Disc Brakes; Yay or Nay?
Old 08-21-18, 11:12 PM
  #151
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
Hydraulic disk brakes on bikes do have a fluid reservoir in the brake lever and do self adjust. If yours aren't self adjusting then something is wrong with them. It is one of the advantages over mechanicals.
Through axles exist because people wouldn't tighten their regular quick release correctly and with the way front disc brakes are made that can equal your front wheel flying off when you hit the brakes. If the brake caliper was installed on the front of the fork that wouldn't happen, braking would push the wheel up instead of down, but nobody thought of that or didn't like the look and now it is just the standard. Stiffness is an added bonus.
Canker is offline
Likes For Canker:
Old 08-22-18, 07:08 AM
  #152
zze86
Quoted: 238 Post(s)
Originally Posted by MikeyMK
my 2kw e-bike weighs 90lbs, sprints to 45mph in just a few seconds, and despite using it on heavy stop-start routes i don't get fade.
Again, pads. And discs. Its not fair to compare the best rim brakes to small/budget/resin disc set-ups.
Also, the wet... enough said.
My bike would be hopeless on rims.
I don't think anyone is arguing about what a moped needs for brakes...
zze86 is offline
Old 08-22-18, 07:13 AM
  #153
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1954 Post(s)
Liked 3,656 Times in 1,677 Posts
Originally Posted by 79pmooney
I just went to see what tires I could fit on my road bike. I'm comfortable riding 28c road tires on fine gravel but Cycle Oregon is offering one of its gravel options this year where the stones are 1 to 2". It looked like I could get a 38c Pasela on the front. Fully expecting to have to deflate the tire, I went for it. Throwing the caliper release off was not quite enough. But popping the Tektro (Cane Creek? - I forget which this bike has) lever release and I had clearances to spare. Lots. And this on on pretty skinny rims, ~20 mm outside width. I suspect a 45c would go in inflated. The calipers are simply Shimano Ultergra? 105?. I picked them up used and never learned the model.
Now I do have a feature that helps clearance although that was never considered when I did it. My levers are road V-brake. Less leverage, more cable travel so they sit further off the rim. (V-brake levers to get the bigger, more comfortable hoods and drop the power for more predictable braking on mountain descents. I love e'm.)
Ben
v brakes are definitely underrated. They stop big time.
52telecaster is online now
Old 08-22-18, 07:16 AM
  #154
Cl904
Quoted: 106 Post(s)
Liked 36 Times in 23 Posts
you have a motorcycle, not a bike.
Cl904 is offline
Old 08-22-18, 07:21 AM
  #155
52telecaster
ambulatory senior
i don t really have a dog in this fight but you have a motor bike. I would assume it would require different brakes than a bicycle. It's really a completely different application. Cheers and ride on man!
Old 08-22-18, 07:37 AM
  #156
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
So what y'all are saying now is that rim brakes are fine because you're slow? Why would I not want brakes to quickly bring me down from 45mph? I can hit 45mph on a descent quite easily.
I didn't realize I was supposed to operate only within a range of lower, rim-brake friendly speeds.
Either the argument is that rim brakes are every bit as good as disc brakes, without any applied conditionals, or you're conceding.
And (hopefully) for the last time (in this thread)
THE RIM BRAKES ARE A BETTER OPTION IN THE OP's CASE BECAUSE THEY ARE LIGHTER, CHEAPER, AND THE LOW-END DISC BRAKES AREN'T WORTH IT
DrIsotope is offline
Old 08-22-18, 07:40 AM
  #157
Cl904
Quoted: 106 Post(s)
My motorbike can do a quarter mile in 13 seconds and has a drum brake in the back. Maybe bicycles should use drum brakes
Cl904 is offline
Old 08-22-18, 09:14 AM
  #158
zze86
Quoted: 238 Post(s)
So are you saying disc brakes are better or rim brakes are better? Cause it sounds like you just said rim brakes are better.
zze86 is offline
Old 08-22-18, 09:52 AM
  #159
Maelochs
Maelochs's Avatar
Quoted: 7648 Post(s)
Liked 3,464 Times in 1,830 Posts
My Honda can crush your motorcycle and has drum brakes in the back. Maybe we should all have Honda Civics.
Yeah, so ... what's your point?
Maelochs is offline
Old 08-22-18, 09:55 AM
  #160
Cl904
Quoted: 106 Post(s)
My motorcycle is a Honda too... maybe if Honda made bicycles we wouldn’t even be having this discussion.
Cl904 is offline
Old 08-22-18, 10:03 AM
  #161
Maelochs
Maelochs's Avatar
You win.
Maelochs is offline
Old 08-22-18, 02:45 PM
  #162
DrIsotope
Non omnino gravis
DrIsotope's Avatar
I'm saying it's not a black or white issue. In the OP's case, there is nothing to be gained in choosing the disc model, because the equipment is... meh. Rim brakes will do the same job for less money, with less weight.
Now if the extra $150 was magically getting him 4-piston hydraulic discs, then there would be no comparison. But it's not. It's getting mechanical Shimano BR-RS305s. They are in the best case unremarkable, and certainly not worth putting 1.75lbs on the bike.
The Hope RX4 brakes on my CX bike weighs about 200g more than a comparable rim brake setup-- with IceTech rotors, no less-- and I would put it up head-to-head performance-wise against any rim brake setup available.
But the calipers, rotors, levers, and hoses cost nearly as much as the Speedster 20 the OP is looking at, so it's not really relevant.
Old 08-22-18, 02:54 PM
  #163
Maelochs
Maelochs's Avatar
No! No! Screwdrivers are Always better than Allen wrenches!
Not a perfect analogy ... but there are different applications where different systems are superior and otehrs where they are not.
I rode a bike with Ultegra rim brakes in the rain last night. I guess I must have died.
This argument over which brake system is "better" is no more reasonable than debating index versus friction, bar-end versus brifter, or Al versus Ti, versus steel versus CF ... or road bikes versus CX versus MTBs, or hard-tails versus full squish.
Apples are just better than oranges. Always ... said the guy who didn't make orange juice.
Maelochs is offline
Old 08-22-18, 02:58 PM
  #164
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Yeah, I've got Ultegra rim brakes on my other bike. They work fine-- great, even. I had the option of getting my Cervelo with discs, opted not to. Good disc brakes are great. Good disc brakes are also (usually) pretty expensive.
Newer dual-pivot Shimano rim brakes are inexpensive and they work great. It's nice to live in a world where I can not only have both kinds of brakes, but recognize the advantages and disadvantages of both kinds of brakes.
Old 08-22-18, 03:03 PM
  #165
zze86
Quoted: 238 Post(s)
I see carbon rotors ARE available for bikes now. You could probably get some carbon rotors and cut that weight differential even lower. That would probably get rid of any brake fade except for the craziest, extremest situations.
zze86 is offline
Old 08-22-18, 03:46 PM
  #166
Maelochs
Maelochs's Avatar
On cars, getting carbon rotors up to operating temps is a real challenge.
Maelochs is offline
Old 08-22-18, 08:03 PM
  #167
TiHabanero
Quoted: 1740 Post(s)
Liked 1,369 Times in 718 Posts
I want to see Buell type rotors enter the bicycle arena. Or how about the Magura hydro rim brakes? Those things were powerful. As for low end mechanical or hydraulic disc brakes, get V brakes. They simply are a better option at the low end price point.
TiHabanero is offline
Old 08-23-18, 09:21 AM
  #168
desmodue
desmodue's Avatar
Quoted: 49 Post(s)
Liked 3 Times in 2 Posts
Why would anyone want a 25" diameter disc brake on a bicycle? It sucked on Buells, but at least it was balanced since everything else about a Buell sucked.
desmodue is offline
Old 08-23-18, 10:44 AM
  #169
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
Remember also, when the braking surface wears out on rim brakes you have to buy a new rim and probably pay to have the new wheel built. But on a disc brake bike, anyone can remove the 5 screws, lay on a new disc, and you are on your way.
rydabent is offline
Old 08-23-18, 11:35 AM
  #170
IvyGodivy
Gravel Rider
IvyGodivy's Avatar
Bikes: 2019 Trek Checkpoint ALR5 | Trek Farley 5
Quoted: 93 Post(s)
No matter the bike (unless it's a fixie) or where I ride it: it's disc breaks or nothing!
IvyGodivy is offline
Old 08-23-18, 11:41 AM
  #171
Ghazmh
Ghazmh's Avatar
Quoted: 694 Post(s)
Liked 910 Times in 487 Posts
Does it violate any rules of cycling to have and enjoy the unique attributes of both rim and disc bikes in ones fleet? Perhaps carbon rim brakes on a lightweight climber, disc on a comfy endurance bike used for bad weather?
Ghazmh is offline
Old 08-23-18, 12:28 PM
  #172
Maelochs
Maelochs's Avatar
It is simply unnatural. It violates every law of the universe. You must choose one to love and defend, and you must hate and revile the other.
Maelochs is offline
Old 08-23-18, 12:32 PM
  #173
Canker
Quoted: 330 Post(s)
I'm putting rim brakes on my motorcycle. Think of the weight savings.
Canker is offline
Old 08-23-18, 12:36 PM
  #174
IvyGodivy
Gravel Rider
IvyGodivy's Avatar
Quoted: 93 Post(s)
Seriously? Nice knowing you!
Old 08-23-18, 01:54 PM
  #175
Cl904
Quoted: 106 Post(s)
Honda rc113 rim brakes
Cl904 is offline
