need the chainring, plus I'm 99% sure you will need a new chain too.
Quoted: 17 Post(s)
I’ve come to the same conclusion. Amazingly I’m having a tough time finding a rear cog for less than 30ish. The few places I contacted only have All City for that price.
Are unbranded cogs decent? That I could grab online for less
Quoted: 897 Post(s)
Liked 9 Times
You really ought to get a chain whip though, for removing sprockets. You'll use it, guaranteed. And that sprocket might be screwed down pretty tight.
Plus, I don't wanna give the board mechanics fits by saying to use channel locks.
Quoted: 897 Post(s)
Liked 9 Times
Here's a cheap ebay 17 cog, in 1/8th inch: https://www.ebay.com/itm/17T-FIXED-G...4AAOSwopRYiWVY
And one in 3/32nd https://www.ebay.com/itm/FIXED-GEAR-...kAAOxy-gBR9epQ
Quoted: 9 Post(s)
Sounds like you could use a tool that would do everything you need.
https://www.retro-gression.com/colle...-lockring-tool
If you take it to a shop you going to pay that much.
if you want to try a 16 t cog I know were you can get one cheap
https://www.retro-gression.com/colle...ts/2-dolla-cog
Quoted: 897 Post(s)
Liked 9 Times
It occurs to me you might just use the chain itself to get that sprocket off, just mount the wheel in the dropouts and pedal backwards.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2627 Post(s)
Liked 3,144 Times
well that's more than a little presumptuous...
edit: and rude
edit: and rude
"Your beauty is an aeroplane;
Quoted: 897 Post(s)
Liked 9 Times
Get sloppy with how you spend $30, how well are you gonna handle $30,000, which you will probably never have, because you wasted all your money on $30 sprockets.
DFTT
DFTT
Not actually Tmonk
Liked 3,144 Times
that's right, frugality is a virtue.
Quoted: 71 Post(s)
Liked 12 Times
OP, if you'd rather not invest in any additional tools to do the job yourself, paying a bike shop to swap out a cog shouldn't be expensive or time consuming.
Also moving form a 48 to 52 tooth chainring is moving the ratio up, not down, which means it'll be harder to pedal. Reducing wear by using larger gears usually refers to the size of the rear cog, you don't see any less wear on an extra 4 teeth up front. Also just having 5 holes on the chainring doesn't mean it'll match because the BDC may not be the same. Better off just checking out a LBS.
Quoted: 71 Post(s)
Liked 12 Times
Although the rotafix method might be a safer alternative since you're not actually riding the bike, but you can potentially scratch the frame.
Quoted: 17 Post(s)
30 bucks!!!!!!! Ha I just wanted to tinker with my bike and see how a different gear felt without turning it into a big ordeal, spare cogs, whip chains, whatever they call the lock ring tool all laying around my apartment to find out I am currently in the right gear lol
so I’ll wait until my chain breaks and let fate decide. That has to be next anyway
thanks for the feedback
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
Time also has value. All this time overthinking and looking to save a few bucks you could of bought a cog and the proper tool and been done with it.
You need to increase or decrease the chainring by roughly 3 teeth just to get the same effect as changing one tooth on the cog. So experimenting with gear inches is typically easier by swapping cogs. Purchasing multiple cogs is usually cheaper, easier to store, and last almost forever.
Quoted: 4802 Post(s)
Liked 3,922 Times
You say you've been riding fix gear a long time. On this bike, chain and cog? Stuff breaks, even fix gear stuff. Breaking a chain could cost you a lot more than $30 if it causes a crash. (Even if you consider the pain of injuries to you "free".) The money you spend on a chain whip and proper lockring spanner will be, over the long haul, money well spent.
The chain whip Colnago Mixte showed in post #5 looks like a good one. You can make you own far cheaper with 1 x 1/8 flat bar from Home Depot, some 1/8" chain and a couple hours access to a friend's drill and file and a chain riveter. You can make the homemade chain whip a lot longer than the one shown which may be a real blessing when it comes to getting you cog off. .(It was screwed on when? Were the threads greased? How many miles and hard hills have you done on it?)
I made my crude chain whip from a 3' bar scrap 40 years ago, Never regretted it. I've used various spanners. The Pedros Trixie fix gear tool is the best I've used (and works far better than any of the plate steel spanners if you ever decide to get fancy and run wild gears like 12 tooth cogs and their required bell shaped lockrings). It also doubles nicely as a hub wrench; very useful for those of us who sometimes get flats on the road on our fix gears,
This is just simple advice on riding fix gears from someone who was in close to your shoes when he started, fell in love with fix gears and never stopped, Many years later I could afford the fix gears I really wanted, own 3 and now change cogs for different rides frequently. Still have and use that (what, $5?) homemade whip.
Ben
Ben
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
OP lives in NYC. Surely someone in the Big Apple has a chain whip and lockring tool and be willing to help the OP out.
New Yorkers are pretty chill nowadays. Just walk up to a bunch of guys on FG bikes and be like, "Hey, can someone help me out?" The worst that can happen is they say no. If he was in Atlanta I'd do it for him yesterday.
@bergerkjh, have a look at Bike Recyclery. They sometimes have nearly new or NOS cogs for cheap.
-Tim-
-Tim-
Not actually Tmonk
Liked 3,144 Times
good ideas right there
Quoted: 897 Post(s)
Liked 9 Times
And that thread will rage on for weeks, and eventually get locked.
Not actually Tmonk
Liked 3,144 Times
We can always lock it now if you're in a hurry
Not actually Tmonk
Liked 3,144 Times
just messin' haha
back on topic though again I'll advocate your most recent response @TimothyH. It involves getting into the local cycling community which is always a good thing IMO.
Quoted: 99 Post(s)
Liked 115 Times
Hello
To remove the lock ring, ideally you need a C spanner of the right size. In practice, it is usually possible to tap it round with an old screw driver and a mallet. If you do that too often, it'll cause damage, but if it's only now and again it's OK.
I have always been able to remove the sprocket by putting a sudden hard shock through the pedal. Just keep the bike on the ground and apply all your weight suddenly to the pedal in the obvious direction.
All these tools are reasonably cheap, readily available, and easy to use. Why pay a LBS to do the job, when you could spend the same money on a tool and do the job yourself this time and every time after?
A change of 1 tooth on the sprocket will always make a bigger percentage difference than a change of 1 tooth on the chain ring. For example, 1/17 difference is bigger than 1/48 difference.
You can increase the gear ratio by putting on a bigger chainring but you will need more chain. You can increase the gear ratio by putting on a smaller sprocket. For 1 tooth difference, you may not even need to shorten the chain. Yes, there is an argument that two larger cogs will be smoother than the same ratio achieved through two smaller cogs. On the other hand, the two smaller ones will be lighter. As there are no hills in NYC, weight is not really an issue for you.
Chain rings come in different thicknesses and I think this depends on whether they are designed for a 1x, 2x or 3x set up. The differences are slight, but I had one once that never sat right on my single speed.
Chain sets come in 4 or 5 arm varieties, but there are also different "BCD". That stands for "bolt circle diameter". The 4 or 5 bolts are evenly spaced around a circle. You need a chainring that is drilled with the same BCD as the chainset. The two common BCDs are 130mm and 110mm.
