BMC TT ZIPP 303 firecrest, rubbing on frame.
Hey guy's, I got a BMC TM1 with 303 zipp 25 continental and they are rubbing if I put 100 psi any solution to this problem?
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,831 Times
Will 23s fit?
lot of sales on 20mm tires, just sayin...
SuperGimp
25 contis tend to measure out more like a 28mm tire, especially on a wide rim (which I assume your zipps are on the wide end of the spectrum)
Try a different brand tire or a different width tire, I don't see that you have much of an alternative. Michelin tires also tend to portliness, btw
Quoted: 551 Post(s)
Liked 277 Times
