2017 Specialized Roubaix rusted headset cartridge bearings
I am looking to see if anyone else is having the same problem. It's a Roubaix Expert Di2, which has been in use for about a year with ~7500 miles. The bike has been back to the shop many times with some annoying problems which were for the most part resolved except for one.
I am currently riding this bike with rusty cartridge bearings where the headset can't be torqued to the factory specifications. If torqued to those levels, I get notches in steering the handlebar in the centered position and 10:30 position (on the clock) which makes steering difficult. The shop mechanic lowered to torque to a level that makes riding possible, while still feeling 'rusty'.
I am told that Specialized does not have the parts and I have been waiting for almost two months. Much has to be said against bikes with proprietary parts, but that should probably be a subject for another post!
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
My solution is just regularly replacing the bearings myself as they start to get a gritty feeling. I had to contact FSA to get a part number for each (they make the headset for my bike) and then I had to find a 3rd party bearing maker on Ebay that sold angular contact bearings that match the FSA bearing dimensions, but since I did that work it's easy for me to get new bearings fairly quickly.
You can also slather your replacement bearings in a marine grease or similar, something that will provide a bit more protection from water ingress which is usually the cause of gritty/notchy headsets.
Quoted: 1975 Post(s)
Liked 232 Times
Serious Cyclist
Bikes: Emonda SL6
Liked 261 Times
If you can't get the cartridge bearings from specialized have you tried to pull them and bring them to a industrial bearing shop or measured them yourself so you can order online? I'm not familiar with the layout of the futureshock, but you could also just try to pull the seals on the bearings and flush them out and repack with grease.
Don't see any reason why he can't just get their dimensions and order replacements from a 3rd party.
Because those older Roubaix uses proprietary 1 3/8 inch bottom bearings that are very hard to source. You cannot just get the same diameter, you also have to get the angle right. Nowadays I stay clear of any frame with proprietary seatpost or headsets. Good luck finding parts on those future-shock 1.0 headsets when they are on future-shock 5.0 few years down the road.
Likes For Chi_Z:
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
When I don't have replacement HS cartridges available, I just whip em out, run some solvent through and work em a bit, which usually removes most of the grittiness. Relube with some heavy chain oil, slather in grease, and reinstall. Because they don't go back in exactly the same orientation, the problem spots don't agree between the bearings and they don't line up with straight ahead, and the notchiness is almost always cured.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Chases Dogs for Sport
Some years back, I had an S-Works Tarmac whose headset bearings were a rusted mess after less than 30 days -- and the bike was stored indoors and never saw rain in those 30 days. I suspect they were rusty before I even took delivery of the bike. Specialized gave me so much runaround as I tried to get a warranty replacement that I gave up and bought / installed my own headset. (They wanted me to pay the dealer to install the warranty headset. The labor would have been more than the cost of a new headset.) That was my last Specialized product. Ever. (It was a nice bike, though.)
I will keep the option of cleaning and reusing these parts based on the very good suggestions from others who responded.
I made an account to chime in on the issue of headset bearings in future shock equiped bikes. I have a 18 diverge comp and was surprised at both the short life and the difficulty sourcing the bearings. My first set were shot after a few months and I had a heck of time getting replacements.
Regarding the short life, I think a combination of riding in the rain and how I washed the bike caused the first set to rust quickly. Water runs down under the top cap and there is nothing to stop it. I now hand wash the top tube and am careful to keep water away from the top cap area. My second set has lasted over a year. I just took it apart tonight and there was a little rust on the outside of the bottom bearing but with a little grease it was as good as new. Oh and I grease the bearings thoroughly during reassembly to try to keep the water out.
Regarding sourcing, I just hate getting parts from specialized. I emailed rider care with my serial number and they initially couldn't provide a part number. When pressed I got a different number for the top and bottom (they are identical). When I pressed yet again I was provided the part number. I then drove to the dealer with the part number and a photo of the bearing from my bike showing the size marking. They required I bring the bike in so they could take it apart before ordering it to "make sure we order the right part". They eventually were able to get the part.
One final thought, I carefully disassembled my old ones by following a youtube video of taking apart a sealed bearing. One is now as good as new and the other is a serviceable spare.
