Anyone using a 46/30T crank on a road bike?
Old 07-17-16, 11:13 AM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Liked 33 Times in 22 Posts
Originally Posted by wgscott
Thanks for posting the link, but now that I have read the blog post, it still looks like you need a bottom bracket shell capable of accepting a 30mm spindle.
You're still missing something, or misinterpreting something. Praxis clearly states that the Alba crankset is compatible with BSA (English threaded) BB shells. Also the blog post states this, "Praxis made an intelligent decision to create a system that, while unique in some dimensions, allows for compatibility with five of the most common bottom bracket shell designs – BSA (English threaded), BB86 (common on Scott, Giant, Lapierre, and others), BB30, PF30, and Specialized’s proprietary OSBB."
The standard inside diameter of a BSA shell is 33.6-33.9 mm.
If this is the crank you really want to use, your search is over.
BluesDawg is offline
Old 07-17-16, 11:20 AM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
Originally Posted by bikemig
This is why a triple still makes a lot of sense but then of course you run into issues with your brifters. My bikes are all older than yours and I run triples on a lot of them. I'm getting ready to do the Dairyland Dare in August and I'm taking my granny with me, .
https://www.dairylanddare.com
Have you thought about a 11-36 in the rear? That will probably mean a new RD and perhaps a chain but it's cheaper than a new crank.
Long time, no hear. Great to see you.
For this bike, replacing the Di2 would be quite expensive. If I were starting all over, XT(R) with Di2 might have been the way to go. But the 32T cassette maxes out the RD capacity. The only limit on the front is the tooth difference must be 16T or fewer, so 46/30T is a reasonable option. (Also, I just put on a new chain and new cassettes on both wheel sets.)
That said, I think your plan of going with a 46/30 makes a heck of a lot of sense for the kind of riding you do. The sugino OX601D or OX 801d would be near the top of my list for a modern bike but it is expensive, Sugino OX601D Cranks Arms w/BB Cups
That looks great. Although it certainly is expensive, the WI crank would be even a bit more, and with this I might be able to get away with keeping the same Shimano BB. It also offers the (alleged) advantage of keeping the hollowtech II type crankshaft.
Alternatively as someone else pointed out you could check out eBay; there are Japanese online vendors you can buy this from as well which will be could save you some coin.
https://alexscycle.com/products/sugi...act-plus-crank
https://alexscycle.com/products/sugi...601d-with-bb-1[/QUOTE]
Thanks so much for the links. I had given up on finding it.
Cyclist0108 is offline
Old 07-17-16, 11:41 AM
Cyclist0108
Occam's Rotor
I like the crank. Their own website doesn't seem to allow you to specify a 48/32T in the order, and the only 32T chainring I have found on their website is in the mountain crank section, and made of steel (which I would actually prefer to aluminum). The price seems right, too. I'd rather have 46/30T, since the 32T isn't going to differ than much from my 34T, but if it is steel, it might be worth it for longevity.
What's missing is my understanding of bottom brackets and their spindles, which is next to non-existent. I've read some basic descriptions, like this:
Bottom Bracket Standards | Park Tool
Complete guide to bottom brackets - BikeRadar USA
I really want to be wrong about this. The only thing I am confident of is that the word "standard" isn't accurate.
My current bottom-bracket is a Shimano Ultegra "BC 1.37 x 24 Road" and am 99.9% sure it is English threaded, corresponding to the first row in the bottom bracket table in the Wikipedia article you linked.
(I have a custom steel bike with a conventional bb shell that resembles that on my 1987 Bianchi (except for the threading). My frame bb shell can accommodate a 24mm Hollowtech II spindle, or a square taper bb.)
I guess the safest thing to do is ask my frame builder, who offered to install the thing for a few bucks (which might save me from making a costly mistake).
Added in edit:
It looks like WI (for example) makes a BSA bottom-bracket for 30mm https://www.whiteind.com/bsa . I had falsely assumed that this wouldn't work. That opens up a whole bunch of possibilities, including the rumored WI 30mm crankset.
Old 07-17-16, 01:31 PM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Yes, your Shimano BB fits a BSA threaded shell. It uses a 24mm diameter spindle, which fits easily within the 34mm hole in the shell, as will a 30mm spindle. It just has to have a shell interface that will fit and work with both.
Old 07-17-16, 10:45 PM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Not sure when (or if) it will actually be available, but FSA is supposed to be coming out with some cranks with versatile BB adaptability and chainring sizing.
FSA SL-k light Adventure Modular BB386EVO - FULL SPEED AHEAD
TPE16: FSA gets Modular with new cranks for MTB, Gravel, and Road, plus steel Comet 1x chainrings - Bikerumor
Old 07-17-16, 11:30 PM
Cyclist0108
Occam's Rotor
Thanks, again
Old 07-18-16, 06:34 PM
cccorlew
Erect member since 1953
cccorlew's Avatar
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times in 21 Posts
I got all excited about the FSA 46-30 but couldn't find it anywhere.
I wrote FSA, who replied:
Hello Curtis,
That version of the Omega will be available later this year as a 2017 model year product.
Sincerely,
brysfleming
cccorlew is offline
Old 07-19-16, 04:38 AM
deepakvrao
deepakvrao's Avatar
Quoted: 394 Post(s)
Liked 20 Times in 14 Posts
Have a VElo Orange 30/46 waiting to be put on my wife's new Titanium touring bike. I think it will be a nice gearing for touring.
deepakvrao is offline
Old 07-19-16, 09:36 PM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Hello Curtis,
Sincerely,
brysfleming
Thanks for the info. Looks like they plan to release similar cranks at several price points. Seems the rise of gravel/adventure/any-road/mixed-surface/whatever-the-@*$*-you-want-t-call-it bikes is starting to produce benefits for a variety of riders.
Old 07-19-16, 09:47 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
+ 1. The 46/30 combo makes a lot of sense.
bikemig is offline
Old 07-20-16, 09:29 AM
Wheever
Bikes: 2015 Trek Domane 6 disk, 2016 Scott Big Jon Fat Bike
Quoted: 147 Post(s)
Liked 9 Times in 6 Posts
Hello Curtis,
Sincerely,
brysfleming
The only crank on FSA's website I could find with a 46/30 is the OMEGA MEGAEXO, which says it's 110 BCD. I thought the smallest ring you could get on 110 BCD was a 33? How they do that?
Wheever is offline
Old 07-20-16, 12:27 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
I run a 46/30 TA crank here:
JohnDThompson is offline
Old 07-20-16, 08:40 PM
clasher
clasher's Avatar
Quoted: 229 Post(s)
Liked 148 Times in 103 Posts
Sugino OX601D seems available from this UK seller, so minus the taxes it should be under 300USD.
clasher is offline
Old 07-20-16, 09:11 PM
Cyclist0108
Occam's Rotor
$224 at today's exchange rate.
Old 07-21-16, 06:52 AM
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
I use a triple on my trike. The bottom bracket has a 30-40-50 set up. Against all "real cyclist" rules, I use them basically up hill, level, and down hill..
rydabent is offline
Old 08-16-16, 05:36 PM
Cyclist0108
Occam's Rotor
My one remaining concern is the DI2 wire in the frame ...
Old 08-19-16, 05:35 AM
Road Fan
Road Fan's Avatar
Quoted: 1856 Post(s)
Liked 664 Times in 506 Posts
Sorry for mansplaining (ALERT! ALERT!), I'm afraid there is room for misinterpretation, but not really BluesDawg's fault. The BB specs the OP read off define a British threaded (AKA "BSC") bottom bracket. All normal British-threaded BBs (Shimano, Campy, Tange, Phil, and pre-cartridge cup/ball/spindle models) are able to fit that frame, because of those specs and because the BB shell width is always 68 mm. The shell has to have a 1.37" inner diameter at the threads AND a 24 thread per inch threading. The spec has nothing to do with the diameter of the spindle. Any BB with those thread specs should screw right in, given the thread are clean and in good condition. It also says nothing about spindle length, the length of the left end, or the length of the right end. That is what the "standard" accomplishes and what it doesn't accomplish.
A lot of the difficulty is due to the existence of different standards. "Italian" is another one, and the Swiss seemed to mix and match. That's it for the traditional standards. Other variations exist, however, for example Octolink (look it up at Sheldon's) and the different square-taper spindle end designs.
In modern days we have a lot of new standards for BB shells and BBs. I can't say I dig them all yet, nor have any preferences.
The spindle is not visible on a Shimano BB, because it's sealed inside a metal cylinder. The metal cylinder diameter is (I guess) around 24 mm, but that dimension does not affect spindle breakage or longevity. If you had a BB in your hand with a shell diameter of 30 mm and threaded sections that meet your frame's British threading requirements, it should still screw in no problem.
Spindles themselves are around 12 to 15 mm (really, I'm just guessing here). For some special new standards like recent Campagnolo and SRAM, the spindle diameter is a lot larger, but in these cases there is no over-shell. I like both of these designs.
Not sure if this is really useful, but I hope it helps. Mainly, "24" is key because it's the threading spec, not because it's the shell or spindle diameter.
Road Fan is offline
Old 08-19-16, 07:04 AM
John E
feros ferio
John E's Avatar
Quoted: 1392 Post(s)
Liked 1,324 Times in 836 Posts
I began cycling when 100 gear-inches (52/14 or 48/13) was a standard top gear, although one still saw an occasional 94 incher (49/14), and a few racing bikes had 108 (52/13). Having never found a real need for anything higher, I currently run top gears of 45/13 (UO-8 transportation beater), and 49/14, 50/14, 47/13 (three road bikes, 94 to 98 gear-inches). I run 104 gear-inches (48/13 on 26" wheels) on the mountain bike. Omitting the high gears that seem fashionable today allows one to have both desirably low bottom gears and reasonable gaps between the ratios. The proposed 46/12 should provide all the top gear you really need -- I would obviously go with 46/13 or 50/14 myself.
John E is offline
Old 08-19-16, 09:12 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Just looked it up. Square taper, many possible configurations: https://www.compasscycle.com/shop/co...-double-crank/ $435
Shipped back a trans continental race guys bike with all premium gear. including that crankset..
fietsbob is offline
Old 08-19-16, 10:28 AM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 973 Post(s)
Liked 511 Times in 351 Posts
Yeah, I agree. I ran a 13-29 10-speed Campagnolo cassette with 50/34. I would spin out the 50-13 around 32-34 mph, and by then I was coasting downhill anyway.
So I assumed that the 11-28 in 11-speed standard cassettes were "marketing".
But I do find two uses for the 50-11:
1. I can cross chain to the 34-12 (since it's not the final cog), and avoid a front chainring shift. That extends the 34 chainring's speeds up past 20 mph.
2. On really long downhills, it's nice to soft pedal in the 50-11, to keep my legs moving.
rm -rf is offline
Old 08-20-16, 04:08 AM
irwin7638
irwin7638's Avatar
Bikes: Sam, The Hunq and that Old Guy, Soma Buena Vista, Giant Talon 2, Brompton
Quoted: 102 Post(s)
Liked 106 Times in 48 Posts
I use a 46/30 with a 12/36 nine speed on my Hillborne. I think it's great. I very rarely have to resort to the small chainring, but it's nice when I do. I have a Sugino triple crank, mounted the 46T in the center position and use the outer for a chain guard. Easy peasy!
Marc
irwin7638 is offline
Old 08-21-16, 07:56 AM
dbg
Si Senior
dbg's Avatar
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times in 8 Posts
Ditto on the triple to double conversion. I love it. Have converted several shimano ultegras to 46-30, 44-28, and 42-26. I put a CF chain guard on the outside spot. Even 42-11 gives me plenty of speed for light touring.
dbg is offline
Old 08-31-16, 08:35 PM
ct-vt-trekker
Bikes: 2024 Specialized Tarmac SL8Pro, 2022 Specialized Epic Evo, 2021 Framed Alaskan Fatbike,2019 Trek Emonda SL6 Pro, 2018 Trek Stache 9.7, 2013 Specialized Roubaix SL4 Expert, 2009 Ritchey Breakaway Cross, 2016 Lynskey ProCross, 2008 Trek T1000 Tandem,
Quoted: 18 Post(s)
Liked 5 Times in 3 Posts
you can buy just the 46T chainring for your existing crankset. It's available because Shimano makes a 46/36 version of the Ultegra crankset for cyclocross bikes. This ring is expensive though! the best price I could find was over $100 for just the 46T ring. You can buy the entire 46/36 crankset for about $160.00 online. Biketiresdirect.com has the 46T ring in stock for $106.50
another option is to run a larger cassette using the roadlink.
https://www.wolftoothcomponents.com/products/roadlink
ct-vt-trekker is offline
Old 09-03-16, 02:47 PM
Cyclist0108
Occam's Rotor
RoadLink ? wolftoothcomponents.com
Yeah, but what I am after is the lower gearing with the 30T small chainring, not a smaller large chain-ring per se. (The 46T is just to keep the gap less than or equal to 16T.)
Old 09-04-16, 01:48 PM
Mr IGH
afraid of whales
Mr IGH's Avatar
Quoted: 347 Post(s)
Liked 5 Times in 5 Posts
...to keep the gap less than or equal to 16T.
That's just a recommendation, I expect it'll work fine on a 20T gap. In fact, this thread is pepping me up. The only way I can see dumping my 3x9 is a 2x11 with a 46/26 in front and 13-28 out back (I hate big steps and can't see ever using a 12-36 cassette on my road bike). And now I see how it's possible, thx! Now I gotta wear out my existing drivetrain....
Mr IGH is offline
