Restoring original paint & logos
Old 06-14-21, 02:46 PM
Wilbur76
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times in 84 Posts
Picked up these two 1989 Specializeds. Really sunfaded with a milky finish. I’d like to restore some shine back to the original paint and logos. Heard about cutting compound but would that be too harsh/abrasive or is there a way to use it in a gentle way? Thanks in advance!
Wilbur76 is offline
Old 06-14-21, 02:52 PM
CliffordK
CliffordK's Avatar
Quoted: 18347 Post(s)
Liked 4,497 Times in 3,344 Posts
How much of it is paint, and how much is decals?
I've heard that a good polishing compound can do wonders for oxidized paint on cars.
The fork should be easy enough to remove, and polish up as a test.
CliffordK is offline
Old 06-14-21, 03:30 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10392 Post(s)
Liked 11,842 Times in 6,062 Posts
I've been using Meguiar's Scratch-X. It does an amazing job on paint that hsa lost its gloss, but I've heard you may want to go light over the decals, unless they're under clear coat.
genejockey is offline
Likes For genejockey:
Old 06-14-21, 04:36 PM
Wilbur76
Quoted: 69 Post(s)
This looks like clearcoat flaking off so I can assume I only have the basecoat left.
Wilbur76 is offline
Old 06-14-21, 05:37 PM
jamesdak
Quoted: 2322 Post(s)
Liked 4,925 Times in 1,760 Posts
Meguiar's #7 works very well to restore dry powdery paint.
Steel is real...and comfy.
jamesdak is offline
Old 06-14-21, 05:49 PM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,747 Times in 937 Posts
Were those bikes mine, I would start with the less aggressive approach - Mother's Cleaning Wax, to see if that achieves the results that I seek. Polishing compound would be next on my list but only if there is a clear coat over the decals...
randyjawa is offline
Likes For randyjawa:
Old 06-14-21, 06:32 PM
Kabuki12
Quoted: 870 Post(s)
Liked 2,264 Times in 1,268 Posts
I would try a wax based non abrasive approach as bike paint is very thin and decals can be damaged easily. The wax will bring shine where possible without too much damage , in my experience of dealing with old bikes.
Kabuki12 is offline
Likes For Kabuki12:
Old 06-14-21, 08:15 PM
Charles Wahl
Disraeli Gears
Charles Wahl's Avatar
Quoted: 504 Post(s)
Liked 369 Times in 214 Posts
I restored a Specialized Hard Rock from about 1993 that didn't have much paint damage at all (it was a bike that's always been in this family), and I remember it as having a clear coat. That may be what is "milky" in your case. And if it's flaking off, then that's a double-whammy, because my bet is that you won't get it all to peel off. While the product suggestions above are good, for a finish that just needs "renewing" (removal of oxidized material), the results involving some-flaking, some-adhering clearcoat may be "uneven"; probably fine for a rider, so long as that level of patina is OK with you.
Charles Wahl is offline
Old 06-14-21, 10:23 PM
dbhouston
Bikes: 2005 Orbea Spirit + 2018 Specialized Diverge + 1974 Raleigh Competition + 1983 Centurion Pro Tour 15
Quoted: 85 Post(s)
Liked 218 Times in 95 Posts
Beautiful bikes, and totally deserving of some love. Did you see that era of Specialized MTN bikes getting some retro-love at Unbound Gravel this year? https://www.gravelcyclist.com/bicycl...lized-diverge/
Veterans and experts can pick the right level of aggressiveness and work their way down to a pretty finish. The rest of us need to work our way up, from gentle to more aggressive and then back down, and bikes are harder than cars because the decals are not all equally protected by the clearcoat. I think most vintage bike people in the US seem to be working with Meguiar's products, but your local auto parts store will be happy to show you the safest order of attack. Anything called a "compound" or "polish" should work by gently grinding into the surface of the paint, so work slow and excercise care around decals. Surface treatments like waxes or silicone finishes work by filling in the gaps, and really can work wonders on old paint without the danger of rubbing something away. Good luck with those great looking bikes.
dbhouston is offline
Likes For dbhouston:
Old 06-15-21, 07:17 AM
Mr. 66
Mr. 66's Avatar
Quoted: 1134 Post(s)
Liked 1,726 Times in 950 Posts
I would wipe it down with windex maybe, I would wipe it down with oil. I go nonabrasive first and work my way to wax, if that's not enough I'll use rubbing compound.
This was in dreary state at the time of acquisition. I did use rubbing compound on the Trek but it left white everywhere the clearcoat chipped, I used motor oil after the rubbing compound. Came out sharp!
Mr. 66 is offline
Likes For Mr. 66:
Old 06-15-21, 08:05 AM
tendency
Quoted: 236 Post(s)
Liked 171 Times in 104 Posts
Looks like the clear coat is shot. I'd remove what's left and re-clear it if that's the case.
Try using a nice microfiber cloth and a polishing compound like Meguiars Ultimate Polish or Mothers. I wouldnt worry too much about damaging the finish if you polish by hand. It's next to impossible to take off or damage the clear by hand polishing.
tendency is offline
Old 06-15-21, 08:37 AM
leftthread
leftthread's Avatar
Quoted: 111 Post(s)
Liked 213 Times in 105 Posts
I've been using Meguiar's Ultimate Compound lately. It works really well.
leftthread is offline
Old 06-15-21, 03:17 PM
Wilbur76
Quoted: 69 Post(s)
I’ve been thinking about reapplying clearcoat since it looks like it’s peeling off. If I apply a polish to remove the milky clearcoat, wouldn’t I have to remove the polish so I can apply new clearcoat. Don’t I want to have a clear basecoat surface to apply new clearcoat? I would think the polish will not allow the clearcoat to adhere over it.
Wilbur76 is offline
Old 06-15-21, 03:20 PM
Wilbur76
Quoted: 69 Post(s)
I had the same Trek Jetta edition bike when I bought a VW Jetta in the late 90s. I loved that car.
Wilbur76 is offline
Old 06-15-21, 04:26 PM
tendency
Quoted: 236 Post(s)
It's hard for me to say w/out seeing the bike in person. You'll first need to either remove what's left of the existing clearcoat (which can be done by gentle sanding or using a clear coat removing chemical) or try to repair the clear coat if most of it is still good. That would involve sanding off any damaged sections of the existing clear then blending those sections in using sandpaper (wet sand) with the existing good clear. You can then re-apply a good 2K clear or, at minimum, 1K clear. You can spray clear over clear as long as the underlying clear has been cleaned.
As for removing polish just give the bike a good wash with warm soapy water then a good rinse. Allow to air dry in the sun or (while wearing gloves) wipe down with clean microfiber.
tendency is offline
Likes For tendency:
Old 06-15-21, 04:51 PM
Wilbur76
Quoted: 69 Post(s)
Originally Posted by dbhouston
Beautiful bikes, and totally deserving of some love. Did you see that era of Specialized MTN bikes getting some retro-love at Unbound Gravel this year? https://www.gravelcyclist.com/bicycl...lized-diverge/.
I did see it. Also saw the Gravelcyclist picked up an 89 Rockcombo in Florida with plans to bring it back to full retro.
All this reminded me to get off my ass and start working on the Stumpy and RH I had sitting in my yard.
Wilbur76 is offline
Likes For Wilbur76:
Old 06-18-21, 09:32 AM
Deepcherry
Off grid off road
Deepcherry's Avatar
Bikes: Corratec Xvert, Peugeot Origin 30, GT Outpost, Kona Cinder Cone ‘93 Specialized StumpJumper, Ritchey mtb
Quoted: 38 Post(s)
Liked 123 Times in 72 Posts
The finest cutting compound I have used is Tamiya Polishing 'Compound', it is a liquid paste cutting compound designed for plastic scale model polishing. Absolutely incredible stuff, and much more delicate than the automotive alternative. It comes in three grades.
Should be available in your local hobby shop or eBay.
Deepcherry is offline
Likes For Deepcherry:
Old 06-19-21, 02:34 PM
capnjonny
capnjonny's Avatar
Quoted: 339 Post(s)
Liked 631 Times in 229 Posts
I have spruced up quite a few bikes with faded paint. Here is what I do
strip everything off frame and fork
wipe everything with paint thinner or wd 40 to remove the heavy grease.
Wash with simple green and rinse well, making sure you have cleaned off ALL the grease and dirt
Rub out with 3m white polishing compound. this will remove embedded grease , light scratches, other contaminants like tar or latex paint.
clean with alcohol wearing rubber gloves to keep finger print oil off bike
set up frame for painting. I do a rotisserie with a dowel sttached to a table and the seat tube pushed onto the dowel
wipe down with tack cloth to remove any hair/ dust on metal
Spray frame with Rustoleum Automotive clear , using paint can warmed under hot water . Paint on warm day
As you spray - chain stays first, then seat stay, down tube, top tube, and lastly head tube, rotate the frame on the spit so it never stays in the same position
This will help keep the paint from running.
For best results paint in shade on warm/ hot day using full can of paint that is shaken 1 minute and warmed under water.
working on cold day with cold frame makes paint run much easies. using almost empty can also seems to increase runs. possibly the paint is thinner then.
Do not spray automotive clear on any paint that is not thoroughly cured, as in a few months old at least.
You will be surprised just how much better the paint will look after this treatment.
capnjonny is offline
Likes For capnjonny:
