Required exercises to move to upper gears in uphills
Bikes: Giant Escape 1
Quoted: 18 Post(s)
Hi guys,
I joined recently (around 1 year and a half) the biking sport and i own a hybrid/city bike, Giant Escape 1 fitted with GP5000 700CX28mm clinchers (upgraded from the 32mm Giant stock tires), which im using for touring/exercising. At the beginning, it was very hard to ride on hilly areas and surely after quiet some time, it started to get a bit easier. I currently feel comfortable with a 40 to 60 km uphill ride, where the altitude gain ranges between 1500m and 1800m.
The problem is that im stuck on my lowest gear combination (26 tooth chainring and 34 tooth sprocket) as soon as i hit a climb of 10% gradient or more, whereas im capable to use a 36/34-30 combination when facing a 4 to 8% climb.
So my main question is what exercises will help me use say a 36 tooth chainring with a 34 or 30 tooth rear cog when going into a 10% gradient climb? In other terms, what will help me get out of my slowest gear combination when attacking "steeper" climbs.
P.S.
- The bike is equipped with a Shimano Acera 26/36/48 chainring and with a Shimano HG30 11x34 9 speed cassette.
- The bike weight is around 11kgs and i weigh a hefty 85 kgs (i know loosing weight will help me a lot during biking, especially climbing, but lets omit this option for now )
-Cant switch to road bikes due to lower back pain issues.
Waiting for your valuable inputs.
P.S.
Quoted: 4790 Post(s)
Liked 3,917 Times
Grade makes a huge difference! Your 26 x 34 gear is roughly 64% of your 36 x 34 gear. 64% of a 10% grade is roughly 6% grade. This sounds right in line with physics.
Now, to climb this steep stuff a little more comfortably - a lower gear (I run a 24 in front. I've heard of 22s. You can go as low as 52 in back but that means spending real money on an entire drivetrain upgrade. Do you ride with foot retention? Ie clipless pedals or toestraps? Do you stand on the pedals?
Standing on the pedals while locked in allows you to slow to a lower cadence and "lug" quite effectively. If you have never done this, it probably sounds luny and the idea of riding strapped or clipped in, scary. But it had been done for at least the past 120 years by thousands.
This is a big jump if you haven't already, Many simply won't ever do it. But others feel like they've just walked into the light after that first clipped in hill climb.
Ben
Ben
Likes For 79pmooney:
Expired Member
Quoted: 3654 Post(s)
Liked 5,392 Times
I know what you mean, there's something about 10%+ that feels harder than it should relative to 7% or 8%. I'd suggest continuing with your 26T chainring but shift to smaller cogs in the rear for part of each climb. When you are comfortable using whatever combo equals your 36-34, then begin starting out in the 36 ring. You want to avoid a front shift while you are climbing a steep grade with low cadence.
Quoted: 18 Post(s)
Ben
Ben
As a matter of fact, im not looking for changing the current chainring/cogs configuration since riding on my lowest combination suits me so far thus im not looking for smaller ratios. On the other hand, my friends are attacking the same climb faster since they are using higher gear combination due to their fitness/muscles. So what im looking for is to improve my climbing "speed" and i believe this will be achieved by being able to use higher gear ratios.
As for clipless pedals, i just got my hands on Shimano PD-M520 SPD Pedals but didnt install them yet, and i heard that they make a significant difference especially when climbing. For the time being, i dont feel comfy when standing since i face some knee pain not to mention that i run out of breath when seated again (kinda weird or im doing something wrong when standing).
Having that said, i was looking for any exercises which will enhance my uphill capabilities, one of which is the speed/higher gear ratios.
Quoted: 18 Post(s)
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,855 Times
Thank you 79pmooney for your clarification.
The only really effective training for climbing is...more climbing. You might try doing hill intervals, if you have a hill nearby you can do in 5 minutes going as hard as you can, then rest up a bit. I used to ride a route that had 3 climbs like that separated by just enough distance to let my heart rate fall back a bit before the next one. That seemed to help with climbing, but overall I only got better at going up hills by going up more hills more often.
Quoted: 2952 Post(s)
Liked 3,106 Times
Simply going into a higher gear you can't turn - especially if your knees are already bothering you - won't make you any faster. And 10% is a tough slog.
Likes For caloso:
Likes For DeadGrandpa:
Improve your climbing technique. While waiting for improvement continue to use whatever gear works. Being able to climb in a bigger gear means nothing. All that matters is how fast you are going. Same speed in 26x34 and 36x34 is same speed.
Best possible exercise for climbing is climbing. No shortcuts.
Gravity is a constant. An interruption in power to pedals that lasts 0.01 second is immediately detected by gravity. No escaping gravity. Most good climbers pedal at a higher cadence than slower climbers. Higher cadence means lower gears. But use what works for you.
Likes For 63rickert:
Liked 11,855 Times
Quoted: 325 Post(s)
Liked 109 Times
Of course, since OP mentioned knee pain the day after using a 36x34t, I would give a word of caution: to save your knees, focus on using a higher cadence and avoid "grinding" in a big gear.
Quoted: 4227 Post(s)
Liked 2,488 Times
Likes For wolfchild:
Liked 3,917 Times
Now on the breathing - the dynamics are different seated to standing, Standing gives you access to more power for a given oxygen level. But when you sit down, you both go to a higher breathing mode and need to play catch-up for the debt you incurred standing. Don't give up. Keep doing it and watching what happens, Get a feel for what you can do. Standing is a very useful tool. For some, a few moments here and there. Others can park themselves there all day. (Me) For some it's an even 50-50. What standing does very well is open up the range of gradients you know you can handle. Standing also gives you far more full body exercise than seating. For those of us who just ride, a real blessing!
Best exercise for hill climbing, especially very steep hills? Ride them! It's all about the heart, the lungs, the legs and the small muscle train from quads to fingers and from glutes to fingers, Nothing targets that stuff like climbing.
Ben
Quoted: 6935 Post(s)
Liked 10,940 Times
torony : It almost seems that you want to climb in bigger gears because your friends are able to do so. But that's a lousy reason. My advice is to stop worrying about the gearing; if you want to get up hills faster, focus on hill repeats and other forms of intervals, as several other riders have suggested. I've climbed grades as steep as 37% on a 34-32 gear, but plenty of other people have done it on higher gears as well as on lower gears -- the only thing that matters is just doing it.
Quoted: 18 Post(s)
My actual concern is working on exercises that will help me ride in higher ratios, so when there, i will be able to upgrade my bike/drive terrain.
So will be working on the shared ideas via this thread to improve my hill climbimg ability/speed
Quoted: 1815 Post(s)
Liked 1,693 Times
It is simple physics. Your uphill speed is limited by the wattage you can put out no matter what gear you use. A lower gear will require a certain cadence to maintain speed. If you cannot put out enough power to maintain that cadence in a higher gear you cannot go faster, and you will probably bog down and go slower. Training is the magic bullet that will allow you to climb faster, it will make it possible for you to put out more power and turn that higher gear at the same cadence allowing you to go faster uphill
Quoted: 18 Post(s)
Liked 1,693 Times
The suggested exercise to gain strength for hill climbing is more hill climbing. Work on spinning your pedals faster in the lower gears. If you spin too fast, switch to the next higher gear on the cassette, don't worry yet about using the next bigger chainring. Learn to climb out of the saddle for brief periods. If you see a steeper section, climb it standing and get back into the saddle when the grade decreases. Use a heart rate monitor to follow your heart rate a nd to learn what heart rate you can maintain for longer periods. Losing weight and buying a lighter bike will allow you to climb faster, again, simple physics. Your current bike isn't doing you any favours when it comes to uphill speed.
Liked 3,106 Times
Likes For caloso:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,029 Times
Climbing standing may not be harder on your knees. If it is a wear issue between the patella and bone under, the angular motion of your knee is just as much a culprit as the raw force. When you stand, you can rock the bike and lessen the movement of your knee. I have had chondromalcia patellae the past 40 years and have ridden fix gear including hill the entire time. The big rocking of the bike is a knee-saver for me Now the .trick is to be efficient while doing all that rocking. Keep your front wheel pointed straight up the hill, not wavering. I keep my head "quiet" with my eyes not moving except a small rotation about the bridge of my nose. I was taught this as a budding racer a million years ago. Took some real practice and concentration, but so worth it! When you get it down it becomes "the dance". Get it down and you can do it (at the appropriate speed - I watch my breathing) for a long time.
Ben
Ben
Riding every day (and often twice a day) this technique made a huge difference to my riding in about a month to six weeks. And the nice thing is that I saw measurable improvements on every ride. Riding less often, maybe you'd want to increase more than 20% on the reps, I don't know.
Likes For MattTheHat:
Usually at this time of the season I'm much lighter, in fact I'm just as heavy now as if I'm in the off season however I'm climbing well despite the extra weight. The equalizer for me has been squats. I now do 3 minute rounds of them. Has made a good difference. I hadn't done them in the past but the current times has changed my work and workout schedule. In a 30 minute workout session twice a week, led by my wife, I'll go through at least two 3 minute rounds of squats. The basic order is, squat take a step squat. I do this the circumference of the workout area for three minutes. It should be noted that I had a knee issue/injury that requires me to wear a knee brace. However I would not have been able to do any squatting at all if it wasn't for the exercises my wife put me on, Mainly quad extensions. They helped strengthen the muscles surrounding my knee and allowed me to stabilize enough for almost complete healing but I still wear the brace when running or other impact exercises.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
Elliptical machine training helps if you have one available.
Likes For livedarklions:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
If there's mention of knee pain at any point, I would take caution and in the meantime utilize whatever gear gets the cadence higher. If you already have it, use it. If you don't have it, consider a small upgrade to get it. After taking care of the health/well being aspect of the knee, then you can make shorter duration efforts uphill in a more difficult gear while still holding the same cadence as before. Rest. Repeat. Intervals. If the cadence drops, change gears for the interval or abandon and rest before another set.
I'm more of a fan of training the specific sport you're doing at the time when you are "in season" and leaving the cross training for off season. Most of us joes don't have the time or energy to both train on the bike when "in season" and cross train another endurance activity. If you need some kind of core or other leg muscle work for the health and well being overall..........I would suggest researching the yoga like exercises you can do on off days to improve that. Otherwise, if you have time to cross train while "in season" on gym equipment.......you have time to strap the bike to a cheap fluid trainer instead.
