Out front mount for Garmin
I want to move my Garmin computer from off the handlebars, to out front. There are billion of them on Amazon from $7 to $50. Any recommendations for a decent one that will last and not cost $50+
Thanks!
Thanks!
https://www.amazon.com/VeloChampion-...tronics&sr=1-1
I have three .... they work great. Very stable.
Likes For soonerrebel:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Kedge
Likes For Cyclist0108:
Likes For RGMN:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I own four of these. They are excellent and come with GoPro mounts for lights and cameras.
https://barflybike.com/collections/road-bike-mounts
You get what you pay for.
-Tim-
-Tim-
Quoted: 1020 Post(s)
Liked 463 Times
In the past I have used the K-Edge mounts. They are well made and come in different colors. They are a good choice.
Recently, however, I have switched to the Garmin out front mount. They are are also solid, well made and the aesthetics fit better with bikes. Here is a link:
https://buy.garmin.com/en-US/US/p/114881
If you have a Garmin Varia headlight, or some other similar device, you may want to look into the Garmin Varia specific mount. It is a very solid platform.
https://buy.garmin.com/en-US/US/p/52...n/010-12384-00
There are lots of good choices out there. Having your Garmin out front, where it can be easily seen is far better than a stem mount.
Good luck and ride safely.
Quoted: 3375 Post(s)
Liked 5,514 Times
I have several bikes and one Garmin Edge 1000.
I bought 2 of the cheap Chinese out-front mounts on eBay for a couple of the bikes.
They look/work exactly like the Garmin mount except for the lack of the "Garmin" logo.
Likes For Shimagnolo:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I have 2.
I use the one that came with my Garmin package. The out front version that has Garmin printed on it. Works just fine. I also have a K-edge one that has the go pro mount on the bottom. I prefer the k-edge one its made really well and its nice looking. But it was $50+ too!! I have not had an issue with either.
Here is the kedge I have:
https://k-edge.com/shop/computer-mou...n-combo-mount/
and the Garmin:
and the Garmin:
Likes For sdmc530:
Quoted: 18883 Post(s)
Liked 10,646 Times
I never understood the need for an out front mount when it fit on my stem.
I believe I'll notice a difference when I get my out front mount on. Although it's minor, when wearing my sunglasses, I have to tilt my head down more to read my display, the bottom rim of my Oakley's are in the way. I'm thinking, putting the computer out there 1"+ farther will eliminate that.
Regardless....thanks for all the input.
Cheers!
Cheers!
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
if we didn't buy fancy out front mounts what then would we spend our money on?!
Likes For sdmc530:
- Soli Deo Gloria -
Liked 736 Times
I know some are slotted and allow angle adjustment. Barfly makes one.
https://barflybike.com/collections/r...ly-race-direct
Asking because all my GPS' are set up level for aero and style. Using the faceplate bolts has them pointing up. The ability to mount to the faceplate, have the GPS level and also use a light on the GoPro mount underneath would be nice. My concern would be putting lots of weight on the stem faceplate.
-Tim-
Likes For TimothyH:
Liked 10,646 Times
Don't most faceplate mounts preclude adjusting the angle? Not trying to challenge. Sincerely asking.
-Tim-
-Tim-
In another thread in another forum, we were talking about the life long influence of formative experiences. The guest really nice bike I rode was at a test ride event, I had bright my bike in for maintenance and that offered me a way to ride for an hour while they worked on mine. All of the test bikes had cateye computers mounted on the stems, compared to mine on the bars with a light and who knows what else. That's probably had some effect on my preference.
Now I use a wrist watch instead of a bike computer.
I bought one of these as I too like stuff out front.
Ride it like you stole it
K-edge or the enve
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
Liked 5,514 Times
- With a stem mount, I need to tilt my face toward the ground to read it.
- With an out-front mount, I only need to move my eyes to glance downward.
An additional plus is that an out-front mount leaves the stem clear to grab when walking the bike.
I've had this one for 2 years. I wanted the Gopro mount underneath. It's well built and no issues. www.amazon.com/Dymoece-Front-Computer-Garmin
- Soli Deo Gloria -
Liked 736 Times
I'm really not a fan of cantilevered loads anchored to the stems face plate bolts.
A cantilever is attached at only one end. The weight hangs at the other end and the load causes the structure to act as a lever against the anchor point.
Stem face plates are designed to provide clamping force in line with the stem. They are not designed to support bending loads which actually pull the bolts at an angle to the stem.
I'm sure some heavier stems support the load just fine but am simply encouraging people to be careful and consider what they are asking their stem to do vs what it was actually designed to do. Some stems are extremely light and I'd hate for a cracked stem or face plate to take someone out.
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
So you are claiming that the folks at Enve, for example(who happen to manufacture and design extremely light stems), have failed to do the most basic engineering calcs for a product that they have brought to market?
Since you have made this Chicken Little claim about cracked stems or face pates due to stem-mounted out front mounts, surely you have many examples of these failures. Right?
"Failed to do the most basic engineering calcs" are not my words.
My words were "Not a fan" and "Encouraging people to be careful and consider."
I think the fact that the ENVE face plate mount does not have a GoPro attachment is telling. My guess is that they did do their diligence and are unwilling to allow people to place heavier cantilevered loads on their stems, which I agree are pretty light.
Anyone who wants a truly light stem should look at the Extralite Hyperstem. The 90 mm version is 73 grams vs 122 grams for the ENVE road stem. The Extralite is also $100 less.
Whatever stem anyone wants to use, I'm just encouraging people to consider what they hang off the face plate bolts, that's all. Stems were not designed to support heavy cantilevered loads by the face plate bolts so just be careful and if you do, inspect often.
-Tim-
Quoted: 4806 Post(s)
Liked 3,928 Times
Again, where are all of these examples of cracked stems and face plates? Heck, why don't you start with just a single example?
If it's true that "they are not designed to support bending loads which actually pull the bolts at an angle to the stem" then what evidence do you have of these failures?
event horizon, you might just want to read up on Mohrs' circle of stresses. The cantilevered load that these units add to the bolt at the head is exactly what you would do if popping the heads off was your intent. Might never happen. But if you ride long enough, it might. Want to volunteer to do 20,000 miles of chipseal with the Envy and report back?
(I have an Element Bolt GPS on an out-front mount but it clamps on a 31.8 mm bar. Since mine is a 26.0. I simply wrap the bar with a couple of wraps of innertube.)
Ben
