Please Suggest Front “Visibility Only” Light
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
Preferably fork mounted, plz.
I own two EXCELLENT road-friendly lights with cut off beams. I typically use both, one above the tire and one above the handlebars.
They light up the road in front of me very well, but because they direct everything onto the ground and are designed not to be un-intrusive, they’re not very visible to others on the road.
Can someone suggest a light, or lights that are designed just for visibility and not really made for illuminating the road and everything else?
BTW, I've owned standard "flashlight" beam Niterider, Cygolite and L & M lights and although they are VERY visible and also light up the road very well, the light is not constricted and BLINDS ONCOMING TRAFFIC.
Thanks very much in advance!
Quoted: 2497 Post(s)
Liked 741 Times
They light up the road in front of me very well, but because they direct everything onto the ground, they’re not very visible to others on the road.
Can someone suggest a light, or lights that are designed just for visibility and not really for lighting up the road and blinding everybody?
Quoted: 225 Post(s)
Liked 39 Times
There isn't any chance that your excellent shaped beam headlights "are not very visible to others on the road". Why would you work so hard to be "one of the good ones" by buying quality lights only to waste money on lights to shine in everyone's eyes. What's going on?
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
I use this light set to blinking
Cygolite Dice HL– https://a.co/d/9yrMPPF
Likes For BTinNYC:
Quoted: 3462 Post(s)
Liked 1,468 Times
I think you just want a very low power blinker. Something similar to a low power taillight, but with white instead of red light. In other words, a blinker to get peoples attention, and then they will also notice your constant on lights.
Over the years I have owned a couple such lights that were very cheap, but all eventually died due to water intrusion. So, I have no suggestions for brand or model. The ones I had came with a handlebar mount.
One with a wide but flat horizontal beam would be best since the LEDs would be dim enough to avoid blinding anyone. Wide enough to alert traffic in driveways and side streets that are not directly in front of you.
If you do not find something you like, forward facing reflectors may suffice, down low where their low beams would still provide some light, perhaps axle height. Or pedal reflectors.
Quoted: 2490 Post(s)
Liked 2,959 Times
Living in a city, I settled on a helmet-mounted light for my night riding. It has a moderately bright constant front light and a blinking rear light. It points where I look, and its movement makes me instantly identifiable as a bike rider. I can turn my head to sweep the front light in the direction of an oncoming car so the driver knows to be cautious. Always there no matter what bike I choose to ride. Works great.
2 in 1 Bike Light USB Rechargeable Cycling Helmet
Palmer
Quoted: 1671 Post(s)
Liked 1,827 Times
You want flash? Flashes for 320 hours:
https://www.cateye.com/intl/products...ghts/HL-EL135/
You want steady? This Knog Big Cobber looks promising:
https://us.knog.com/products/big-cob...ont-bike-light
Just Pedaling
Bikes: YEP!
Quoted: 335 Post(s)
Liked 523 Times
Quoted: 225 Post(s)
Liked 39 Times
Likes For michaelm101:
Liked 1,468 Times
Quoted: 225 Post(s)
Liked 39 Times
However, I've had many close calls with other non-lighted bikes and non-lights motorized scooters.
In one incident, I veered so instantaneously to avoid a "head-on" that I was thrown and suffered injuries...
I'll have to additionally mount some lights!
Quoted: 7352 Post(s)
Liked 2,479 Times
I'm not convinced that a to-be-seen light has any advantages over a to-see light except for cost. I have a German-made shaped beam headlight, and I get compliments on how visible it is from far away. The actual output is low. The beam shaping makes it look sharp, and I don't have it pointed too high.
Likes For noglider:
Quoted: 4560 Post(s)
Liked 2,802 Times
I've done a lot of night rides, solo and groups, and by far the best to-be-seen lights are spoke/wheel mounted LEDs. Nothing else comes close. When I've been in a car at night watching for cyclists it's often easy to overlook cyclists passing broadside if they have only front and rear facing lights. But spinning wheel mounted LEDs pop out of the dark like nothing else, and are visible from any angle of view.
For awhile I used older style clip-on LED/reflectors that were pretty visible as well, but heavier than new style LEDs and could arguably unbalance the wheel slightly. Not a big deal on my commuter/errand bike though.
Otherwise, the Blackburn 2'Fer and Grid 2'Fer are excellent values and very versatile. They can be switched from white light for the front to red for rear, multiple modes, and can be mounted on the bike or helmet. I used one for years before losing it, and it retained almost full runtime per charge even after five years. Only weakness was the pocket clip -- it popped off my running shorts while I was jogging and I never found it again. But the provided mount held securely to my bike or helmet for years, even on gravel rides.
The Cygolite Dice HL-150 someone else suggested looks good too. I put that on my list.
Likes For canklecat:
Liked 2,981 Times
If riding in the dark will happen & the whole cycling thing is a long-term thing to do, I'd invest in a long-term light that is "to see" . It will not be cheap if it's worth it's reputation.
-Oh Hey!
-Oh Hey!
Quoted: 482 Post(s)
Liked 1,593 Times
On the street, I agree, brighter is better.
Palmer
Liked 1,827 Times
Ah, you've added 'fork mount'.
https://problemsolversbike.com/produ...ut-light-mount
Couple of folks offer 'eyelet mounts'.
No eyelets, no quick release? There's the Cronometro Nob.
You could strap a light like the Cateye Omni 3 or Blackburn Grid directly to the fork.
Hmm. How about a Reelight Cio+?
Quoted: 225 Post(s)
Liked 39 Times
I owned the Blackburn 2fer and they were great on the forks, but the little rubber straps kept snapping. The lights eventually fell off...
The Cygolite Dice is not rechargeable :-(
Quoted: 225 Post(s)
Liked 39 Times
Liked 2,479 Times
@canklecat is right that a light in your wheel is a huge attention grabber. I've been complimented on mine. But I can't seem to keep it supplied with a fresh button cell battery. I can ride it in the rear wheel, but in the front, it distracts me too much.
@michaelm101, reflective stuff is not nearly as effective as something that emits light. You're not guaranteed light will hit you at the right angle.
I make these fork mount for my bikes. I usually use PVC, but sometimes I use copper pipe. Miter the inner end to match the curve of the fork. Cut a couple of slits to let the hose clamp through.
Likes For noglider:
Liked 2,802 Times
I've ridden alongside several folks who use elaborate multi-color LED lights on both wheels of their bikes and was surprised to find those weren't distracting to me. Probably because they aren't excessively bright, just bright enough to be seen a long way off, and very visible due to the sheer number of lights, colors, and rotating wheels.
Liked 2,802 Times
I understand the spoke lights. However, I have all my (street) bikes outfitted with reflective sidewall tires. They're awesome.
I walk a lot after dark and it's not usual to see about 10% of motor vehicles running without lights -- head or taillights. I don't know whether they've disabled the auto-on feature, but these aren't older cars on which it was up to the driver to manually activate lights. I'm guessing some people have disabled all lights because I've seen a few cars on which the brake lights don't light up when they slow and stop at traffic lights. And Texas is basically eliminating vehicle safety inspections so there's no practical way to improve traffic safety.
Regarding rubber band straps for bike lights, yeah, those tend to be a bit fragile. I have some Velcro straps and replacement rubber band straps for some of my most commonly used lights.
BTW, according to the Cygolite website the Dice HL 150 and TL 50 are USB rechargeable.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Likes For znomit:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Why waste your money on a third light when all you have to do is use the lowest setting on one of the lights and set it to flash? Is it because you're afraid of the weight of having one of your lights do that?
If all you want is a small strobe light, then get a Trek Ion 200 front light, it's very small and puts out up to 200 flashing lumens for 1 1/2 hours, or bring down the brightness for longer run time, the day flash mode will run for 12 hours.
I still swear by my dynamo powered CYO premium headlight. They light up the road with a cutoff beam but are still visible by everybody. I don't quite get what it is you are looking for though.
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 304 Times
Very pleased with the Light & Motion VYA but have not tried fork mount, use mine from the bars. Also rotate it among bikes with drop and straight bars.
It's automated wrt powering on, and programmed to pulse/flash various patterns depending on ambient light and whether still or underway.
