Official Trek FX Thread
#1901
Bikes: Trek FX 3 Disc & Trek 5200
I just bought a new FX3 Disc and added the adapter kit and bar ends. Worked perfect! Loosen the shifters and brakes to creep inward a tad. Had to cut off maybe 3/8" of the new Isonzone pad for the adapter end plug to fit properly but everything went on very easy and mission accomplished!
Likes For Jim J:
#1902
Quoted: 765 Post(s)
Liked 1,735 Times
CO2 for the win....
#1905
I really like the climb ability, handling and speed of my FX, but I have to do something about the ride to use it on anything but smooth bike trails. Mine is bone jarring on any type of in-town streets, or less than smooth surfaces. The bike is light and rigid, and makes peddling a breeze, anything more than 2-3 miles will give me a headache. I think it has 700 X 32 tires which I may try and go larger and perhaps a suspension seat post.
#1906
Quoted: 427 Post(s)
Liked 699 Times
#1907
I tried running lower pressures, it helped slightly but I am still taking too many jolts, the great efficiency of the bike is offset by the beating I would take going any distance on roads. It's great for smooth trails, and that is the only place I run this bike right now. I'm thinking 700X35's may improve the ride without slowing it down too much.
Likes For FREEBIRD1:
#1908
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
You could probably go up to 38s or 42s (depending on frame clearance) and you wouldn't notice a thing in terms of efficiency. Rolling resistance is much more about the construction of the tire and materials used than it is about the physical size. In fact, larger tires are often more efficient in many circumstances. If you're using the factory tires, they're very likely not very efficient and may have a layer of puncture protection that, while it helps ward off flats, increases rolling resistance and contributes to ride harshness.
A larger and more supple tire would make a considerable improvement to your riding comfort. I can speak only of two tires I think would work well for you, and they're relatively inexpensive: the Continental Speed Ride and the Panaracer Pasela (standard version; not the ProTite version). Both of these tires are about 38mm in actual size (the Contis are labeled 42mm but will inflate up to about 38 on your wheels), are relatively inexpensive (about $25 each), are relatively light weight, are relatively compliant, and would probably feel a lot more comfortable to you than the factory Bontrager tires I presume you have. Neither of these tires are at the top of the class in any one area, but they offer pretty good performance at a reasonable price.
Edit: I have a set of the Paselas in both the ProTite and standard version. The reason I didn't recommend the ProTite is because that puncture protection layer does add some stiffness to the tread and it's a difference that I can feel on the bike. I've run both tires on the same bike and I prefer the standard version.
Likes For hokiefyd:
#1909
Liked 762 Times
I should re-state that, as I think my wording wasn't clear. I didn't mean to imply that those are the only two tires I think would work. I meant to say that I can speak from personal experience about only two of the many tires that would probably improve your ride...
#1911
Installed Bontrager 700X35 H5 hard case ultimate's, ride improved about 50% and they did not slow it down any. The grip is fantastic, and these will handle some gravel if needed. The ride however compared to other bikes I own is terrible, I don't think hybrid bikes are for me. It was fun to try one out
#1912
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times
Does anyone know how wide I can go with tires on the FX Sport Carbon 4? The Trek site says 35c without fenders but I'm wondering if that also gives some extra room for 35c tires that may measure out bigger after mounting.
Thanks.
Thanks.
#1913
Quoted: 765 Post(s)
Liked 1,735 Times
38's easily without fenders.
Likes For jaxgtr:
Likes For Karmajack:
#1915
Bikes: '21 Trek Domane AL3, '18 Trek FX2
Liked 11 Times
Funny. My with and I have almost the same combination of bikes (an FX and a Verve).
I wonder if he's got a Domane too.
#1917
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
2012 Trek FX 7.3 here. 22.5" size XL.
- I would have preferred a slightly longer top tube to get away with a shorter stem. Stock is 120mm
-Paint is awful quality
- stock brakes are horrendous from quality control perspective
- otherwise, great frame and solid parts for the price range
- excellent all around performer for something designed to be ridden more upright
-im 190lb and this bike handles up to 20kg of loaded riding very well.
#1918
Quoted: 427 Post(s)
Liked 699 Times
Don't know about the 2012 models, but the newer FX line is fine. And a well adjusted set of V-brakes with a set of Kool-Stop salmon pads work very well. Have Avid V brakes on my old mtn.bike and they can throw you over the bars with 2 fingers (maybe one!).
#1919
Thinking about changing out my stock pedals on my FX 2. How much of a difference are "upgraded" pedals?
Was looking at Race Face Chester pedals.
Thanks
Thanks
#1920
Liked 762 Times
The Chesters are terrific pedals. They make a big difference in keeping your feet connected to the pedal, with the shoe retention pegs. They're also pretty large (in terms of size), and I think they're a lot more comfortable than most pedals, especially for large feet. Unlike many pedals, they're longer (front to back) than they are wide...but they're still wider than most stock pedals...so the platform ends up being about twice the area of typical stock pedals.
Likes For hokiefyd:
#1921
Quoted: 427 Post(s)
Liked 699 Times
You will probably like them. I used to only mtn.bike and have been using flat pedals with pins for years. Even use them on my road bike. Pins keep your foot firmly planted on the pedal, but allow you to get your foot off quickly, if needed. That type of pedal works best with shoes that are not slick on the bottom, but which have a sole design that allows the pins to grip, such as what are described as "trail running shoes".
#1922
Drip, Drip.
Liked 193 Times
The metal "quick release" thingy which holds the brake line n place appears to have bent out of shape which caused the wire to come out while I was riding. Imagine the panic which ensues when you press the lever and feel nothing. I have bent this piece back in place with some pliers, but have not reused this specific brake since.
#1923
Drip, Drip.
Liked 193 Times
I am also looking to replace my pedals.
I actually tried flipping the stock 120mm 10 degree stem upside down to see how it feels. The stem is almost perfectly perpendicular with the ground now. It feels really good when cornering. I'll upload a pic sometime.
#1925
Drip, Drip.
Liked 193 Times
Anyone else here think that this bike would be better suited to 650b x 50 tires? The rolling diameter would be exactly the same as the 700 x 32.
As for the Bontrager tires on my FX, I actually quite like the casing. They maintain their shape even with lower pressures and certainly ride smoother than other tires i have tried close to around the same diameter. The ride is about on par or maybe slightly better than my old chromoly road bikes - that is to say, reasonable over everything but the worst of bumps.
Tire clearance and braking aside, is this frame well suited to 650 x 50 wheel/tires?
