When do you change tires on your hybrid?
Old 06-14-21, 07:03 PM
ps249
ps249's Avatar
Bikes: 2019 Specialized Sirrus Elite Carbon
Quoted: 20 Post(s)
Liked 11 Times in 5 Posts
I have had my specialized sirrus since February 2019. Do you swap your tires after so many miles? Years?
ps249 is offline
Old 06-14-21, 11:14 PM
Slowkevin
Quoted: 10 Post(s)
Liked 18 Times in 14 Posts
there’s wear indicators but I changed mine when they couldn’t handle the blue and black trails hhaha
Slowkevin is offline
Old 06-15-21, 05:19 AM
jtaylor2
Quoted: 10 Post(s)
Liked 8 Times in 6 Posts
I swap them when they are worn out. I'm sure how long that takes depends on the type/quality of the tire, rider weight and perhaps type of riding surface.. On my 2012 Trek 7.3 FX I get about 8000 miles on a rear tire and got 22640 miles and 7 years on the factory front tire. Currently have 28000 miles on the bike and am on my 4th rear tire and 2nd front. And I'm probably jinxing myself, but I've only had one flat in all that time.
Jim
jtaylor2 is offline
Likes For jtaylor2:
Old 06-17-21, 02:53 AM
poiuyt
Quoted: 19 Post(s)
Liked 18 Times in 11 Posts
I've different kinds of tires knobby and more gravel oriented, that I'm changing depending on the season (winter is muddier, so knobs are appreciated off road).
Because the rear tire wears faster than the front one, I also swap rear and front when the rear is "half-worn" (using the wear indicators). And then I replace the rear one when it is worn-out (see post below, compelling point). But I only dispose them when they are worn out (wear indicators or too big cracks) or not fit for the purpose — for the knobby ones, though.
poiuyt is offline
Old 06-17-21, 04:45 AM
DorkDisk
Quoted: 576 Post(s)
Liked 1,000 Times in 488 Posts
Replace tires when they wear down, are physically compromised, or are unsuitable for the task.
One quickly notices that the rear tires wear much faster than the fronts. It is important to not rotate tires to compensate for wear, as it is the front that does all the work in braking and steering. A front blowout is way more impactful than a rear blowout. Replace the pair or buy a new front tire and rotate the former front to the rear; you always want the best tire up front.
DorkDisk is offline
Likes For DorkDisk:
Old 06-17-21, 06:17 AM
badger1
badger1's Avatar
Quoted: 1576 Post(s)
Liked 1,181 Times in 601 Posts
This ^^^
Absent obvious damage, my regime is simple: when the wear dots are gone on the rear, I put a new tire up front and move the 'old' front to the rear. Rinse/repeat.
badger1 is online now
Old 06-19-21, 08:00 AM
Helderberg
Helderberg's Avatar
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times in 139 Posts
Jim
Could you share what tire you are using? Sounds like you are getting a good wear rate.
Thanks, Frank.
Helderberg is offline
Old 06-19-21, 04:00 PM
jtaylor2
Quoted: 10 Post(s)
Thanks, Frank.
The bike came with 32mm Bontrager Race All Weather Hard Case which were later discontinued and replaced by the Bontrager AW1 Hard Case. I'm now using the AW1 Hard Case (the regular not the light).
I got 22640 miles on the original Race All Weather Hard Case front tire and replaced it with the Bontrager AW1 Hard Case. The bike now has 28056 miles on it so the AW1 has 5416 miles on it and still going strong.
The original Race All Weather Hard Case was replaced at 7895 miles with the same kind.
The second rear tire was replaced at 15887 miles with 7992 miles on it with a AW1 because original had been discontinued
The third rear tire (the AW1) was replaced at 24872 miles with 8985 miles on it with another AW1
The forth rear tire (AW1) has 3184 miles on it and is still going.
Jim
jtaylor2 is offline
Likes For jtaylor2:
Old 06-19-21, 05:09 PM
Helderberg
Helderberg's Avatar
Quoted: 249 Post(s)
Jim
Much appreciated. Do you feel the ride is hard on your hands or do the sidewalls have some give? Not familiar with the Hardcase tires but am looking to move from my 37 with soft sidewalls. I am also not running tubeless as I am very comfortable with tubes.
Thanks again, Frank.
Old 06-20-21, 05:06 AM
jtaylor2
Quoted: 10 Post(s)
The sidewalls are fairly stiff. That makes them harder to mount then some other tires. I can't really say about the ride being hard or hard on the hands as I have only been riding this one bike and have nothing to compare. I mostly only do 20-25 mile rides and have bar ends for different hand positions so haven't had any hand problems.
Tire pressure makes a big difference in the ride. I don't check tire pressure regularly. I pump them up to 90 pounds when I lub my chain and a few weeks later when I lub again they are down to 60 or 70. The ride is much better at the lower pressure.
​​​​​​​Jim.
jtaylor2 is offline
Likes For jtaylor2:
Old 06-20-21, 06:37 AM
Helderberg
Helderberg's Avatar
Quoted: 249 Post(s)
Jim.
Thank you for the information.
​​​​​​​Be safe, Frank.
Old 06-20-21, 08:46 AM
TakingMyTime
Bikes: Canyon Endurace
Quoted: 1036 Post(s)
Liked 922 Times in 539 Posts
I got 22640 miles on the original Race All Weather Hard Case front tire.
I'm sorry, either I'm reading this wrong or something.... but I'm finding it really hard to believe you got 22620 miles out of a new stock tire even under the best of circumstances. To further clarify, are you saying you got 22620 out of the front and 7895 from the back on the tires that cam with the bike?. I'm sorry but I'm having a hard time swallowing that one.
TakingMyTime is offline
Old 06-20-21, 01:04 PM
jtaylor2
Quoted: 10 Post(s)
That's what I am saying. I keep meticulous maintenance records. Disbelieve what you want, Attached is a PDF of my complete maintenance records of that bike. You can either believe them or not as you see fit.
Jim
File Type: pdf
jtaylor2 is offline
Likes For jtaylor2:
Old 07-03-21, 06:49 AM
BiciMan
Bikes: '97 Bianchi CDI, '97 Specialized RockHopper, '13 Specialized Sirrus Pro, '13 Trek 8.5 DS, '13 BH EasyMotion NeoXtrem, '14 Trek Domane, '86 Schwinn AirDyne ;)
Quoted: 39 Post(s)
Liked 23 Times in 21 Posts
Jim
Damn! Impressive, JT. It WAS hard to believe, though I don't really know what we're talking about, because I keep NO track of mileage and only eyeball-check regularly, especially each spring in my neighborhood, and go by those "data" and the feel of the ride. Geography/weather/climate and where/how you keep and maintain your bike are other variables that can make our experiences, data, and responses differ.
BTW, and speaking of... this is sort of a bump: I have a current question on the Specialized Sirrus thread about how big a tire I can use on my Sirrus -in case you or others have any experience/input on the matter. My original Sirrus tires have plenty of life left, cuz while they are 8 years old, they have relatively low miles on them. Yet, I am thinking of replacing them because my aging joints are thinking cushier rides are good for them. Which is also a way of adding that changing riding habits, and wanting a different ride is the most common reason I've changed tires on three bikes in recent years, though that is only/barely a related point on ps249's original question. Thanks.
BiciMan is offline
Old 08-12-21, 01:05 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times in 55 Posts
I may suggest loosening your elbows.
epnnf is offline
Old 08-13-21, 10:21 AM
whydoibike93
whydoibike93's Avatar
Bikes: 19 pitch,05 7300fx, giant stance 2
Quoted: 23 Post(s)
Liked 13 Times in 9 Posts
when i see threads poking out that's when i change the tire.
whydoibike93 is offline
