Full Hydraulic brakes on a long-distance AT excursion bike? Yea or Nay?
920 is a 29er touring bike .. on a bike tour you won't have to ride through the night..
Unless you are into that sort of thing ..
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Mine's not. It is in the seat-post, and I have no clue how to remove it and live in irrational but nonetheless crippling fear that it will never work again if I try.
Randomhead
Liked 3,697 Times
The industry is moving away from rim brakes, the main thing I'm worried about is the availability of good rims. I think we're already seeing fewer rim brake rims. It's a lot easier to make a disc rim, doesn't really have to be straight. At least none of the rims I ever got from Stan's was anywhere near straight.
Quoted: 3459 Post(s)
Liked 1,465 Times
the way I read the regs, it would be better to leave them installed if you can make sure they will not be actuated. But etap batteries come right off, there is one on each derailleur. And they are small enough that it would be wise to have spares on a 1200k. Di2 batteries are often buried in the frame.
https://www.faa.gov/about/office_org..._batteries.pdf
So it looks like it is possible to legally carry the batteries that are installed in the device. I was unaware of that.
Quoted: 1248 Post(s)
Liked 1,323 Times
I assumed all Li Ion batteries were prohibited in checked bags, but your reference to the regs made me look. Covered in Q2.
Liked 1,465 Times
FYI, I was pulled from boarding a flight and taken to the baggage security screening area in the bowels of the airport because the scanner indicated there was a battery in the frame. I was required to remove the Di2 battery from my seatpost and place it in my carryon. No argument, no discussion either remove or you and the bike don't get on the plane! Fortunately, I am familiar with my equipment and was able to do this fairly simply. I was the last person to board and they held the plane for me.
I have often carried a saddle and pedals in a carry on, but I suspected that they might think a seatpost is a club (weapon), so I never carried a seatpost in a carry on.
Randomhead
Liked 3,697 Times
That's good information, thanks for letting us know about it. It's not real surprising, I suppose
I sensed the battery in the carry-on is a fire that can be extinguished because It's accessible ...
but one in checked luggage is not... ... have not flown in 18 years..
maybe arrange to buy one on the other side..
have it shipped, surface, when you're done with trip.
That Trek is an attractive bike.
Will you be standing next to the bike, guarding it against potential damage; or will you have to put it into a baggage car and just hope that no oaf throws anything onto it; or something between these extremes?
I happen to be in Japan. Here there's at least one company manufacturing (or anyway having its name attached to) new 126mm and even 120mm OLD rear hubs. (Here.) Not sure about 120mm, but I imagine that wherever you are, with a little websearching and/or ingenuity you too would be able to locate new or as-new126mm rear hubs. I suspect that this tells us something about the continuing availability of aluminium rims. I'm pretty sure that I'll predecease the disappearance of rim-brake-suitable rims -- and if I were a lot less sure of it, I'd buy half a dozen as spares.
Liked 1,465 Times
With so many people switching to discs, Ryde has recently stopped making CSS rims.
That is another example of a top quality rim brake rim disappearing from the market.
Shimano steel axle XT rear hubs for touring bikes are easy to find in 36 hole for disc brakes, but it is nearly impossible to find one of the older steel axle XT 36 hole hubs for rim brakes, I have not seen a new one in years. Everybody seems to be going to 32 spokes, but for touring you really want 36 spokes.
I am sure that rim brakes and brake pads will always be available, but might be lower end products instead of the shiny higher end brakes that almost look like jewelry.
Bicyclehub
General Cycling Discussion
30
04-22-16 04:33 PM
KonaRider125
Bicycle Mechanics
14
02-18-16 03:43 AM
Discusman
Mountain Biking
25
04-15-12 01:28 AM
