Got a Gravel bike on a C&V frame?
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
I'm not really sure I buy into the whole gravel bike craze but it sure is popular these days and seems like anyone on road bikes are changing over to gravel bikes. I just can't imagine spending another 3 grand on a road bike with a thicker wheel and tire to ride around on crush gravel paths? If you had a nice, carbon mountain bike, wouldn't you just take that out to ride with your gravel bike friends? Will they eventually put suspension on gravel bikes to hit some trails?
I'm thinking you could take a nice steel frame, road or mountain bike and turn it into a decent gravel bike for a lot less than 3 grand so show me what you got.
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
My Eisentraut Limited currently sports 32mm smooth tread Gravel Kings. I've ridden it on the Des Plaines River Trail a couple times this year with no particular problem (one tumble, but I chalk that up to pilot error). I think I could fit 35s with a more aggressive tread. That's probably all I need. In general, I think most production road bikes made before the late 70s probably have clearance for 32s, if not wider.
Maybe there's a difference I'm missing, but are modern gravel bikes all that different than modern cyclocross bikes?
Usually, vintage 70s racing frames can handle a 32. There are some exceptions. Pretty much all of the classic 70s and 80s touring frames can as well. No problems for me riding gravel on these types of bikes.
I'd reckon I've put more gravel miles on my old 70s Masi than most official gravel bike riders have put on their gravel bikes.
Likes For Salamandrine:
Quoted: 5888 Post(s)
Liked 3,471 Times
There is a whole thread devoted to drop bar MTBs any one of which would make a fine gravel bike on the cheap.
https://www.bikeforums.net/classic-v...nversions.html
Cheap and easy? Take a vintage MTB and run a set of trekking bars:
Or you could do a 650b conversion:
Or you could as fat a tire as you can stuff in a vintage bike. Most will top out at 35c.
https://www.bikeforums.net/classic-v...tage-bike.html
Or you can find a bike that was designed to be a road bike for bad roads. Some of the bridgestone XO series were designed to be "fire" road bikes, road geometry plus 26 inch tires. Back in the early 90s, 26 inch made a lot of sense if you wanted to run a wider tire. This is my XO 2.
Likes For bikemig:
Quoted: 1609 Post(s)
Liked 2,590 Times
Started a while back, but the parts went on another project. Miyata 618
Likes For curbtender:
Quoted: 170 Post(s)
Liked 264 Times
Miyata Sportcross
Likes For ctak:
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Eventually? They already have...
Quoted: 3015 Post(s)
Liked 3,802 Times
Likes For iab:
Quoted: 823 Post(s)
Liked 1,395 Times
This is my purpose-built all-road bike, a 1973 Raleigh Competition running a Surly Dingle 17/19T fixed cog with 42/44T chainrings, so I get a 70-in pavement and a 60-in gravel fixed gear. Someday I'll spend the money for a White Industries Dos Eno 20/22T freewheel for the flop side of the hub, giving me 60-in road-ish and 52-in single-track-ish freewheel gears. The tires are 35 mm Continental Cyclocross Speeds.
But honestly, I've ridden most of the fire and dirt and gravel roads in this part of South Carolina with 26-28 mm tires on this Mercian fixed-gear. Not too much of a handicap, really.
Likes For rustystrings61:
Quoted: 3810 Post(s)
Liked 6,699 Times
As noted previously, you can often convert vintage frame to 650b x 38mm wheels, and have at those gravel roads. Here’s my Holdsworth Special:
Likes For nlerner:
Furthermore, serious consideration needs to be paid to what's actually being expected of different bicycles being ridden by different riders from different areas. A road bike that can just squeeze 32mm tires is sometimes a fantastic candidate for a "gravel" bike in an area where the gravel is all well-maintained hardpack, but may be a very poor choice for other situations. There's a lot of "it depends" here.
Likes For HTupolev:
Quoted: 548 Post(s)
Liked 473 Times
All great options here and I was thinking of maybe getting a 90's mountain bike like bikemig's Trek above and using that with a tour tire instead of mtb bike tire. I actually have a Trek Antelope 800 that I use as a grocery getter. I think all of your bikes look nicer than what they are offering as gravel bikes in the shops now.
I don't know if this qualifies as a gravel bike or not, but it was done on the cheap............like zero dollars cheap. I picked this up last Fall during community clean up days and was inspired by the Covid Challenge here on C&V to get it ride worthy. I did not do the ride part of the challenge. The bike is currently being used for gravel and rail trail paths. A bit on the heavy side but it gets the job done.
Be where your feet are.......Lisa Bluder
Likes For r0ckh0und:
I brushed on a fun paint job and some wider Kenda tires on my Mercier. Still putting back together. Looks like a gravel bike to me. Still trying to find some gravel to ride on. I do have the Green Bay trail, but its crushed limestone and pretty much dead flat. Going to have to put fenders in soon with the wet weather approaching.
Likes For big chainring:
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I never thought of it as a gravel bike, but I could put some pretty knobby tires on the CERA now that it fits 26" wheels.
I don't have any bikes that I'm not willing to ride on gravel.
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
Quoted: 821 Post(s)
Liked 255 Times
All of these are fine on Class five.
More tire is preferred if on sand and loose river rock.
Nothing worse than a road grader "improving" roads right before we get there.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
This one (88 RockHopper) goes great on road, crushed stone trails and actual gravel roads.
This one (85 Schwinn Sprint) is great on roads and on crushed stone trails when they are reasonably dry and firm. I don’t take it on real gravel because I have the RockHopper.
And that’s it. No bikes that can’t at least tackle crushed stone trails.
Oh, I’ve run them both with drop bars, but running SS, I prefer these touring bars that offer more versatile positions to ride while standing.
Otto
Otto
I found this 1973 Cinelli Speciale Corsa on Kijiji a few years ago and it was in rough shape, having spent the previous 6 years leaning against a shed in Sudbury, Ontario (yes, including winters). I ride a 58cm frame and this thing is huge, a 61cm but I figured I could rescue it and find some sort of use for it.
It sat for many years inside my own shed and then I had the idea to make a French-fit gravel grinder out of it. Still a work in progress, as you can see, but those are 32mm Gravel King slicks on there and they feel great on the road.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
Welcome to my nightmare, my French Fit Gravel Bike.Not very C or V, unfortunately. A little flexy, but very stable at high speeds, nice handling, springs right over bumps, those fork tips dance like crazy.
Running some very tough Conti City Ride 32's, for goathead season.
Likes For Lemond1985:
Quoted: 964 Post(s)
Liked 1,451 Times
C&V gravel? Heh, it's the only thing I do! René Hubris builds.
Nishiki Sport, 700x35 Gravelkings, 1x7, under 25lbs and under $300, using BOC parts!
Lent my friend an issue of Bicycle Quarterly, which started her lusting after a Moots Routt, but her budget was only 1/10 the price. I told her this was the closest we'd get - and I think I'm right.
Panasonic Touring Deluxe, to which a few braze-ons were added. Gravelking 38s fit perfectly.
Univega Specialissima, budget build for Gravelking 700x38 and rinko using foundling oddball but top-shelf parts, for a friend who lives on a gravel road in Vermont, in order to convince him to start cycling, since he lives in gravel mecca! The gravel tires fit, just barely!
Extreme budget parts bin build Univega Gran Turismo. Everything on here was a reject from some other build. Even the spokes on that 27" dynamo front. Eats gravel for lunch with those fat Schwalbes.
Ron Cooper, outfitted with the Compass Barlow Pass tires and rather clunky but extremely nice Rivendell racks:
Trek 61x from 1983. Fast and supple with Pari-Moto 650x42s, this thing rips up doubletrack from the NEK to the Cape. Pretty involved build, adding canti posts and other doodads, and re-raking the fork. But it's an easy rinko, super fast, pretty light, and very durable. Did my first two centuries down the cape on this bike after building it. Was easy enough on me to go explore the lovely gravel around Truro the next day after each.
Likes For scarlson:
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
35s fit on this 1966 Frejus.
Likes For Choke:
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
And why must $3000 be spent? Why not $2200? Why not $900?
- I've never found a mountain bike that fits comfortably enough to ride fast for a couple hours straight on the short side of ride length.
- I have 0 interest in riding a flat bar for a couple hours straight on the short side of ride length.
- Full suspension sounds completely miserable for a 40mi gravel road ride. It is massive overkill.
You created some easily defeated positons then knocked em down. Strong work.***
My first gravel bike was an early 90s Univega Via Activa hybrid that was converted to drop bars with bar end shifters, 40mm tires, and stock 3x7 gearing. It was a blast for getting started but had limitations for what I wanted.
My second gravel bike was a Black Mountain MC steel frame and fork with modern 2x11 drivetrain and canti brakes. It was an incredible bike and the frame is now set up for commute/touring, but I wanted to try some new things.
My current gravel bike is a Fairlight Secan 853 steel frame with carbon fork. 44mm head tube, tapered steerer, 2x11 shifting with hydraulic disc brakes, and thru axles. Its simply been incredible.
My gravel bikes have cost more each time, but each time they have been better for what i want. None have cost $3000.
https://www.giant-bicycles.com/us/re...dvanced-2-2021
$2500 gets you a carbon frame and fork, 2x11 hydraulic disc shifting, flared bars, thru axles, and good general gear range.
No idea why $3K is the price you set.
Why not reference this for $800? https://www.statebicycle.com/collect...-tan-650b-700c
Cost $285
Cost $1400
Cost $2350
Sunshine
Liked 7,490 Times
Quoted: 838 Post(s)
Liked 1,082 Times
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
I ride a 73 Raleigh SuperCourse in the states, running a re-dished 7 speed hub and a 2 speed 17-21 freewheel and a 46x42 set of chainrings making it a dingle speed.
Here in Cambodia I ride just about anything I have including a Centurion Pro-tour, a 2012 Fuji steel Stratos, along with a couple of other bikes including a modified Hybrid.
