1 1/4" headset bearings?
Old 10-14-09, 02:51 PM
nitropowered
Bikes: Custom Custom Custom
I've got a frame that has a 1 1/8" to 1 1/4" tapered fork. The fork on it right now is pretty heavy and I've got another lighter carbon fork. I want to use the other straight 1 1/8" fork in the tapered headtube frame.
So is there a source for a bearing that will reduce the bottom bearing so I can use a 1 1/8" fork? I know trek did something like this for paris-roubaix.
nitropowered is offline
Old 10-14-09, 03:51 PM
dvs cycles
Check with Chris King.
dvs cycles is offline
Old 10-14-09, 04:28 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times in 18 Posts
https://www.pricepoint.com/detail/118...et-Reducer.htm
operator is offline
Old 10-14-09, 09:16 PM
nitropowered
Sorry I forgot to mention its integrated
Old 10-14-09, 11:26 PM
operator
cab horn
Quoted: 42 Post(s)
You're screwed. I should've realized that seeing as how I don't think there are any frames out there that taper in such a way that are not integrated.
operator is offline
Old 10-15-09, 01:39 AM
DannoXYZ
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
yeah, you're pretty much stuck. Personally, I'd measure your frame dimensions, look up the Park Tool - headset standards page to see if your 1-1/4" headtube section can be bored out to 36.8-36.9mm to accept the spacers operator linked to. Then bore out the 1-1/8" section to 33.8-33.9mm to fit standard 1-1/8" cups and use a standard 1-1/8" headset and fork.
DannoXYZ is offline
