Top pull front derailleur
Old 10-19-10, 07:36 PM
Captain Jake
Devil's Advocate
Bikes: Sterling Road bike, Chromolly Specialized Allez, Bianchi was given to me don't know model
Does a top pull road derailleur exist, and if not why not? My Zydeco runs the cables on the top tube and the front derailleur cable has to go around a goofy wheel fastened to the seat tube to work with the front derailleur, and I know Cinelli isn't the only company running the cables on the top tube, it seems like it would make more sense for some company to make a top pull front derailleur.
Captain Jake is offline
Old 10-19-10, 07:47 PM
mzeffex
mzeffex's Avatar
Bikes: Something Canadian, something Italian, something American, and something German
Quoted: 64 Post(s)
Liked 16 Times in 10 Posts
Nope.
Originally Posted by rjones28
Are they talking about spectators feeding the cyclists? You know, like don't feed the bears?
mzeffex is offline
Old 10-20-10, 06:54 AM
crocodilefundy
if you run small enough rings you might be able to use a mountain one. you can hit well over 30mph with a 44:11 so you'd be fine with the smaller rings.
crocodilefundy is offline
Old 10-20-10, 10:49 AM
SpongeDad
Overacting because I can
SpongeDad's Avatar
Bikes: Merlin Agilis, Trek 1500
Would be nice - the pully is a magnet for mud and grass and can interfere with a bigger tire if you're not careful.
There's lots of things I'm hoping the growth of cross will bring. Top pull cross specific derailleurs and matched Shimano 46/36 rings are at the top of my list.
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
SpongeDad is offline
Old 10-20-10, 04:09 PM
Captain Jake
Devil's Advocate
I'm alright using the goofy seat tube wheel, I just feel like there should be a top pull road derailleur available so we aren't stuck running cables on the downtube or configuring some weird setup to turn the top tube cable routing into a bottom pull.
Old 10-20-10, 11:48 PM
RussellRides
RussellRides's Avatar
Bikes: 2009 Blue RC8, 2011 Blue Norcross SL
Not so Fast! My new Blue Norcross SL has top tube cable routing and a standard SRAM Force front derailleur. Works like it was designed that way.
How? It came with an add-on lever by Speen Umlenker. You can order these direct from Germany, they'll ship to the US and accept paypal.
https://www.speen.de/speen*_en/products.html
Good Luck.
RussellRides is offline
Old 10-21-10, 04:18 PM
Captain Jake
Devil's Advocate
Good Luck.
Thanks I don't know that I need one but that is a really cool solution to the issue.
trail_monkey
Bicycle Mechanics
0
09-09-18 01:03 PM
minicoopers05
Bicycle Mechanics
1
12-22-13 09:00 AM
bluenote157
0
09-01-12 10:45 AM
bluenote157
Framebuilders
1
09-01-12 10:41 AM
jmeans53
Bicycle Mechanics
9
08-22-10 08:19 PM
