Low rent lemond tourmalet
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I got this cheap and I rode it a bit with drop bars. I always forget how bad my arthritis is until I try another drop bar bike. Anyway this bike is Reynolds 525 welded with the rsx 8 speed group so nothing special. I managed to resurrect the right brifter but the left one refuses to operate correctly. Since I choose to use chainrings it or it's front mech are not compatible with I decided a suntour bar end would suffice. The new(ancient) chainrings have no ramps or pins but are way lighter than the steel rsx rings. 26-39-42 for a half step and granny on a 12-34 cassette. The fenders barely fit over 28s, but they do fit with judicious use of zip ties. The seat is a Persons majestic I scored for ten bucks. I may not be very aero on this but it's a fun ride.
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
Likes For jdawginsc:
ambulatory senior
Liked 3,661 Times
Quoted: 3814 Post(s)
Liked 3,345 Times
what function being performed by the zip tie rope running over the seat binder
ambulatory senior
Liked 3,661 Times
Likes For 52telecaster:
Likes For robobike316:
ambulatory senior
Liked 3,661 Times
Thanks, it looks we have tried the same things, upside down Mustachios, Porteurs... I still can't find the right 23.8 upright bar with a decent rise. The Porteurs are too narrow and don't rise enough. The upside down mustache gives good rise but puts the angles in a bad place. They sweep up instead of down or neutral which I told myself was fine for years but never believed myself. You have some nice bikes! How's your half step setup working out? I've been thinking about doing a 39-44 on a 5spd. 14-34 which probably works out to close to what you have although I haven't run the numbers.
ambulatory senior
Liked 3,661 Times
Sounds like you have partaken of the half step Kool-Aid! I am soon to join the cult if I can find and old TA 44 outer.
Liked 3,345 Times
the look of this arrangement of tie wraps connected to form a "rope" of sorts reminds me of all those movies where someone is shown to escape from a high window by tying together bed sheets...
in The Towering Inferno Lorne Green tells all of the ladies to remove their pantyhose so the hosiery can be used to form and escape rope
Likes For juvela:
ambulatory senior
Liked 3,661 Times
ambulatory senior
Liked 3,661 Times
On my main touring bike, the gugified austro Daimler, I use a t.a. 44 outer. It really works well as a top touring ring. On a loaded trip I never reach high speeds unless I'm going downhill. That bike isn't half step but half step is fun. Peter White cycles has a big selection of those chainrings, but they aren't cheap.
Quoted: 2483 Post(s)
Liked 2,955 Times
As to the handlebar configuration: I replaced the stock bar and stem on that hybrid with the riser bar and stem from my retired 1986 Cannondale SM500 mountain bike and added a clamp-on aero bar and fenders. Shopping bike and bad-weather training bike. Works for me.
Likes For Trakhak:
ambulatory senior
Liked 3,661 Times
Every time I ride for any significant distance on my 1995 Cannondale H300 hybrid with its half-step-plus-granny setup, I'm reminded again how imbecilic the gearing arrangements on my other geared bikes are in comparison.
Cantilever believer
Quoted: 536 Post(s)
Liked 1,838 Times
Re RSX: Two of the most stubborn brifters I've degunked were 2 x 7 RSXes. I lost count of the number of passes in the ultrasonic cleaner before I finally got a single "click" out of each of them. But after patience, perseverance, and a whole lot of buzzing, they finally came clean and are put away for a future project.
Likes For RCMoeur:
ambulatory senior
Liked 3,661 Times
Half-step: Big jumps on the right, little jumps on the left. Easy. I used it for decades until 2-tooth-jump 7 speed freewheels and cassettes became a commodity. Still have it on my recumbent (41-38-24, 14-17-20-24-28-32).
Recovering Bikeaholic
Jones Bar?
Yours is a beautiful looking build...I dig the (mutant) shifter/brake combo... (cooler than you think?). I just love the look and the ride of the Lemond steel frame sets.... I have a (2002?) green and white Alpe d'huez... may one day convert it into an upright rider like yours. Keeper.
Likes For montclairbobbyb:
