Pedros tire levers
we be rollin'
Pedros tire levers
Just a heads up if anyone wants thicker, wider tire levers. I know Schwalbe seems to have changed their tolerances because I know the Schwalbe Land Cruiser is medium-fitting in my opinion but yesterday I took off (with a considerable amount of force) some tight Schwalbe 26" Ranger Cruiser tires on some Rhyno Lite rims. It was EXTREMELY tight and the only time in my life I had tires installed at a bike shop. Anyway, let's see if I can add a picture. (By the way, the Maxxis Overdrive Excel tires were loose-fitting so I was able to install them myself on the Rhyno Lites even though it took some effort.) (This is not a paid ad, just grateful I got them.)
Pedros tire levers
Pedros tire levers
Quoted: 668 Post(s)
Liked 529 Times
Pedros makes some good stuff.
I have a pair of steel Park Tool irons for emergencies.
Likes For freeranger:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Personally, I like the Park plastic levers.
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
At one of the shops I managed I had mechanics start dating each Pedros lever because it felt like they were going through a pair a week. I prefer to use the Crank Brothers Speedier Lever. Way easier to use no harm to the knuckles and has an install side for those tougher beads. I rarely need two levers from them and my personal main use lever is now 7 years old or so.
Likes For veganbikes:
Likes For katsup:
Quoted: 164 Post(s)
Liked 44 Times
at home i just use a lonf wide flat head screw driver wrapped in electrical tape , best tire lever i have , on the road i carry a metal lever and a plastic one both from wal mart extra cheap !!
Quoted: 668 Post(s)
Liked 529 Times
Anyone have any luck with one of these? Got one cause it looked like a great tool, but the couple of times I tried to use it didn't work out so well. IIRC could never get the hook end to stay on the edge of the bead. Ended up going back to just thumbs.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
No matter the lever, keeping the tire in the rim bed where you aren't currently working on it is key. Sometimes you think it is, but it isn't. Then I'll see that and fix it by putting it back in the bed, and it gives me that bit extra.
I use the pedros. Usually just to get em off quicker. Working the tire into the bed usually makes it so I can get it with fingers. Well, if the fingers as dripping in sweat on a hot day.......back to pedros!
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Back when I started, tire levers were chromed steel. Plastic wouldn't have been considered by anyone.
Fast forward 45 years, and you find that Pedro's levers are indeed the best lever made. No question.
I also have two of the Crank Brothers Speedier, a useful tool for quick re-seating of the second bead. And I have a KoolStop tire bead jack that I carry on my commuter because Schwalbe Marathon Plus tires are difficult to change/mount. Fortunately, flats are rare with those tires.
Likes For Phil_gretz:
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I'm also a fan of the Pedros levers for stiff, nasty, wire bead tires. I've broken my share of tire levers, but my first pair of Pedros is still going strong. (And they're pink, so everyone knows that they're tough.)
Likes For wipekitty:
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
First time I tried it on a new foldable Conti Gatorskin it bent my rim and didn't get the tire on. Granted it was an old rim with worn brake surfaces, but still disappointing. The incident did teach me the virtues of soapy water, which is how I finally got the bugger on, with my thumbs!
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
I have an old mtb, much easier tire repair than roadies, but when seeing a brand new pair of Pedros in a thrift store for $1.99....
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I bought one a few years ago but have rarely used it, mostly because when I end up with tight tires I don't buy them again. It does work well for me.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
Tire lever wise I have a 1/2 set of Pedros, one broke due to being used in cold weather, a problem with plastic. I use Soma steel core levers, they're not quite as bulky as the Pedros but far stronger, they can't crack in the cold because they can't flex. Another tire lever I use is the VAR, extremely good at putting on very tough tires, and it can fit in a standard seat bag.
Zip tie Karen
Liked 1,542 Times
So you started road biking 43 years ago? so that was in 1975, correct? I started myself in 1976, in 1976 I bought my first road bike, a Trek TX900, and with that Trek I bought my first flat repair kit with tire irons...mine was made of aluminum. Aluminum tire levers came out because of aluminum rims, and the steel would damage the rims. Aluminum rims go back to 1937, but I can't find when aluminum tire levers first come came out, but they've had to be out for a long time due to aluminum rims. There were chrome steel levers as you mentioned but those were used on chrome steel rims, so were you riding on steel chrome wheels back in the mid 70's?
WALSTIB
Schwalbe tires can only be removed with Schwalbe tire levers dummkopf
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
If you want to read about how Schwalbe feels about some rims and tires being harder to mount and how you can deal with it then read here:https://www.schwalbe.com/en/tech
It’s an amazingly detailed document covering the company and it’s products Did you know they make a fluid called “Easy Fit” that can help ? Also they talk about tried and true techniques like holding down a section of the tire with a toe strap or zip tie while working on it Highly recommended.
BTW, that little brochure that we all throw away when unwrapping a tire was where I got that link. Enjoy.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,034 Times
Quoted: 18411 Post(s)
Liked 15,531 Times
Liked 15,531 Times
