How long will you replace a bike light set?
Along with a properly fitted helmet and a good understanding of the rules of the road, bicycle lights are a crucial element for safe cycling.
Likes For 02Giant:
Same as 02 Giant said. I would add in another parameter. After maybe 5 years, assuming it was a decent light to start off with, I might buy a backup just in case. I commute as part of my bike activities, so those lights are pretty crucial for me.
Quoted: 18410 Post(s)
Liked 15,531 Times
When it no longer functions properly?
Expired Member
Quoted: 3665 Post(s)
Liked 5,420 Times
Hi Jessica and welcome to BF! Do you have a link to a really great bike light set?
Likes For shelbyfv:
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
I have a Cygolite Rover II LED with 255 lumen stated output from 2 LEDs and lenses. It still works perfectly; even the original 4/3A x 4 NiMH battery pack is still going strong. I think it's about 10 years old but don't recall when I bought it. It's adequate for my needs, though the manual charging and NiMH tendency to lose charge in storage makes it a slight hassle. I've even kludged up a backup AA x 4 NiMH battery pack for it. Yet, yet,... the new lights with more efficient LEDs, compact footprints (no water bottle battery), better beam patterns, longer run times with either dynamo or Li-ion batteries, are so awesome I'm thinking about getting a new one.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
I got tired of below average lighting and just bought the L&M Seca 2500. What a step up.
Liked 15,531 Times
Likes For indyfabz:
Forum Moderator
Liked 6,593 Times
Likes For cb400bill:
Quoted: 5224 Post(s)
Liked 3,581 Times
I would love to replace my main headlight but i was able to adapt it for better performance. meaning I added a wide angle diffuser & beam cutoff hood. a new unit wouldn't need those things. I also spent some good money on a bigger battery so I need to keep using that to get my money's worth out of it. I suppose I could get a new head unit for the battery, so I might do that. not sure how old the head unit is, maybe 10 yrs old? still works like new
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I'm not into batteries when they aren't necessary, what with the invention and implementation of dynamo hubs. So I guess I would replace it if it needed to be. Right? Does that answer the question? I would take only as long as necessary to complete the task of replacement.
Quoted: 7652 Post(s)
Liked 3,473 Times
I burned out a Light and Motion Urban 250, (took several years,) replaced it with a 500 and a 750 which have lasted another decade or so and seem to be going strong still. usb recharge, simple, secure mounting, flawless dependable performance. Plenty of other brands offer similar products.
I run Cycgolite Hotshot tail lights--USB rechargeable, multi-mode, retina-searing brightness. Again, excellent in my experience, but there are many other manufacturers offering similar goods.
Quoted: 550 Post(s)
Liked 325 Times
I upgraded to dynamo lights with optics meeting German StVZO standards and super capacitors for backup when stopped.
Before that I bought a new $30 Chinese front light every few years, an $80 Chinese light after a few years, and a new Nite Rider for $150-$200 every few years.
My headlamp has lower measured output, but with uniform light makes it easier to see road imperfections. It never runs out, even starting before sunrise and finishing my last 100km after sunset.
I also wired in a USB power supply, so my GPS doesn't run out on rides over 12 hours and I never need to charge it.
I ordered direct from Germany for half US prices.
Schmidt SON28 dynamo hub, Schmidt Edelux II headlight, Busch & Müller USB-Werk USB power supply, Busch & Müller Line Plus tail light.
Likes For Drew Eckhardt:
Liked 3,581 Times
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
Originally Posted by Drew Eckhardt
Hopefully never again.
This is the kind of post I really like! I would Like it, if that option were available to me (those options at the bottom are obscured from me on certain posts).
Quoted: 550 Post(s)
Liked 325 Times
Some GPSes pop up annoying "external power lost" messages when you stop or slow without that.
The B&M USB-Werk includes a small one.
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
Right on. And one question that missed getting in my previous post: Which business in Germany did you order from, and did you source all of these items there?
Quoted: 550 Post(s)
Liked 325 Times
The blade type connectors for Schmidt hubs are a bit stiff and hard to reach on the inside of the fork blade, so I made a short pig tail with male connectors for the hub and an offset pair of micro bananas on the wiring running up my fork leg where they're easy to reach.
I also used those plugs for attaching the USB supply so it'd be easier to remove if I wanted to swap it out for something else.
Likes For Happy Feet:
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
I ordered everything from starbike.com in 2016 apart from some micro banana plugs from Sinewave Cycles and a longer front brake nut to accommodate the fork crown mounting.
Quoted: 1062 Post(s)
Liked 665 Times
I use lights until they break. More often than not, the attachment mechanism is what breaks first. I've repaired broken lights, attached them with zip ties, and so forth. When I have to buy a new one, I prefer rechargeable.
Winter is tough on lights. Plastic gets brittle, hands in mittens are clumsy, water gets in and freezes.
Quoted: 451 Post(s)
Liked 364 Times
Quoted: 550 Post(s)
Liked 325 Times
It works very well.
While not as bright as a $35 Chinese light, there's no signifiant hot spot so you can see road detail farther out.
Quoted: 1324 Post(s)
Liked 927 Times
Thanks and cheers
Quoted: 550 Post(s)
Liked 325 Times
You might be happier with the two piece Ixon IQ Speed Premium. It should have a similar or identical beam pattern - the Edelux II shares optics with the one-piece battery powered B&M Ixon IQ Premium.
https://www.bumm.de/en/products/akku.../1932qla.html?
I also have a one-piece Ixon IQ Premium for backup because a light failure 100+ km from home after dark would be lousy.
The beam pattern is the same, but handle bar mounting is not as solid as the fork crown mount and isn't quite as good at showing road detail.
