gear ratio
Bikes: 1980's Viner Track Bike, Litespeed M1
Quoted: 43 Post(s)
Liked 107 Times
gear ratio
Just curious what everyone is running for gearing. I run a 51x17. Mostly flat rural roads and average about 16 mph. I usually have a couple of stop signs and some wind.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
It varies for me, but lower than that gear, because I like to maintain a higher cadence. So I've got 46x17 on one bike and 43x16 on another bike. Your cadence with that gearing at 16 mph will be only 68 rpm, assuming a 700x23c rear tire.
- For approx 20-30 mile rides and 2000 ft elevation gain rides, my 50x17 was okay. Was able to do a 60 mile ride with that setup
- For 3000 ft elevation gain rides, went to a 47x19, and was still difficult
- Finally switched to a 42x19, specifically for 4000+ ft elevation gain rides
(likely staying with my White Industries Dos Eno 17/19 freewheel and the 47t tooth chainring for most of my riding, except for major mountain climbing where I’ll use the 42t)
Likes For highandlowrpm:
I am potato.
Quoted: 1793 Post(s)
Liked 1,633 Times
I run a 46/17 with a 700x38 for 74.6 gear inches & about 90rpm@19mph. Works good for the local conditions. Spin out at 160rpm for some fast downs. Kick out 45 rpm & a pile-o-watts for the steepest hill I'm able to climb near my house. (But can still do it.)
Gearing is very individual based on locality & individual fitness. I'm not sure crowd sourcing a bunch of data points clustering around some average of around 70 gear inches really is going to mean much other than "most single-speed riders ride at or about 70 gear inches."
Car dependency is a tax.
Likes For base2:
Quoted: 43 Post(s)
Liked 107 Times
I'm running a 25c tire. I usually use the fixed gear for short after work rides.
Veteran Racer
Liked 766 Times
So that still works out to about a 68 rpm cadence at 16 mph. If you geared down to 51x19, you'd have a cadence of 76 rpm, which is about where I'm at.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 654 Times
23x6 for me, Thinking of going 24x6.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For TejanoTrackie:
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
my 2spd kick back(on an '84 Miyata OneThousand), i think i set it up with like a 40t x 20t in the 1:1. Then when I kick back I think S-A goes like 1:1.38 ? I could google it, but I need to get back to work...... we're getting layoff announcements today. yay......
Quoted: 2502 Post(s)
Liked 2,980 Times
I've never understood why people like to slog along slowly in a mammoth gear on a fixed-gear bike on the road. For fixed-gear road riding, I've been using a 72-inch gear since I got my first track bike, in 1964. I believe that that's about the same as the Brits used for most of their fixed-gear riding in the 1950's. I got very good at spinning while training with my teammates, who were all riding road bikes.
Likes For Trakhak:
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by TejanoTrackie;[url=tel:22935270
22935270]Auto industry ?
since I started working for The Ford’s Family 20+ years ago, we’ve been having layoffs. (How’s there anybody left!?!)
being in the pension program the targeting laser has been swinging closer and closer… at least so I think!🤔
ps- and this came today!! Hahaha
Quoted: 480 Post(s)
Liked 277 Times
Veteran Racer
Liked 766 Times
Who said anything about going "slowly"? ;-) The bike with the 99 gear inches is a lot of fun on our "fast days" (relative term, we're all old guys) - the mid-week morning ride; a 20-mile loop with about 1,200' of elevation gain/loss. Those rides are just over 22 mph. But yeah, if I rode that bike a lot - for other than that quick blast in the mornings, I'd much rather be in the 70-80 Gi range.
Quoted: 480 Post(s)
Liked 277 Times
By my calculation your cadence is 75 in that gear at 22 mph, which is not very high. Personally, I'd rather be at a cadence of at least 90 when I'm trying to push hard, which works out to about 83 gi at that speed. Do you guys ride in a paceline, taking turns at the front, or are you in the wind all the time ?
Quoted: 43 Post(s)
Liked 107 Times
I completely agree. 90-95 is my sweet spot. 22 is the avg. There are some sections (one long one) that require peddling at 32++. We keep a mostly organized line for that ride - taking turns at the front. Because I'm the only one on a single speed, I try to minimize the disruption... like spinning out and slowing down the line - well, the part behind me ;-)
Likes For EJM73:
Quoted: 1609 Post(s)
Liked 2,216 Times
4616 on relatively flat terrain. Optin is 42/16 which I may swap to since I moved.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 458 Times
Depending on which bike, between 65-70 gear inches.
42/18 with a 50c tire.
44/17 with a 32c tire.
Quoted: 898 Post(s)
Liked 2,072 Times
44x17 for me, so 69.5" at 30mm tires. That puts my sweet spot at 18mph, and up to 20.5 is comfortable.
I rode a 200k Tuesday with ~4k feet of elevation, with a tailwind all day. I can manage 150rpm/30mph for a brief period on a descent, and I was at that limit several times. On the other end, I had to dismount and walk one short steep hill, and I slogged up a few others. On some of the tailwind flats, gearing was limiting my speed. Overall, I think my gearing was a pretty good compromise.
Cantilever believer
Quoted: 546 Post(s)
Liked 1,891 Times
I guess I'm an outlier - I'm not the fastest rider these days and I'm OK with that, I have a 17% grade on the road into the neighborhood, and I don't like lugging in low RPM, so I've been rather happy with a 38/18 on a 700C wheel. It does mean I'm spinning a bit going down that 17% grade, but it's not an impossible task.
Likes For RCMoeur:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
I'm a big fan of "medium gear" -- being in the vicinity of 72 gear-inches but not exceeding it. It's a good compromise between speed and the ability to climb hills without stalling. On my bike, it's currently 44/16 with a 26" tire for 71-ish gear inches.
Likes For ThermionicScott:
Quoted: 3369 Post(s)
Liked 3,670 Times
It wasn't until a few years later that I found some old track hubs, built some wheels around them, and converted a road frame in to a porteur bar cruiser. This time I decided to go for a much chiller ~70" 44x17 because this bike was just going to be for riding rail trails and I ended up liking that gearing a lot.
Likes For abshipp:
