Mystery bike
Quoted: 4414 Post(s)
Liked 4,867 Times
A blank sheet?
RIDE OR DIE
Bikes: trying to find out what i got
damn it isnt letting me up load i have to post so many times because im a new member
RIDE OR DIE
Mystery bike
I have a bike and i dont know what it is. I have searched the web. I was wondering if i could pick the brains off one of yall so I could see if you could help me
Quoted: 3814 Post(s)
Liked 3,345 Times
if you have or can make some photos of the bicycle you can post them to the album on your member page - there is a button on the right of your member page for "member album"
no minimum number of posts is required to create your member album
readers can then visit your album and insert the images into the discussion thread
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Looks like a steel-frame hybrid, partly stripped, and running as a single-speed.
Could also be a single-speed ’city bike’ from one of those lifestyle brands like PureFix or Retrospec.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
If you are interested in the forums you will get up to the post amount easily. If you don't like bikes and talking about bikes, you might consider google image search or something like that but if you like bikes, welcome get involved with the many current and active threads going on in the various subforums that can be quite interesting and then post your pictures and whatever useful info.
Quoted: 7652 Post(s)
Liked 3,478 Times
There might be more info on the frame, stamped into it perhaps ... look under the bottom bracket and at the bottom front of the seat tube, perhaps.
To me it looks sort of like a mid-'8s to mid-'90s rigid MTB which someone has converted to SS
Liked 3,478 Times
The real issues .... what are the bottom-bracket and headset dimensions, what is the rear dropout spacing. It could be 130 or 126 or 135 .... depends how old it is and whether the previous owner messed with it to convert it. Looks like a 3-piece BB/crank maybe .... (not very good pics but I am sure you did your best. Try more light.) If the headset and cranks bearings are okay ... great,. If not it probably takes any generic threaded BB (Unless it is French, or Italian, or Raleigh) but .... whether it is 68 mm or 73 mm matters (and a ruler can tell you that.)
What do you want to do with it?
RIDE OR DIE
I want to make it look like it did when it was built. I want to get all of the original peices.
Quoted: 4722 Post(s)
Liked 3,038 Times
The photos are very poor but it appears to be some relatively modern, entry level, city bicycle. The brazed-on seat post collar is typical of low end models, as are the rear brake cable stops on the underside of the top tube. It's equipped with U-brakes which, in conjuction with the aparent frame level, should put it into this century. The crankset looks like it may be a Shimano Tourney from earlier this century. Given your location, it's likely some UK chain store brand with which I'm not familar. Better photos may help.
Likes For T-Mar:
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Merged duplicate thread. Please do not cross post.
