Serotta Colorado BB width?
Quoted: 601 Post(s)
Liked 781 Times
Im building up a Serotta Colorado Legend TG frame and not sure what size 102mm vs 111mm is needed?
I want to use a Campy Record BB like below:
Campagnolo Record BB 111mm Bottom Bracket Square Taper English Thread
Im pretty sure Serotta take a English Threaded BB, maybe they are all 102mm?
These are also square taper BB and this will fit the CR crank that I have for this bike.
Guess a Chorus model would also be fine, is there really that much of a diff?
TIA
Joe
TIA
Joe
Quoted: 1821 Post(s)
Liked 1,696 Times
The length of spindle you need is determined by the crank, not your frame. Your bike almost certainly has a 68mm bottom bracket shell, English threaded. Which exact crank are you planning on using?
The earlier Campagnolo Record cranks use a longer bottom bracket spindle than the later ones. You have to match the bottom bracket spindle length to the version of the crank you are going to use
Licensed Bike Geek
Serotta has a 68mm bottom bracket shell width and is standard British threaded.
As stated above, the crankset will determine which bottom bracket you’ll use.
Quoted: 601 Post(s)
Liked 781 Times
BTW, the BB shown is what I need and what did not come with my purchase. Buyer has no clue what happened to it
Likes For alcjphil:
Quoted: 601 Post(s)
Liked 781 Times
Thanks!
mikemowbz
Classic and Vintage Sales
5
07-12-19 11:09 PM
tigerteeuwen
Bicycle Mechanics
12
08-12-13 08:41 PM
