Grail bike: CO-MOTION experts help with model choice…
No Pain, No Pizza
Bikes: 2015 Tarmac Pro Disc, '99 Burley Duet, '10 Velo Vie Vitesse 300R, '94 Trek 2120, '90 Cannondale SR 600, '79 Ross Super Gran Tour, '76 Raleigh Record
Quoted: 31 Post(s)
Liked 40 Times
I can finally afford my grail bike, trouble is I don’t exactly know what it is. I want one bike with a Pinion gearbox, that will be used mainly for weekly, round trip commute 46 miles with seasonal snow and ice on 3 mile section with 7-15% grade, total commute with 3,600’ elevation gain; as well as weekend rides with lots of climbing, road and gravel. But will also be using for annual protracted bike tours in US & Europe, but not planning on technical trails. I have gotten by commuting when the roads are clear with a Specialized Tarmac, which I love, but has poor clearance so I can’t put studded snow tires on it, nor could I tour with it. So I’m considering the CO-MOTION “Divide” with P18 Pinion gearbox. But there are other CO-MOTION choices as well. Not sure about BEST wheel size, frame dimensions, etc. I am 6’1”, 225 lbs.
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,845 Times
I can finally afford my grail bike, trouble is I don't exactly know what it is!
Oh well, .....it's called =
back to the drawing board
loop back to Step 1
evaluate before test & repeat
who's in charge of the design dept?
BTW, I really like my custom Co-Mo tandem.
edit: A basic question to be answered when describing a 'do-it-all' bike is, How gravelly is the gravel? Determines tire width (and other stuff). Also, for 6'1" humans the wheel size for best tire selection is 700c, 622. But I've never checked studded.
loop back to Step 1
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Originally Posted by KerryIrons;[url=tel:23091744
23091744[/url]]Why do you want a pinion gearbox? The mechanical efficiency of pinion gears is significantly lower than chain drive. It seems to me you are needlessly constraining your choice due to focus on that one thing.
Likes For Thigh Master:
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Originally Posted by Wildwood;[url=tel:23091759
23091759[/url]]A basic question to be answered when describing a 'do-it-all' bike is, How gravelly is the gravel? Determines tire width (and other stuff). Also, for 6'1" humans the wheel size for best tire selection is 700c, 622. But I've never checked studded.
Clark W. Griswold
Quoted: 4365 Post(s)
Liked 4,006 Times
I would go Divide though I like wider tire clearance. I have a Cascadia, I am quite happy with but a Pinion would be neat to try and have been looking into it.
The one thing I will say is get the Pathfinder package for sure and I would also get the stainless dropouts stupidly I did neither of these and wish I had though I did end up adding a dynamo later and drilling myself and all of that but would have been easier just to get it from them though I built mine from the frame up. The stainless dropouts aren't a huge deal but would have looked nicer and made sense for what I was building. Though I guess now the price of the dropouts has gone up but I have had mine for 11 years or so, so I am not surprised.
Really take some time build out what you want, maybe contact them and talk with them as well. They have been quite friendly to me and very helpful and the bike has been fantastic.
I kind of rushed my build slightly and am now regretting a few decisions as you can see above but I can attribute that to not knowing as much as I do now and having differing opinions.
Likes For veganbikes:
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Oh great info, thank you! I have the Pathfinder option on my list. What’s the big deal about the stainless dropouts anyway? I think they are standard with the Pinion option but I don’t understand the advantage. Please feel free to let me know wnat you learned in hindsight.
Quoted: 626 Post(s)
Liked 401 Times
Likes For Rick:
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Awesome advice. Thanks. Hadn’t considered that rotor size might be limited. Was just gonna go for the biggest rings that would work.
Quoted: 626 Post(s)
Liked 401 Times
I purchased the SS couplers, the SS dropouts, the raised headtube and the Pathfinder package. I stipulated the Son SL dino hub model so I don't need to unplug the wires when taking out the front wheel. Co-Motion didn't charge much more for the machining of the right fork dropout. I also paid for additional brazons on the fork. I spoke to Co-Motion and they didn't like the wire running inside the fork blade. A hole allowing water to pool in the bottom of the tube was a concern and I agreed with them. A taillight wasn't included in the package.
Likes For Rick:
Clark W. Griswold
Liked 4,006 Times
In terms of the stainless dropouts NO NEED FOR PAINT. My paint got a little flaky at the drop outs from removing the wheel to replace flats and general maintenance and such. I also think they look good and may also be a touch stronger but it was mainly the paint chipping and just the general look of them.
I learned that I love wider tires (at the time my thought was 35 was the max I ever needed and skinny tires were the best, oy was I wrong) I also learned I liked dynamos and now have realized I wouldn't mind thru-axles on my touring bike and a 3x9 is fine but for my touring 2x11 might be the jam. Also found that Dura Ace shifters are fine but I should have just gone with the Microshift that fits on the Gevenalle levers a bit better. Also square taper is not as needed and I would be fine with HTII style cranks easier to deal with (though in the past I was quite the staunch defender of square taper) Also some new parts have come out that I love but nothing crazy and I found love for an older part that I wish I had used on the build instead of the current XT 9 speed derailleur but not a huge deal or deal breaker it just doesn't have the barrel adjuster at the derailleur which is kind of nice I have found.
Also one final little thing is Koga Denham style bars are great and maybe I don't need drop bars for touring? But I do still like drop bars and the Koga Denham bars aren't quite perfect and the new version of the Velo Orange Crazy Bars improve some things from the Denhams and also ruin somethings maybe slightly. I mean I would love to have someone build a perfect set of bars for me but I don't know if that is really practical and won't be cheap and what I am using in all three drops (in particular Zipp Service Course SL-70 Ergos) and the two alt bars (Denhams, a V2 Crazy Bars and I guess Molokos as well come to think of it so three alt bars) are all quite good and no real major complaints. I guess I am wishy washy a little here on those I guess if I ran Pinion or Rohloff I would want alt bars as the drop bar converters are just not what I want and the sram style ones aren't it either.
All in all the build is great and I like Co-Motion. I just am building better bikes for me with more knowledge and time in the industry under my belt.
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Love the thoughts on tires. I’ve never gone larger than 28c on my Tarmac. Had a 35c on the tandem rear end.
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
No rear dyno light eh? And mmmm, extra brazons. That’s very intriguing. I’m not accustomed to ordering a custom bike. What else can I dial in? Hmm.
One advantage of the Pinion will be no dish on the rear wheel. At 225, you might appreciate the theoretical increase in strength. The P18 has an impressive range you will appreciate on that steep section.
Of course, if you can afford your 'Grail Bike' you might be able to afford your 'Grail Quiver.' Just trying to cause trouble.
Likes For Pratt:
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Clark W. Griswold
Liked 4,006 Times
With a custom bike you can dial in whatever you desire up until the limits of the frame builders skills or the materials properties. You can go as wild or mild as you want with everything. If you get a fit and tell the fitter what you want you can send that info directly to Co-Motion or whomever is building your frame and say this is what I want and they can generally do it or can recommend someone who can. Lennard Zinn who writes for VeloNews and his own books and also runs Zinn Cycles built a custom titanium banana seat bike (the seat was carbon) with SRAM Red for a customer who had some health/body issues but wanted to still do triathlons. Unfortunately I was dumb as a sack of bricks and didn't save those pictures of it and cannot find it again but it was a truly neat unique bike. Point is you get the right builder they can build basically whatever you want. Heck Surly has braze-ons all over their bikes you could cover it in as many zits as you wanted. You want a 690mm top tube go for it.
I have a rear dynamo on everything that has a dynamo in my fleet aside from an e-bike I am building but that has lights plugged into the system. The dynamo is so I can run the front light I want and two rear lights/radar without overloading the system with powerful lights now that Supernova has the M99 Dynamo front light. The previous owner of the bike and the shop I worked at had two front lights I wanted two rear lights and I may add a lower power front light in the system and have the more powerful one be the dynamo light.
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Originally Posted by veganbikes;[url=tel:23092963
23092963[/url]]Thanks, I love big tires and I cannot lie! I want a road bike that is running 30 or 32mm now and my new gravel bike is running 650bx48s and would happily run wider if they would have fit but 48 is the widest they recommend going and I want some clearance for fenders and mud. There are very few drawbacks to wider tires up to a point for most road applications you cannot go too wide. Once you start getting into fat bikes then yes but that is a special thing.
Clark W. Griswold
Liked 4,006 Times
Those are wonderful insights. I will check with co-motion about what it would take to dyno rear as well. I am familiar with Mr. Zinn, we have mutual close friends in Boulder. I know him but he doesn’t know me! Apparently after his arrhythmia episode he must use an e-bike to get around with his old gang in order to keep his heart rate down. So he is designing e-bikes as well now.
Yes he is. He is working with Schwift/Vapor Propulsion Labs to make them and Zach who runs that is really a fantastic guy. He couldn't build my dream bike but I was asking something of the materials that just isn't possible but had a solution that I may bring to him and a non-bicycle titanium fabricator to see if they can replicate it but honestly not a need anymore as I got the same basic bike in aluminum and with the massive 140mm fork and wide tires and the stiffness added with the batteries the actual ti properties would be kind of negated but would still be neat.
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Originally Posted by veganbikes;[url=tel:23093091
23093091[/url]]If you want a rear dynamo you just need a rack at the back, I recommend some variation on a Tubus rack and the Busch and Müller Toplight Line Plus Brake (or whatever combination of words it is) however if you want a more minimalist light the SON rear light would work well. I don't recall if the package comes with a rear light or not I had bought some other stuff from them and asked for a hub because Peter White was out of stock or something odd I cannot recall.
Quoted: 626 Post(s)
Liked 401 Times
Does the rear light power come from the front dyno as well or is a rear hub dyno also required?
Likes For Rick:
Clark W. Griswold
Liked 4,006 Times
Nope all from the front hub or just from the front light in some cases (typically it is wired into the light). I haven't seen any rear hub dynamos that I can think of at least nothing in recent design. I feel like maybe there was something vintage but I could just be imagining it.
No Pain, No Pizza
Quoted: 31 Post(s)
Liked 40 Times
Originally Posted by Rick;[url=tel:23093346
23093346[/url]]Co-Motion sales the Edelux II headlight and the Sun 28 dino hub with there pathfinder package. I purchased the Busch & Müller Toplight Line Plus Brake Tail Light. It plugs into the headlight. You also need the wiring harness for it.
Quoted: 4806 Post(s)
Liked 3,933 Times
Chrome dropouts - visually nice but absolutely not necessary. I've been riding a very long time and have owned bikes and ridden them year round in Massachusetts, Michigan, Washington and Oregon, never wiping bikes dry after riding and never having any issues with dropouts other than the paint ships early on and that small part of the bike looks bad. Also chrome is very hard. Considerably more clamping force is needed to secure the rear wheel. (Rarely an issue, but it is a fact.)
I currently have a bike with chromed dropouts but it's the first in my half century plus of riding. I have no issue with the chromed dropouts other than I have to remember to set QRs tighter. If this bike is thru-axle, I suppose no diff.
Likes For 79pmooney:
Quoted: 626 Post(s)
Liked 401 Times
Likes For Rick:
This may be redundant, but here goes: I went into my Gunnar with data from a medical professional's fitting on a previous bike. Vecchio’s incorporated that into their fitting decisions, along with what they saw on their fitting stand. As a result I have the most comfortable bike I’ve ever ridden. Everything else about the Gunnar is stellar, but the fit is the thing that I notice the most.
Likes For randallr:
