68 vs. 68/73
Bikes: SS Surly Crosscheck; '91 Cannondale 3.0
68 vs. 68/73
So, I need a new BB and I found a great deal on one from an online shop that has everything else I need at a great price. But, the spindle length I need is 113 and the BB with that spindle length is stated as a 68/73 instead of just 68 like the 108 sl is. What the heck does 68/73 mean and will it work?
BTW, I have a Cannondale 3.0 with Suntour GPX cranks, so if anyone can correct me on the spindle length I would appreciate that, too. This was what my mechanic said, but he's messed up before (always paid for it himself, though).
Thanks
Thanks
is slower than you
Bikes: Gunnar Sport, Marin Pine Mountain, Gunnar Ruffian, Gunnar Roadie, BMC Fourstroke, Salsa Vaya
Thanks
Thanks
So, if your frame has a 68mm bottom bracket shell then yes, the 68/73 will work. You'll just have to use the spacer.
more spin, less brake
68/73 means the bottom bracket will work in both 68mm and 73mm bottom bracket shells. If the frame's BB shell is 73mm, you use the bottom bracket alone. If the frame has a 68mm BB shell, then you use a spacer along with the BB (the spacer is typically provided).
I'm just quoting for reference. If anyone can help, please do.
is slower than you
Check the internet for the tech documents of the BB you're using. Most manufacturers have these instructions available for download (or just RTFM if that's handy).
Proud supporter of the Chippewa Off-Road Bike Association (CORBA)
www.chippewaoffroad.org
