For the love of English 3 speeds...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
I found a sun gear with the same wear pattern on
a bike a while back.
Quoted: 457 Post(s)
Liked 462 Times
The hub had some slack in it for sure, somehow this hub with the large diameter left side bearing to accommodate the coaster brake was really tough to get adjusted as I like them and this one was actually looser than I run an AW of mine that has thousands of miles on it.
Quoted: 8 Post(s)
Royal York
Can anyone help with a part source for Sturmey Archer hubs? My hub is an SW and dated 1958.
I am in need of an indicator pin.
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Watch ebay. If I'm not mistaken, the toggle chain/indicator pin assembly is the same as seen in the 4-speed hubs. I like the SW for its range, but its propensity to slip is really annoying. I think if the pawls were made of a better material and modern lubricants used, this might be solvable. If the hub has not seen much use your pawls might be OK. I don't know what might be considered a good lubricant but I would consider some sort of transmission fluid.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Quoted: 457 Post(s)
Liked 462 Times
I've been a huge fan of sturmeys for 30+ years, and I've always run "made in England" ones, but I'm looking at replacing this hub with a brand new one for the sake of reliability, it will certainly take away some of the appeal of the bike for me, but this bike will get ridden long and hard and I just can't get into that mentally if I'm questioning my equipment :-(
Quoted: 359 Post(s)
Liked 265 Times
Likes For Salubrious:
Quoted: 457 Post(s)
Liked 462 Times
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Just picked up a Dutch Gazelle tandem with a Sturmey Archer AB hub from '79 for a mere €55 ($62)
The rear hub needs some work as the 3rd gear works for a short while before suddenly locking up completely. At least I managed to ride it back home at a briskly pace after picking it up 9 km (5.5 miles) away.
In second gear I still managed to propel it to 25-30 kph (15-19 mph) easily on the way home so everything else runs fairly smooth.
Likes For JaccoW:
Quoted: 457 Post(s)
Liked 462 Times
I love that bike!
Likes For jackbombay:
Quoted: 359 Post(s)
Liked 265 Times
That Gazelle looks awesome. But there is quite a but if rust around the rear hub. Looks like you have your work cut out.
I have an 88 Gazelle which uses the Sachs Torpedo 3 speed. The coaster brake was hardly working anymore because of all the hardened grease. I think this hub was never serviced. Opened it cleaned it and re-lubricated it again. Now it works like new.
I have had bikes with Sachs 3 speed hubs since the 70s. I grew in Germany and they were everywhere back then. My favorite is the Sachs/SRAM Spectro 3x7. I have got this hub on 3 bikes. Basically bullet proof. However I had a clutch failure and a flange failure on on one of mine about two years ago. Since the local bike stores rejected to work on the internal gear hubs I decided to learn it myself. These are really no rocket science. So whenever one pops up cheap on ebay I grab it since parts are getting rare.
Likes For Harhir:
Quoted: 457 Post(s)
Liked 462 Times
I decided to go with a new SA 3 speed, was a bit of a tough decision, but there are certainly some benefits to it, I think. I have some arguably stupid rides lined up for this bike and need it to be pretty reliable, hopefully the new S-RC3 will fit the bill for me. I will give riding impressions once its laced up and in the bike :-)
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
This one however is getting a full disassembly first and deep clean in a sonic cleaner. Let's hope the insides aren't too bad otherwise I will have to pick up a replacement hub somewhere.
They are cheap and common around here so that shouldn't be a problem. I had one of those Sachs 3-speed hubs on a Koga-Miyata. Worked pretty well though the brake arm was a bit weird.
Though when looking at an example I came across a set of the modern 5-speed RXL-RD5 and matching 90mm XL-FDD dynohub front and rear hubs, so I might just rebuild the wheels with modern hubs.
But let's just allow the WD-40 to do its work first and take a look at it this weekend.
Liked 443 Times
Never Try...
This bike was originally listed for sale as a 70's Raleigh Sports with an asking price of $200.00
I replied to the seller that the bike was older than he thought and to check the hub for a date.
He's now re listed the bike as a 1958 and after hearing from "a Raleigh Expert" has upped the price
to $500.00!
Another Story
This Superbe was given to a friend's daughter a couple of years ago after her bike was stolen.
She's moved on to another bike and this came back to me.
There's a neighbourhood handy man that needs a bike and
the small frame will suit him.
to $500.00!
Another Story
Yeow! That's some hardcore shredding!
Quoted: 457 Post(s)
Liked 462 Times
I'm feeling pretty tough right now, outside of a city I'm sure I could put down a sub 6 hour solo century as long as it didn't have a ton of climbing, and a week ago I went out with plans to ride this hub/bike 50 miles and I went so hard for 2 hours (in a city, lot of stops wrecking average speed) that I had to call it quits at 36 miles, considering how easily I've been blowing down centuries lately it took some pretty serious self abuse to empty the tank in 2 hours. Its kind of a bucket list item though, "Blew up NOS sturmey hub in 350 miles." Although this one does have a weak 3rd according to Sheldon Brown, I don't think its possible for a guy to my size (164 pounds currently) to blow up an AW with the 46/20 gearing that I'm running.
Liked 443 Times
here's my mangled sun gear...
this came out of a 1972 hub....
Quoted: 359 Post(s)
Liked 265 Times
Liked 443 Times
This one came to me with a very tight hub that wouldn't shift.
The standard adjusting/flushing methods didn't work and I opened it
up to find the sun gear ground down to almost nothing.
The rest of the hub seamed fine.....
Quoted: 359 Post(s)
Liked 265 Times
You never know how a 50 year old bike has been treated over the years.
Liked 443 Times
That was my thought.
I've seen lots of dirty, rusty, gunky hubs but never damage
like this example.
Also, it wasn't a sudden failure.
It's possible that one spline could fail.
This shows a consistent and uniform wear pattern.
over a course of time.
like this example.
Quoted: 457 Post(s)
Liked 462 Times
Huh I've opened up half a dozen or so AW hubs, but have never seen any appreciable wear on any part inside the hub, odd that this sun gear was seemingly worn away. The teeth on my sun gear were broken off, and the sun gear on this S3C hub is part of the axle.
I did get a brand new SRC3 (II) hub today, I'm excited to get it laced up and ride it, but I also feel like a bit of a traitor what with this not being made in England, and now the bike lost it's oldest part. The frame is from 1988 so I will still be able to pot about this bike on the C&V page, but maybe not in this thread?? ;-)
Liked 443 Times
NASA has several test papers on sun gear failures due to poor lubrication.
https://ntrs.nasa.gov/archive/nasa/c...9920021153.pdf
Quoted: 457 Post(s)
Liked 462 Times
