How to keep cut cable from fraying?
Dopamine Junkie
Hi all,
This is a follow-up to my last query, about lubing/not lubing shifter and brake cable housings.
Is there a way to seal the ends of cut shifter and brake cables without a soldering iron so that they don't fray and can be re-inserted into cable housings? I looked on the 'tips & tricks' thread and didn't find anything. I had a friend who used a soldering iron to do it, but I don't have one, and I won't buy one just for this one application. I do have a glue gun, am wondering if that would work. I tried using super glue, but it doesn't seem to adhere to the wire strands, perhaps because they are lightly oiled at the factory, so I doubt a glue gun would work...
As always, thoughtful, well-informed replies are appreciated the most!
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
First thing is to cut them with cable cutters, not side-cutters, dikes or lineman's pliers. Don't cut them until you're ready for them. Use immediately after cutting. You can always install the little cable end caps and crimp in place after the installation is completed.
Jon
Jon
Cyclist
If you have a good set of wire cutters you should be able to just trim a tiny bit of the frayed end off without causing additional issues. Then, what has worked for me is spinning the cable (or housing) as you insert it. Since the cables are made of smaller wires spun together, you should be able to spin it so the cable rubs against the housing in the direction that will keep the wires together... I realize now that this technique is difficult to explain without some sort of visual aid, but hopefully this helps.
Quoted: 336 Post(s)
Liked 309 Times
The best spent money is on a good pair of cable cutters so cables don't fray when running them through housings and stops.
Or if you know what type of cable end you need (mtn vs road for brake cable; Campy vs Shimano/Sram for shifter cable) you can buy cables with only one end and the other is pre-soldered.
Really Old Senior Member
These-
Quoted: 897 Post(s)
Liked 9 Times
I need to buy a lifetime's supply of "these". Hopefully there is a size that fits both brake and shift cables. I used to use cheap spoke nipples, the long flimsy kind, and a squeeze from some pliers, but really cheap spoke nipples like that are hard to find these days.
Dopamine Junkie
Thanks for everyone's quick replies!
Yeah, I noticed that the cable I bought was nicely soldered at the end--and rounded too. But it's way too long..
A couple of you mentioned buying a good pair of cable cutters. I think that might be the best solution. I have a pair of wire cutters, but they're not very good. And I have a very high quality pair of pliers from my father (vintage ~1950) that has chisel jaws built in. They are hard and tough enough to cut cables but I suspect that they are not sharp enough to make a clean cut--or, rather, not designed to do so b/c they spread the individual wires out as the cut is made. That's why I have trouble re-threading cables after cutting them.
Can anyone recommend a good pair of cable cutters?
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Park and Shimano make decent cable cutters. Felco makes the best.
https://www.felco.com/ca_en/felco-c7.html
Quoted: 336 Post(s)
Liked 309 Times
Pedros probably has the best bang for the buck cable cutters. They have the same design and jaw shape as the Felco's; the difference in cost is most likely due to better materials and tighter tolerances on the Felco's.
https://www.universalcycles.com/shop...0&category=747
Quoted: 2338 Post(s)
Liked 2,822 Times
put the cable through the housing and brakes/shifters and cut afterward, then put the endcaps on the cables. A lot of modern cables are not partial to soldering (teflon coating etc)
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Wrap the cable with a layer of masking tape before you cut.
Quoted: 1609 Post(s)
Liked 2,590 Times
All good until you get into the double ended universal cables. My secret is putting on my glasses before I start threading it through...
Liked 2,822 Times
LOL the glasses on top of the bifocal contacts are a requirement for me also
:foo:
in a bike shop see # 5
I for my bike, Solder it before I cut it, where you plan on cutting it..
with proper cable cutters.
fit , mark, pull, solder, cut , then grease.
you don't want to,? ... that's the best way.. your choice..
silver solder * is needed for stainless, But not for Zn treated steel.
* I got 400F melt, from welder supply .. (but metal must be clean)
Quoted: 897 Post(s)
Liked 9 Times
Thank you. Ebay has a rather wide aglet selection, people get fancy ones to customize their prestigious shoes.
https://www.ebay.com/itm/25Pcs-Shoel...sSonAa-LkjXR7Q
I bet these would work on bike cables, and add a little style too.
Jon
Jon
That said, you need the wire-rope cutters anyway, so...
As FB mentioned, you can use solder on stainless cables, but it has to be silver, and you need to clean it with an acid wash/thoroughly degrease for it to stick. Tin is fine on plain/galvanized cables. Superglue will work, but will work better if it is immediately sprayed with CA accelerator (available at hobby shops). Grab a bottle of CA remover while you're at it--way faster than using acetone to dissolve a bond between skin.
Quoted: 1438 Post(s)
Liked 1,092 Times
I used to use Krazy-type glue but I've started doing it this way, with a torch and drill (really!) :https://www.youtube.com/watch?v=cUQQ9aggSt
And +1 for Felco cutters, wouldn't use any others.
Quoted: 18375 Post(s)
Liked 4,510 Times
I TIG weld mine. Quick and easy. The problem is to get just enough weld to tie the ends together without getting too big of a ball (and thus not being able to pull the cable without cutting the end).
I've seen notes about twist welding. Perhaps I'll try that someday.
Quoted: 2026 Post(s)
Liked 1,096 Times
Superglue works if you clean the cable end. Acetone does a good job of removing any oil and dirt.
Dopamine Junkie
Thanks, y'all, for chiming in! I don't know what I'm gonna do, yet, but it looks like a new pair of cable cutters and superglue are in my future, since I live in a tiny studio apartment and would have a bit of trouble storing--and using--a TIG welder in it...
