28 on back 25 on front
What Physics?
What ever.. I don't think Isaac Newton wrote about bike tires .. do you have a Thesis to quote ... footnotes??
I bought 2 406 - 40 tires, I always put the new one on the front, the old front a 406 - 47 is on the back,
when its worn I'll put another 40-406.. on the front...
will 3mm matter? others ask can I put a fatter tire on the front to be more comfortable ?
you certainly can try it..
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
No worries. BITD, it was pretty common to run 25 or 23mm tires on the rear and 18 or 20mm tires in front.
I'm not really sure if there's any gain in having the narrower tire up front. Most of the weight is in the rear, so I'd use the narrower tire there since it'll run higher pressure and roll with less resistance. Then the larger tire up front can take up bumps better.
Likes For crankholio:
Bikes: Scott speedster flatbar, univega fixed gear conversion, Dawes Galaxy MTB
I have done 23/25 tbh couldn't notice the difference in ride between that and 25/25.
Likes For trailangel:
Quoted: 1943 Post(s)
Liked 2,164 Times
Typically a wider tire in front will provide more cushion than one on the rear. I really doubt that there is any speed difference regardless. Although 25 to 28 is not going to make much more of a smoother ride, you might as well take advantage of it.
John
John
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Also, aero wise.......run the narrower up front since the front wheel sees undisturbed air and benefits from that. The rear sees the air already churning by the bike and rider, so the larger tire doesn't matter as much.
If there isn't a bicycle dimension restricting what I use and I'm not racing......I use the same. If I'm in a TT, smaller front optimized to the wheel larger rear optimized for crr. Cyclocross same size for both, the most I can run on the bike suitable for the conditions and allowed at the race.
But yes, you can do it. It is common. And the smaller one goes up front.
And I believe it's been shown that higher pressure narrow tires don't necessarily have lower rolling resistance.
Backwards. The rear bears more weight so would benefit from more tire if you're going to run staggered tire sizes. Why would you over inflate a smaller tire on the rear just to wind up increasing the crr and lowering the ride quality?
Likes For fietsbob:
Quoted: 4227 Post(s)
Liked 2,488 Times
I never understood the logic behind putting a smaller tire up front and bigger in the rear and it doesn't make sense to me for a bike that is used on pavement. I prefer the same size tires on my bikes which I use for pavement or gravel riding...but if I was going to run different sized tires I would put bigger tire up front for better handling and comfort and smaller tire on the rear for better acceleration and rolling resistance....Right now I am running different sized tires on one of my mountain bikes: 2.35 inches in the rear and 2.5 inches up front. The bigger tire up front gives me better handling, traction and comfort and the slightly smaller tire in the rear gives me better acceleration and makes climbing hills easier.
Liked 2,488 Times
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
I’d say people sometimes overestimate the difference in weight distribution because they don’t consider the weight distribution during braking nor while standing out of the saddle. I prefer to run the front pressure no more than 10% below the rear. So I just run similar tire sizes.
OTOH, it will totally work to run different sizes front and rear. It accomplishes different things depending on where you put the larger tire. Larger tire in back and you could run pressures the same, and probably is more efficient. Larger tire in front means lower pressure and maybe easier on your hands.
Otto
Otto
Quoted: 604 Post(s)
Liked 1,063 Times
That’s what’s on all my bikes, except for the Sports Tourer. Played around with the pressures, and settled on 85psi rear, and 75 psi front. But then again the roads around my house really suck!
Tim
Tim
For the front, one should use narrower tires that are supple and lighter weight overall, this will translate into faster reaction to turning. Supple casing means more shock absorption. Also, if you use aero wheels, most are optimized for a 23mm or 25mm tire. A good front tire would be something like Veloflex Corsa or Vittoria Corsa.
For the rear, one should wider tires with harder casing and a tad tougher rubber. This is mainly for wear and puncture resistance. A good example here would be Conti 5000GP, Vittoria Rubino series,
There is nothing more enjoyable then riding a front tire that allows the bike to carve naturally around curves. I have tried 28mm tire for the front once, then took it off after a few ride. It's akin to buying Ducati and then proceed to put Harley tires on them... very vague, floaty, and imprecise feel for the front. Oh sure, if you use a wider tire and lower the pressure, it'll give you more comfort... until you try to hard corner,.. then you curse wtf!
Likes For aclinjury:
Pennylane Splitter
Bikes: Yes
Quoted: 1796 Post(s)
Liked 1,439 Times
Bigger tires all around. I've got 700x32's on both front and rear on my roadie and single speed. Tour bike has 700 x 35's. No problems with either set up.
Quoted: 1248 Post(s)
Liked 1,323 Times
Stability? Your rear tire has stability issues, that’s also a first.
Braking? Considering weight transfer and all never considered the rear having a major influence on braking performance! A first for me.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
You’re not a dragster. Unless you routinely spin out on your 25s, tires won’t have any effect on power transfer.
Same for braking; skids under braking are more to do with weight shift, or lack there of, than tire contact patch.
In the rigid MTB days, it was not uncommon to run a bigger tire on the front, so you could run lower pressure for absorbing bumps, and for more float over the loose stuff.
No no real reason to stagger sizes on a road bike, unless those are the only two tires that you happen to have on hand. In that case, I’d run the 28 on the front, since your hands aren’t as good of a shock absorbers as your butt.
Cheerfully low end
Quoted: 645 Post(s)
Liked 1,044 Times
If that is not a factor and it’s only for road use, there is still a consideration of the effect of tire size on trail. As I expect you know, a properly designed frame will have the head tube angle and fork offset chosen to produce an optimal amount of trail (for that head tube angle) for an assumed wheel size, which includes an assumed tire size.
Smaller tires reduce trail, larger tires increase trail. For a given frame, excess trail makes the handling more stable but slower, while less trail makes it less stable but quicker. Changing front tire size can definitely make a noticeable effect. Whether you like it is a matter of preference.
Otto
