who uses a 47 tooth ring in their double?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1084 Post(s)
Liked 1,821 Times
I was going through my chain rings last night and shocked to find several 47 tooth rings.
I usually use a 53/42.
Other than maybe a pista, when would someone use a 47?
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Quoted: 3015 Post(s)
Liked 3,804 Times
Prior to 1958, when Campagnolo ruined it all, it was common to have a 3-tooth spread on the big and small ring. Most common was 52/49, but they could go down to 48/45. Certainly 50/47 was conceivable. If you are talking about "modern" stuff, racers got soft. Wimps needed a 42.
_MG_9280 by iabisdb, on Flickr
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
Spence Wolf used to sell top end road bikes with a 47 or 48T big ring for "normal riders".
"You don't need the big gears".he used to say
My yellow Cinelli (20 miles from new) is so equipped.
Previous owner Hunter S Thompson
and yes those are Jim Merz titanium crank bolts
/markp
/markp
Passista
Quoted: 868 Post(s)
Liked 721 Times
Don't know about the 47, but for me a 48/13 (a little less than 53/14) would be more than enough on flat roads.
Likes For Reynolds:
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times
I seem to recall riders in the 70's using 52/47 cranks(or something close to that) for a race like Paris Roubaix where a lower gear just wasn't necessary. Whaddaya know a quick search yielded just that ! A sweet looking Molteni bike, possibly a team bike. https://contenderbicycles.com/blogs/...essels-molteni
Glamour shots !
Glamour shots !
Liked 1,821 Times
I so rarely use my 52, 53 or 54. The jump is huge and while I like keeping up RPMs, I don't see the need to accelerate and pass cars in hilly Portland.
I think I'll try a 47/42.
Thanks for the input all.
Robert
Robert
Likes For Robvolz:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
I was going to ask “47 tooth in the outer or inner position”? I agree that a 47-13 is adequate unless you have a tailwind coming out of the Columbia Gorge.
(There were sub-freezing, 100mph gusts at Vista House in the Gorge a couple days ago. We are still waiting for it to get above freezing.)
Jeff Wills
Jeff Wills
Quoted: 1079 Post(s)
Liked 1,899 Times
Your limiting factor may be if the front derailleur tab is low enough to allow for proper adjustment. I run 50T big rings and the gap between chainring and derailleur is more than I'd like, but it works so you might be OK.
Likes For P!N20:
Quoted: 1303 Post(s)
Liked 1,912 Times
Rob,
I would ride the 47-42 combo and think in terms of half step gearing. As an older guy, the range is better for me. How many do you have in your stash? With enough, there is a potential for some Panto Merckx levers as trade bait. Smiles, MH
Likes For Mad Honk:
slow on any terrain
48-32 rings with Campy Chorus, ftw! 13-34 cassette yields < 1:1 granny. great where I live . . .
Likes For eljayski:
Bikes: 1946 Holdsworth Cyclone, 1969 Cinelli SC, 1972 Raleigh Pro, 1973 Merz road bike, 1974 Alex Singer Sportif, 1974 Merz track bike, 1975 Teledyne Titan, 1976 Ritchey road bike, 1977 DiNucci built Merz track bike, 1977 (?) Exxon Graftek, many more!
Quoted: 139 Post(s)
Liked 1,432 Times
I use a 47/36 on the front, with a 13/28 freewheel. This combo allows a normal Campagnolo Super Record rear derailleur to shift all the gears nicely. I use this on very steep hills, I can go up without walking. High gear is OK for slow old me. The chank on this bike was modified by the late great Jon Williams.
Jim Merz
Jim Merz
Likes For Portlandjim:
Quoted: 3464 Post(s)
Liked 2,831 Times
Portlandjim - having trouble figuring out how a Record 144 BCD arm could be machined to a small enough BCD and show the material that presents on your bike. Maybe with a short production G.S. 5 bolt arm. I doubt material was built up then cut back.
Quoted: 139 Post(s)
Liked 1,432 Times
Jim Merz
Quoted: 139 Post(s)
Liked 1,432 Times
One more bike of mine with 47/36 chainrings. The arms are Chater Lea, I made the chainrings patterned on Holdswoth Allez rings. The bike is a 1946 Holdsworth Cyclone. Jim Merz
Quoted: 930 Post(s)
Liked 1,293 Times
I have 47-42 chainrings on my Cinelli, which results in a perfect half-step gear combination. The lack of a real high top gear just means that I spin out a little earlier on descents.
Likes For davester:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
Making up the numbers
Quoted: 107 Post(s)
Liked 502 Times
Glamour shots !
Glamour shots !
However, 52/47 and similar half-step chainrings were not uncommon at Paris Roubaix and for flatter time trials in this era. Earlier still several of Coppi’s later bicycles featured 47t inner chainrings, irrespective of terrain…
Nothing quite says wall hanger like drillium toe straps
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 268 Post(s)
Liked 325 Times
I don't, but I could be happy with it. Not in its vintage use, but as the outer ring. 47-11 is still likely a taller gear than I really need.
Likes For mhespenheide:
Quoted: 117 Post(s)
Liked 209 Times
Beautiful bicycle, but the description is incorrect. The photographs show a crankset that if not very nearly is very actually 53/42.
Likes For Garthr:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
Another old guy here, but also fairly flat riding environment. I have 47-36 on one double. 46-36 on another and triples in that sort of range but with a granny. I love the gear calc website to play around. Without long hills to go down 47 is tall enough for me.
Quoted: 5888 Post(s)
Liked 3,471 Times
46, 47, or a 48, outer works fine for me. I'm well past my racing days. I can spin all the top gears with an outer in the upper 40s and an inner in the 30s gets me up the (few) 10% local grades in style.
One of the reasons I'm partial to French bikes is that it is a heck of a lot easier running a "compact" double on them than on Italian bike assuming you want to stay with campy cranks.
Likes For bikemig:
Likes For Sierra:
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
My 83 y.o. memory claims I have a Grand Jubile with a 48/36 double driving a 5 speed 14/28 FW, but the bike is currently 3000 miles away in Oregon, so I can't count teeth to confirm. Could be a 47 or 46 big ring. The combination does well in Willamette Valley and foothills. Don
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
I have standardized on 46-38 1.5-step gearing with 13-26 in back. Top gear is only 1% lower than the 50/14 (96.4 gear-inch) I used for decades, and I can go 10% lower than with my previous 50-42 ringset, without messing up my ratio progression.
1959 Capo (128mm BCD Nervar Star) and 1982 Bianchi (130mm BCD Ofmega): 46-38 / 13-26 6-speed. Top ratio = 95.5 gear-inches. Works with Campag. NR on the Bianchi's short derailleur hanger tab.
Mountain bike (110 BCD outer): 46-38-28 / 12-30 8-speed (13-26 6-speed, plus the 12 on top and the 30 on the bottom). Top ratio = 99.7 gear-inches.
These are the most satisfying gearing combinations I have ever used. .
Likes For Mr. Spadoni:
