Questions About Recumbent Trike Electric Motors
Quoted: 47 Post(s)
Liked 17 Times
I am in the market for my first recumbent trike. One of the features I want it to have is an electric motor. (We have lots of hills around here and I'm not getting any younger....)
My initial research shows me that there are a lot of types (power-assist or throttle?; rear-hub, front-hub, or mid-drive?, etc.) and brands (Bosch, Bafang. and others) My only brief trike experience was on a Catrike Villager (non-powered) so I need some help. I also have some experience riding a powered-with-throttle Rad two-wheeler a few years ago.
What should I be looking for in an electric motor for a recumbent trike? And what should I avoid? I like the idea of a throttle, since I feel that it can get you out of trouble quicker than simply power-assist, but maybe there are drawbacks to it that I haven't noticed I also have no idea of the advantages/disadvantages between rear/front/mid drives. I also have no knowledge of which manufacturers to look for and which to avoid. Is there one (or two) with better reliability and warranty?
I'm not interested in being a speed demon. I'm just looking for maximum reliability in getting me up some of the hills around here. So, can anyone help me out?
Thanks!
Bert
Thanks!
Bert
Quoted: 680 Post(s)
Liked 949 Times
bosch is going to give you the best feel and give you the best battery and longest range for that battery. bosch is also the leader in reliability and serviceability from shops.
Half way there
Quoted: 989 Post(s)
Liked 881 Times
I have an ICE Sprint that will probably be converted to non-leg power in the near future. I plan to use a Tong Sheng TSDZ2 kit. It's a mid-drive motor, which on a trike means that it's up front at the crank. I installed one on my wife's bike a few years ago and am very impressed with it's function. The crank incorporates a torque sensor for assist unlike some that only sense pedal motion. You can add a throttle but the assist is pretty rapid so you may not use it much. Eco-Cycles in Nashville is a great company to deal with for the TSDZ2 as well as other manufacturers.
I am spending some time in Tucson this winter, riding The Loop (130ish miles of bike path heaven). Ajo Bikes is a specialty recumbent shop in town. I've been riding with the Facebook Tucson Recumbent Cyclists. Virtually all trike riders in the club and on the path are e assist. It appears everyone here uses the Bafang. One of Ajo's mechanics rides with the club. He said that most people don't opt for the torque sensor as it adds an extra $100. to the cost, but the ride is more natural feeling with the sensor.
I recently made the switch to recumbent with e-assist. My new ride is the ICE Sprint X Tour with the Shimano Steps 8000 mid-drive (mounted up front on the crank). It's a 250 Watt motor. The control has 3 levels of power: Eco, Trail and Boost. I use the Eco mode most of the time. The sensors add more power in proportion to how hard I am pedaling, so I'm getting back into riding condition as I pedal. This system allows me to turn the power off completely and still pedal, or choose the power level appropriate for the amount of work I want to exert. I still use all ten gears on the cassette, and the front crank on the motor is a 1x 44T, I believe. It's a very intelligent system. I don't need a throttle. If I need a temporary boost in speed to get out of someone's way, I hit a button for more power and keep pedaling.
If you want a motor that will do all the work for you, you need a different type, but I don't think you can pedal those home if your battery dies.
Quoted: 2497 Post(s)
Liked 741 Times
With a tadpole trike the only options are the so called mid-drive (on DF's) that hang from the crank or a rear hub motor. My TSDZ2 weighs over 10lbs. It's on a cargo bike. It seems like a lot of weight to put on the front of a tadpole. Maybe the battery can be rear mounted to counter it. Torque sensing cranks can be found and will allow a rear hub motor to provide PAS (pedelec) which eliminates the need for a throttle and provides for proportional assist. The Shimano Steps and Bosch systems are lighter than Bafang or TongShen mid-drives but cannot be retrofitted to existing trikes, they require special mounts that can only work as part of a factory designed system.
Quoted: 47 Post(s)
Liked 17 Times
Thanks for all the info, everyone.
I have my eye on a new Catrike Villager. The electric motor options offered by the nearest dealer are the Bosch and a motor from ebikekit.com. The Bosch has a much longer warranty, higher price (by almost $1000), but no throttle. It also sacrifices about 20 gears (or so I've been told). OTOH, Bosch is a well known brand with a known track record. Given the choice between these two, which would you choose?
Does anyone have any experience with ebikekit.com? Also, does the Bosch use a torque sensor or does it use a cadence sensor?
Thanks!
Thanks!
Quoted: 680 Post(s)
Liked 949 Times
Thanks!
Thanks!
Quoted: 47 Post(s)
Liked 17 Times
with a bosch you only get one chainring. but thats usually enough. we have a bosch on our tandem and we have climbed 20% grades. bosch is torque sensor cadence speed and other factors and it feels totally natural.it will give you How much range you have accurately and reliably
Those decisions depend on one's technical skills and budget.
Aftermarket systems are best for those with enough electrical knowledge to understand wiring diagrams and tools to install, wire, and maintain.
Otherwise an OEM offering is the best direction.
Catrike is a great trike in rigid form although they really haven't mastered suspension.
Mid Drive is the most efficient system and you'll really want one with Torque Assist. Direct Drive Hubmotors are the least efficient at speeds under about 18 MPH and have some added drag when not powered.
Quoted: 47 Post(s)
Liked 17 Times
Thanks!
Liked 741 Times
Thanks for your reply. It sounds like you recommend the Bosch over ebikekit.com's offerings then? Also, since you said that Catrike "haven't mastered suspension", which manufacturer's recumbent e-trike's offerings would you recommend? (Note that I'm not being argumentative. I just want as much info/opinions for me to make an informed decision.)
Thanks!
Thanks!
Thanks!
Thanks!
HPV Scorpion FS, Azub Ti-Fly. They have excellent suspension systems and OEM Assist options.
Steintrike Wild One. Best suspension by a mile, no OEM assist option yet.
ICE, has lightweight suspension with OEM assist options.
Aftermarket systems don't come with much support, with cable lengths designed for bikes not trikes. Even the OEM systems end up with displays on bar ends rather than dead ahead on the Boom Post where they belong.
--> I make my own cables with JST connectors for signals as well as fabricating brackets etc., for mounting components. <--
When someone thinks "I would like to do that" after reading the previous sentence, they're probably a great candidate for an aftermarket system. Otherwise an OEM offering is generally a better choice.
Price is often a barrier. There are a few really nice used trikes out there as well.
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
I thought I would not want a pedal assist and just throttle, having had an ebike with throttle I liked in 2 wheel form. However, I have found holding a throttle button. for long periods is a giant pain in the butt. If you just do really short rides or just use it on hills, a throttle is okay, but if ou want to ride any kind of distance over a couple miles, get a pedal assist. You'll thank me. later. You can also get a throttle with many systems, to give you that quick thrust in taking off or in traffic, but the pedal assist is the only way to go for longer rides. And, frankly, you will ride longer if you have pedal assist.
Wife and I each have Terra Trike EVO which comes with Bosch motor. If we have to start on an incline, we put them in “turbo” mode briefly to get rolling. We love them.
Quoted: 3352 Post(s)
Liked 1,056 Times
I put a Bfang electric motor on my tadpole trike. Yes the motor is mounted in the front BB, and the battery is mounted behind the seat. It has 9 levels of assist and a thumb throttle. I have ridden it about 60 miles so far and level 2 is enough to smooth out most hills.
Likes For rydabent:
I put over 3000 miles on an ICE Adventure and a Catrike Trail fitted with Tongsheng TSDZ2 midrives. Only one problem: a wire chafed through the insulation and caused a short that fried something in the motor or display circuitry. I call that my fault for sloppy wiring and failure to inspect it once in awhile. Dave Hall at Eco Cycles will trace down and repair the problem when I send him the motor and wiring, meanwhile I installed a new motor, display and wiring.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Even though the video is not recumbent related, but general criteria involving ebike/motor/battery choices are very useful:
Short crank on bosch
Quoted: 47 Post(s)
Liked 17 Times
FWIW, I recently switched to a Bosch motor on my Catrike Villager. The crank shorteners which I was using transferred over to the Bosch with no problems.
Bikes: Elderly Specialized Hardrock
I bought a used HPV Gekko a few years back and since I'm getting along in years and have a few physical problems I decided to put a motor on it. I did some research, reached out to someone that seemingly knew what they were talking about and wound up with a Tongsheng kit, that 'included' a throttle. I installed the mechanical part of the kit but when I was wiring it, I found that even though it came with a throttle there was no way to connect it to this particular motor.
I tried it for awhile but the amount of force needed to pull away from stops or top hills was too much for me. I also did not like the 4 step torque sensing PAS system.
This year I bit the bullet and removed the Tongsheng and installed a Bafang BBS02 kit. It works much better for me, I have a throttle if I need it and I like the 9 step PAS. It's actually fun to ride where the Tongsheng wasn't. That's from my 80yo perspective.
Idk, my Bafang BBS02 is not a very reliable conversion kit. I'm not too fond of the pedal assist of the motor, and its build is unstable and doesn't give much power and torque. I'm not talking about the versatility anymore... The only advantage is that it can be installed relatively easily. This thread reminded me of a movie you can check out here since it is on the topic and has an unmistakable message. The essay examples by expert writers about the film "Wall-E" explained that we make and use too much stuff. If we keep going down this path, eventually, our planet will be overwhelmed with toxicity and threaten every life form to extinction. By beginning with electric bikes, we can save the Earth.
Liked 374 Times
As I have considered switching from a rear hub to a mid-drive and been reading up on torque v. cadence systems, it's clear to me that there is a need for both. not every rider is suited to a torque sensor, even though they say it's more like riding a regular bike. If you have a knee problem that makes initial pressure getting started a problem, or ( like me) have a medical issue where muscles give out the more you ride, a cadence based system can be better. One that has 9 levels of assist with the ability to program those levels to give more
precise control over just how much motor each level produces. if you are perfectly healthy a torque system seems like the right choice. i'm glad we have both options.
Likes For linberl:
Liked 1,056 Times
Now after a full summer of riding with my Bfang electric motor I have these additional comments. I fully recommend the torque sensing type of assist, with the addition of a throttle lever like I have. Im still running mine on a 2 setting out of nine, and use the throttle lever to get started a lot of the time. Having both I think is ideal.
