Can a CF bike be a rain bike?
Thanks to randombikeparts.com I put together a 17 pound bike for $700!
So cost wise I can make it a rain bike but should I?
Will clamping fenders on it, all the road grime being kicked up and generally being in the rain etc. effect it?
Thanks
Thanks
Quoted: 8274 Post(s)
Liked 9,031 Times
It won't melt. Look at all the cf mountain bikes being hammered in the mud/rain/snow.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12759 Post(s)
Liked 7,673 Times
No rust. Top choice!
Likes For LesterOfPuppets:
Titl should have been "Should ..."
Yeah, I know CF is tough, but I was also referring to my effort to service it.
For example, inevitably wet grime you forgot to clean gets baked on the underside. With an ALU/Steel frame removing it doesn't remove/effect the top coat. But this CF bike has one of those matt finishes.
Also, this CF bike is absent of drain holes from the moulding process, so if water does get into the frame (i.e. from the seat post area) will that cause issues?
Quoted: 663 Post(s)
Liked 496 Times
Epoxy composites will absorb some water. This was investigated by the Geugeon brothers some years ago. While epoxy resin will absorb some tiny amount of moisture, it is not enough to compromise the laminate. You may be able to fine out more by poking around their web site or their online magazine. https://www.epoxyworks.com/
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,852 Times
CFRP boats are wet-sailed all season without ill effect.
Likes For MoAlpha:
Quoted: 3233 Post(s)
Liked 2,079 Times
If used a lot in the rain I might want a BSA threaded b-bracket. Means I don't have to go to the shop to swap.
OTOH, a carbon won't rust !
Quoted: 7650 Post(s)
Liked 3,472 Times
Wheels manufacturing and a few other companies make excellent thread-together press-fit BB replacements---a little heavier, but bullet-proof, and easy to remove.
As for cleaning the bike---you would need to clean it no matter whether it was a rain bike or not. I use Simple green and very sofft cloths, lots of rinsing and very little rubbing or scrubbing ... but as others have said, CF is a mature technology which has proven its durability in a lot of applications far more stressful that a rainy bike ride.
Im sure the frame will be fine in the rain, but "clamp on fenders" are not nearly as effective as proper mudguards, like SKS longboards or SKS Olympic. Im never going back
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
Yep, cheap is good for a rain bike!
Quoted: 451 Post(s)
Liked 364 Times
I live in a small apartment right now and there is not a hose outside for me to use. So, I just turn some warm water on in the shower and lay a couple of crummy towels down and gently rinse the bike off in the shower. Takes a little maneuvering, but in 15 minutes or so, it looks pretty darn good. I just gently wipe it once it's wet, and pretty much all the crud comes right off. No chemicals. Just warm water and some crappy towels and rags. I clean the drivetrain separately.
Likes For bpcyclist:
Bikes: Shmikes
Liked 5,852 Times
Just beware of the dissimilar metals problem wherever aluminum is in contact with the composite. The wetter it is, the more corrosion will occur. Use a good marine galvanic corrosion inhibitor.
Likes For MoAlpha:
RacingBear
If you are looking for fenders I have been pretty happy with crudracer, the latest iteration of mk3 is best one yet.
Quoted: 551 Post(s)
Liked 277 Times
Any bike can be a rain bike.
Likes For tagaproject6:
Recusant Iconoclast
It's a bike, not a piece of artwork. But it's also not maintenance-free; learn to wrench it yourself. YouTube is a great resource. Now ride the heck out of it.
Quoted: 2952 Post(s)
Liked 3,106 Times
In my experience, the main thing about whether a bike will make for a good rain bike is how well you can fit full-coverage fenders to it. And that's usually governed by brake bridge and chain stay clearances.
Likes For caloso:
My winter, rain, bad weather bike;
'73 Raleigh Gand Prix...$60
Full fenders...$35.
Put my vintage tubular wheels with 33mm CX tires, pumped to 50-60 psi. Roll over road debris and thru standing water. Bike stays clean, I stay dry.
Full fenders...$35.
Expired Member
Liked 5,408 Times
Good fender line, not always easy to achieve.
