Looking to upgrade 1998 Cannondale R200
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
Had it since new. Low miles. Yes, I crashed on it. Had the frame inspected by two shops. Needed a new front wheel, and handlebars.I've lost a lot of wieight, and was going to use this bike on the trainer. BUT. The RSX brifters were gummed up.
Bike as outfitted has RSX 3x7 brifters, brake calipers and RD. Crankset is 3 ring Shimano 105 FC-1057 and FD-1057 FD...
Which leads to my round of questions...
1. Will a 8,9,10 speed freehub fit in place of the old 7 speed hub?
2. If not, is it possible to have a shop bend the aluminum frame to fit the wider hub?
I'm believing if I can go 8, 9 or 10 speed, guessing my 105 crankset won't work with the narrower chain.
No, it isn't cost effective to update this bike, if I were going to sell. I've upgraded my old KHS to Shimano 105 5600 10 speed. Certainly no value in that, but it was a old friend and I'm enjoying it again.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 711 Times
1: Maybe, maybe not. 7-speed width between the dropouts was 126mm, 8/9/10-speed is 130mm. However, some manufacturers split the difference in order to use different groups on the same frame production line. Given the vintage, I'd bet your frame is 130mm. Try it!
2. Probably not necessary and it will be tough to find a shop that would do it for you. Most shops won't try to align an aluminum frame due to fatigue concerns. Whether these concerns are warranted... I dunno.
I'd bet your existing crank will work fine with an 8-speed chain and might be OK with 9-speed. If you want to try 9-speed, the chainrings should bolt right on.
Jeff Wills
Jeff Wills
Quoted: 284 Post(s)
Liked 385 Times
Ok. I officially feel silly. For not just trying to slip a different wheel in. Simple answer, it fits perfect.
Ok. Now I can start looking for newer brifters. The old RSX brifters got gummed up with old grease. I am now curious if the RSX RD-A410 will cover up to 10 speed or not. Probably go with Microshift if I buy new.
Thanks!
Really Old Senior Member
Flush the shifters with WD-40. One of the few uses where it works well.
Quoted: 809 Post(s)
Liked 711 Times
Agreed. Shimano shifters with gummed-up grease is a very common problem. WD-40 works to break up the old grease, but I follow that with a petroleum-based spray oil. I gave my early-'90's XTR shifters this treatment about 15 years ago and they've worked fine ever since.
Jeff Wills
Jeff Wills
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Ditto. My 1996 3x7 RSX brifters are still working great. I need to do the WD-40 flush every five years or so.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,405 Times
Or try these like-new RS-500 8 speed shifters I have for sale. They shift either a double or a triple, and index perfectly with any Shimano FD and RD (except the notorious DA 8740X).
Perfect hoods and lever blades, shift like a charm. PM me if interested:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Also, if you go to 9- or 10-speed, the FD cage will be so wide, it'll have trouble picking the chain up to make shifts. I wanted to keep my 3x FD, when i went to 9-speed, but the the chain is just so narrow inside the cage, that it can't pick up the shift pins on the chainrings. I had to use all the travel on the 4500/3 (3x) shifters to make a single upshift. I ended up getting a new FD-5600.
Quoted: 284 Post(s)
Liked 385 Times
My initial efforts to un-gummy the shifters met with no success. I went straight to automotive brake cleaner to clear the gum deposits. With zero success. I gave a lot of thought to disassembly. And I still might, as I am building a new workbench for such projects in my basement. I can't seem to keep my garage bench clear... I did purchase new cables all the same, for someday, clean the current or upgrade...
@rccardr, I will give the 8 speed set a serious consideration. With the triple chainring, My first thought was why go one extra cog, but 8 might be sufficient and ought to work with the RSX RD... And, I do have an 8 speed cluster on hand to begin with.
@Ironfish653, thanks for the RD info, and the FD. I'm guessing the RD pulleys are interchangeable between series. As luck has it there are a few 105, and Ultegra FDs available locally.
I also have a 29er built off a Performance Access frame, the guy that gave it to me has an interesting mix of parts the work well, 9 speed Sora ST-3500 triple brifters on a drop bar, with a SLX RD-M662 RD, SRAM X5 FD and Avid BB5 disc brakes. Comfortable ride, And a 1991 Trek 7000 with original Deore LX 7 speed drivetrain. I keep the Trek at work, and it is going to stay as close to original as I can keep it. I have 3 other bikes, but they are out with my son, daughter and son inlaw... Yes, I have a reasonable N+1 issue. Odd for a guy afraid of riding on hills...
Quoted: 284 Post(s)
Liked 385 Times
I do a brifter flush with CRC Power Lube in the red can. This stuff has PTFE in it, so it lubes as well as being a solvent.
I still have yet to find a pair of gummed shifters I haven't been able to free with this technique. The key is patience. It has taken me a good half-hour on each shifter - spray, let drain, work shifter both ways, repeat - to free a badly gummed one. Keep at it, you'll get it.
Quoted: 284 Post(s)
Liked 385 Times
your upgrade is all parts at retail , so It wont be exactly cheap..
New bike they whole kit was assembled at the lowest cost Large order at OEM Wholesale..
Might find a used bike with the parts you want , .. to strip and put them on your bike, then sell everything else on eBay
Quoted: 9 Post(s)
I would bet the frame is 130 spaced, despite coming with a 7 speed setup originally.
I have had STI levers work after flushing with very hot water, after solvent flushing didn't work.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
A 1998 Cannondale coming stock with 7 speed? I started running 8 speed Dura Ace in 1989, hard to believe that any 1998 Cannondale came with 7 speed originally.
Quoted: 284 Post(s)
Liked 385 Times
Quoted: 284 Post(s)
Liked 385 Times
I may access to a steamer with a thin wand, that might break up that grease.
Quoted: 284 Post(s)
Liked 385 Times
The bike indeed came with 7 speed RSX in 98, bought the bike new. Likely the last year or maybe the next offering a 7 speed rear. I recall then, wondering how they could find the space for 8 and the old guy running that shop mentioned that 9 and 10 speeds were coming...
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
But, again, you answered that question.
The chains are only narrower on the outside. They still have the same internal pitch. The best approach is the same one that you used with the wheel. Just try it and see. If you it works, you're golden. If it doesn't work, you'd have to buy a crank anyway so you aren't out any money you weren't planning on.
No, it's not cost effective but the last "new" bike I bought was in 12 years ago. Every other bike I own has been used frames that are older than that and I built them up to my own tastes. Not a cheap way to get bikes but I get what I want.
Stuart Black
Stuart Black
Quoted: 284 Post(s)
Liked 385 Times
Quoted: 284 Post(s)
Liked 385 Times
As I have mentioned elsewhere, I'm not a patient person. My attempts to ungummy the brifters was a failure at the first and second attempts. But, it was winter. So, today I.lay the brifters on the sun for a while before repeatedly flooding them with WD40. Short answer is, it worked.
So my upgrade path may only be with a different rear cassette. 11 to 24 is awfully tight. Yet, 11 to 30 all but negates the third chainring. Ohhhhh, decisions...
But deciding to just keep this as it is for the most part. New chain, cables and cassette... After all. It has new stable mates.
A 1992 Trek 1400. Full 105 1055 group. Currently rolling 105 5600 hubs, and 11 to 28 cassette.
And a suggestion of a 2019 Cannondale was made. Well. Not 2019, but 2006 CAAD8 R1000 frame... Building it as a reward for my next weight loss goals, less than 30 pounds to go...
DT Swiss R1800 wheelset, SRAM Red crankset and. SRAM Force 2x10 brifters. Needs a RD, chain, brakes and cables... I got very lucky with all the above...
I will add, I found a 1998 Scwinn Passage for my daughter. Similarly equipped aluminum bike to this R200 CAD2. Looking forward to riding ether the R200 or Trek 1400 with her.
Ok. Bills to take care of, then a bunch of bike parts to find... Darned responsibilities!
Quoted: 284 Post(s)
Liked 385 Times
Just thought I'd update this. Yes, the seat is at a funky angle. It works on the indoor trainer, but no way could I ride outdoors like that. Same for the old Shimano 561 wheelset. Too few spokes, but they were a good deal for keeping on the trainer. And yes, some bling...
Bike is still 7 speed rear, RSX brifters cleaned and new lube added. I toyed with the idea of swapping in 9 or 10 speed stuff, but have yet to find a good enough deal to make it worth my time. With 2 other road bikes, one heavier than the R200, the other lighter, it's only advantage is the 3x crankset.
As mentioned at the beginning of this thread, I crashed on this bike 8 years ago. Broke my back and had a head injury. I have tried to ride this outdoors over the last couple years, but never felt comfortable or safe. Mental issues of mine I think more than the bike not safe. But, I can't bring myself to give it away or sell it, just in case it is jinxed... So indeed, it is an awfully nice bike to just sit on a trainer. But, it is still useful and used. And isn't that what any bicycle really wants?
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I recently bought an older Cannondale mountain bike, just for the parts, to put on my keeper Cannondale mountain bike, lol. 😁 A lot of times, you're better off buying a good frame with cheaper parts, then either upgrading a little at a time, or buying a parts bike. It seems like a lot of hassle, but if you're on a budget, it works great, usually. 🙂
I'm at the point you described, needing to de-gunk old brifters, but they're XTR 9-speed, so worth the "hassle". 😁😉
