Upgrading Peugeot U018 Shift Levers
Bikes: Miyata 710, Univega Viva Sport, Centurion LeMans, Peugeot U09
Quoted: 212 Post(s)
Liked 111 Times
I have been upgrading my wife's U018. So far I replaced the steel rims, stem and handlebars. This winter I am looking at replacing the shifting system, both the levers and derailleurs. I assume the first step is getting rid of the drive side boss on the downtube. Anyone done this? Hacksaw?? Suggestions appreciated.
Quoted: 478 Post(s)
Liked 634 Times
Why not leave the boss there and either put a bell or a decorative cover on it, or just leave it plain? The bike is in nice shape and a jagged rough spot with paint that doesn't quite match will surely look worse than leaving the boss.
Quoted: 212 Post(s)
Liked 111 Times
If you think brifters (brake levers with integrated shift levers) you don't want to get rid of those downtube shifter tabs. They are useful and built-to-purpose places to hang your cable stops (with barrel adjusters). This way there's no need to do full length cable outers, just from handlebars to those stops.
Quoted: 212 Post(s)
Liked 111 Times
Worth considering. But I'm sure I can do better than a jagged rough spot. Also, won't the new clamp-on.shift levers cover that?
Curiosity got me - you are sticking to downtube levers and simultaneously considering getting rid of downtube boss(es) for said levers? What exactly do you mean with new clamp-on shift levers? Stem mounted levers?
Quoted: 212 Post(s)
Liked 111 Times
The Peugeot has a unique system where there is a boss only on the drive side. This is set up to work with their Prestige plastic levers which are flimsy and prone to breakage. I plan to use a pair of clamp-on levers on the downtube. But the drive side boss will be removed first. You could leave it there but it isn't my preference.
Likes For kross57:
Bikes: Still have a few left!
Quoted: 466 Post(s)
Liked 527 Times
Many vintage frames had a stop brazed on their down tube to prevent lever clamp movement downwards.. But, it's your bike, and not rare at all, so your choice. Don
Quoted: 478 Post(s)
Liked 634 Times
Quoted: 212 Post(s)
Liked 111 Times
I have successfully mounted both cable bosses and alternative shift levers to the original Simplex clamp on band, so since you are retaining downtube shifters why not go route of least destruction and try to find replacement levers first. There are a variety of Simplex all alloy levers available.
Quoted: 478 Post(s)
Liked 634 Times
Those look great and appear to be designed to fit that square boss.....hopefully not to expensive!
Here are a couple of Simplex alternatives:
https://www.ebay.com/itm/203110950475
https://www.ebay.com/itm/vintage-sim...t/353225574923
Good luck!
Good luck!
Likes For markk900:
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,285 Times
In defense of the original plastic levers, though less stiff and less durable than alloy levers these don't flex noticeably when 1) the cabling is in good order with no metal-to-metal along the cable's path and 2) one doesn't push the lever hard beyond the lo-limit of the derailer's travel. The latter is helped by the former and my bikes are really quite fine with plastic levers (wish I could say the same about the plastic FD's).
The downside of the Simplex levers is that I have occasionally pinched or poked a fingertip on the metal projections toward the front of the pivot assembly. Not fun when that happens.
I am not at all an expert but last week I tried to replace the Simplex lever you see below with a single version of the Huret levers you have above and it didn't fit. The squares were different sizes. But mine is a different lever to yours so..... I just wanted to say.
Shifter missing the d-ring
Quoted: 212 Post(s)
Liked 111 Times
I appreciate all the advice and suggestions. I will let you know how this plays out.
Quoted: 212 Post(s)
Liked 111 Times
Well, the Huret levers worked out fine. While I was at it, I replaced the Delrin derailleurs with Shimano/Suntour. Functions perfectly, and rides well.
Likes For kross57:
Quoted: 478 Post(s)
Liked 634 Times
Looks amazing! Glad the Huret levers worked out - also with Suntour the Huret works better than the simplex - I understand the barrel the cable wraps around is larger diameter - with Simplex and SunTour (especially if you go to 6 or more cogs on the back) the lever comes quite far around in low gear - works fine just looks wrong!
I spy a Comp-V on the front - that was the first mod I made to my AO-8 back in 1972 or so - replaced the rear with a Shimano Crane (1st gen) and the front with a Comp-V. I now run an SL on the front of that same AO-8.
Likes For markk900:
Quoted: 212 Post(s)
Liked 111 Times
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
I chiseled off the drive side Simplex boss and covered the scar with a double SunTour cable stop for stem shifters while it was my wife's bike, then barcons and drop bars when it became mine. (She got intimidated by traffic and switched to trails after I let her borrow my mountain bike.)
Likes For John E:
Quoted: 212 Post(s)
Liked 111 Times
The only thing I wish it had at this point are barrel adjusters for the brakes. I can get them properly set through cable adjusting, but it takes time. Someday!
