The Definitive (But Wildly Inaccurate) Guide to Brake Cable Pull Ratios
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,865 Times
Background: I'm a nerd. Shimano likes to take a very narrow view of compatibility between components. Those two things combined led to this post.
It's generally well known that Shimano has been tweaking their brake cable pull over the past few generations of their road components, but the details are very hard to come by. If you search the product specifications on the Shimano website you can find out which trademarks are associated with which components. They have "SLR-EV" (DuraAce 9000/Ultegra 6800/105 5800/Tiagra 4700), "New Super SLR" (7900/6700/5700/4600) and "Super SLR" (7800/6600/5600/4500). At some point there was also plain old "SLR" but I don't know where that cutover took place. Shimano vaguely claims that each of these is incompatible with the others, though much anecdotal evidence suggestions that's not entirely true.
From various sources (mostly discussion posts on this forum and others) I've gathered that the "New Super SLR" levers pulled slightly more cable than the "Super SLR" while the "SLR EV" pulls (roughly?) the same amount of cable as the "New Super SLR" but tweaks the rate at which the pull is changed throughout the cable pull.
All of this is perhaps interesting to extreme bike nerds but mostly not very helpful without some numbers to go with it.
In another thread (https://www.bikeforums.net/bicycle-me...l#post18380942) @andr0id reported as follows:
So I took some measurements of my own....
Let me preface by saying that I am absolutely terrible at taking precise measurements. On top of that, I was using linear measurements as an estimate of lever travel that is actually an arc and picking a more or less arbitrary point on the lever at which to measure the travel (though I tried to be consistent from lever to lever). Finally, it's my understanding that the rate of cable pull actually changes throughout a full sweep and for practical reasons I measured different amounts of pull with different levers.
Nevertheless, I think the data I came up with shows a reasonable resemblance to meaningfulness.
It turns out I've got a lot of brake levers in my garage. Half of these weren't actually on bikes, so I just mounted them to a spare set of bars. For each lever I tried to measure how far the part of the lever where I'd usually be applying pressure moves, and then I measured how much cable moved during that pull (measured in various ways, depending on how the lever was mounted). Here's what I came up with:
Lever
I would guess that my margin of error on these measurements might be as much as plus or minus one millimeter, but I think you can see the trend lines. It looks to me like the cable pull ratio for long pull levers is around 0.6, the pull ratio for the old "Super SLR" levers is about 0.38 and the pull ratio for "New Super SLR" levers is about 0.42.
Prior to the introduction of "New Super SLR" everyone seemed to lump all "short pull" levers together, and so I have always kind of assumed that they all had about the same cable pull ratio. Within my generous margin of error, it looks like the SRAM levers and the short pull Gevenalle levers I measured are around the same pull as the old Shimano "Super SLR" levers, so that seems to be consistent with my expectations. The SRAM levers might actually slot in somewhere between new and old Super SLR, but my measurements weren't precise enough to say for sure.
I don't know where the 6500-series Ultegra levers fit in all of this. Just looking at them I expected them to be in the "Super SLR" camp, but my measurements didn't back that up.
I'd love to see someone who is more skilled as precision measurements than I am repeat this experiment.
EDIT: See post 18 in this thread for what I consider to be more reliable data.
I just set up my fixed gear bike with Ultegra 6800 brakes (the new SLR-EV) and the Cane Creek V brake levers.
The feel of the brakes is the same as my geared bike with the ST-6800 levers.
I measured the pull of a "full squeeze" on the following levers and found the following:
ST-6800 SLR-EV (5800, 6800, 9000) = 15.5mm
Dura Ace 7402 Brake lever (SLR) = 13mm
Can Creek V Brake lever = 16mm
I originally tried the 7402 levers but was not satisfied with the feel or pull with the 6800 brakes which led me to try the Cane Creeks.
Lever
- Lever travel (mm)
- Cable pulled (mm)
- Ratio
- MA
- 40
- 24
- 0.60
- 1.67
- 39
- 15
- 0.38
- 2.60
- 27
- 12
- 0.44
- 2.25
- 26
- 11
- 0.42
- 2.36
- 17
- 7
- 0.41
- 2.43
- 27
- 10
- 0.37
- 2.70
- 28
- 10
- 0.36
- 2.80
- 36
- 11
- 0.31
- 3.27
- 43
- 17
- 0.40
- 2.53
- 43
- 32
- 0.74
- 1.34
- 43
- 25
- 0.58
- 1.72
My Bikes
My Bikes
Last edited by Andy_K; 02-06-17 at 07:09 PM. Reason: Converted table data to list format
Likes For Andy_K:
Quoted: 1074 Post(s)
Liked 295 Times
Well done!
While accuracy is generally a good thing, I don't think you need to worry too much. Between hand strength, brake track surfaces, weather, pads, compression of casings etc etc there are so many other variables that I think you've done enough. This would be a be a good chart to indicate which combos that are good, possible and hopeless matches.
I've long suspected that brake part matching mostly isn't an either/or scenario anyways.
Back when I took a more active interest, I determined the (added) pull of a Travel Agent and compared it to the difference in pull between the Canti/Caliper levers and V-brake levers that I had available. And despite TAs being generally considered quite OK, it wasn't a close match.
Quoted: 18351 Post(s)
Liked 4,502 Times
Thanks for starting.
I've been meaning to start tracking shifter cable pull ratios. Most of it is online, but I wanted to verify the data myself. I'll try to build a rig to do it shortly.
Here is Sheldon Brown's Cable Pull Device.
Sheldon Brown's Internal Gear Hub Cable Pull Crib Sheet
One of the issues with road levers is setting up a standard mount. Less of an issue with MTB levers.
It would also be good to convert cable pull to brake caliper movement.
Quoted: 263 Post(s)
Liked 9 Times
I'm really surprised at the speed dial lever. I had assumed the dial would move it from V-brake long pull spec to cantilever short pull spec. Instead it seems to go from V-brake to some wacko extreme.
Bikes: Yes
Liked 3,865 Times
Yeah, that does seem wrong, and it's entirely possible that I mis-measured that one. It was one that I mounted on an empty bar, and having a different lever shape It didn't lend itself to consistent reference location. It may be entirely wrong. I have a short pull flat bar lever that I could add in as a sanity check for the SpeedDiall -- maybe I'll do that this weekend.
My Bikes
My Bikes
Quoted: 4195 Post(s)
Liked 3,837 Times
Thanks for this. Not so much for the actual data but more for the cause of not asking others and doing the measurements yourself. This is a lesson for others to follow. BITD John Schubert did much the same with the then available drop bar levers and calipers. Turned out the Universal levers had the least leverage. The next step is to decide what kind of performance one wants in their brakes. Max leverage/clamping pressure, the least leverage but the most solid lever feel, or something in between. Andy.
Quoted: 2026 Post(s)
Liked 1,095 Times
Your data shows the true "long pull" levers (the Gevenalle CXV0/Tektro RL520...) and the Avid Speeddials set to their V-brake setting do indeed have a lot more cable pull and lower mechanical advantage than any of the caliper brake levers. The caliper levers do vary a bit in pull and mechanical advantage but, except for a couple of outliers, are in a fairly narrow range. I can't see any of them being unusable with any of the current or former brake caliper models.
Liked 4,502 Times
The Travel Agent gives about a 2:1 Pull ratio. The straight ones may be discontinued, but the 90 degree travel agents are designed to replace the noodle with the Linear Pull brake levers, and should bring one close to what is needed.
Quoted: 1422 Post(s)
Liked 7 Times
My pull measurement is pretty accurate. I put a piece of masking tape on the TT under the cable and another piece of tape on the cable and marked the starting and finishing points.
The lever pull was less scientific. I just squeezed until it touched the bars mounted in a normal position.
The different curves of the 3 levers I have are pretty inconsistent.
I also use a travel agent on my tandem to change my 10 speed Ultegra STI ratio to work with my V brakes.
Bikes: Yes
Liked 3,865 Times
I would definitely agree with this. I think there's more variation in leverage based on where different people grab the same lever than there is is between different levers in the short pull group.
My Bikes
My Bikes
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Thank you for this. It's a good reference, even if the measurements of the lever are subjective.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Yes
Liked 3,865 Times
My Bikes
My Bikes
Perhaps a better way to measure is at the caliper. You should be able to measure the pad motion and dial in 5mm of cable adjustment using a barrel adjuster. For a given caliper you're measuring the pad displacement as function of cable pull.
Liked 7 Times
Stick a 5mm shim between the pad and rim on each side. Then remove it and see how far the tip of the brake lever moves until the pads touch.
That along with the masking tape behind the cable gets you all three measurements.
Disco Infiltrator
Liked 2,102 Times
You're measuring the ratio of the caliper but you're not learning anything about the lever. The other end of the system...
Genesis 49:16-17
Genesis 49:16-17
Liked 3,837 Times
Bikes: Yes
Liked 3,865 Times
What I'd really like is to be able to produce a graph of lever travel vs. cable pull for each different lever.
My Bikes
My Bikes
Bikes: Yes
Liked 3,865 Times
I was poking around Google, and I stumbled across this article from Park Tool:
Travel Agent? Installation and Adjustment - Park Tool
The article points to an obvious simplification of the problem: measure the distance from the pivot point to the cable anchor (more or less) and you can calculate the cable pull from that. The 5700/6700 levers complicated things a bit in the the cable rests on part of the lever behind where it is anchored, so I had to measure to the point where the cable is free to move independent of the lever body.
Anyway, after measuring the radius of the virtual circle about which the fixed cable point pivots, you can calculate the amount of cable pulled in a 20 degree swing of the lever (for instance) by the formula:
C = 2 * ∏ * r * 20 / 360
or, if you're a math geek and see that the cable pulled will actually be a chord and not an arc:
C = 2 * r * sin(20/2)
which works out to be pretty close to the same thing.
From there, the kind of cable pull versus lever travel I was trying to measure before is mostly a function of lever shape and where you squeeze it.
So, grabbing my trusty digital caliper and returning to the garage, I found the following:
(Model
1. My earlier Speed Dial measurements appear to have been way off (as was suggested previously).
2. The SRAM levers seem to be closer to the "New Super SLR" pull that to the old "Super SLR". My earlier SRAM measurements were probably bad too.
3. Despite my absolute certainty to the contrary, the R700 levers do not have the same cable pull as the 5600. This shocked me because they look identical holding them side by side. I measured both of them half a dozen times trying to find an error, but it seems to be what I've got here. Still not convinced, I dug up an old Shimano specification chart, and sure enough the R700 are listed as not "Super SLR". It's like the Michelson-Morley experiment all over again.
I also added a Shimano R550 lever (short pull, flat bar) and an old (pre-V-brake) Alivio MC11.
(Model
- Pivot radius
- 20 degree pull)
- 32.5
- 11.3
- 20
- 6.9
- 23
- 8.0
- 23
- 8.0
- 23
- 8.0
- 22
- 7.6
- 19
- 6.6
- 18
- 6.3
- 22
- 7.6
- 27
- 9.4
- 33
- 11.5
- 20.5
- 7.1
- 22
- 7.6
My Bikes
My Bikes
Last edited by Andy_K; 02-06-17 at 07:04 PM. Reason: Converted table data to list format
Quoted: 101 Post(s)
Liked 49 Times
I used one going from a Campy road lever to full-sized V brake and it worked extremely well. Don't have any actual measurements but I can take some. I'm now running Mini-Vs and don't need the cable pull change, but you can set it for 1:1 pull and it acts as a roller noodle with an adjuster. This gives a noticeably better feel than a regular noodle. I was surprised, it feels almost like a rod linkage or something, very direct.
Still stupid and seriously neglected..
It's interesting that SRAM is slightly different but still close enough for compatibility.
Bikes: Yes
Liked 3,865 Times
Measuring the arm of a V-brake or mini-V is pretty trivial. I think dual pivot caliper brakes would be a bit more complicated, but you could probably still figure out a number from a couple of measurements.
My Bikes
My Bikes
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
Why not just measure the triangle between the pivot, cable anchor, and the entrance to the housing run (I'm not sure what to call this point). You can then extrapolate the cable pull for any angle of brake lever travel.
Bikes: Yes
Liked 3,865 Times
The one big mystery in leaves in my mind is why the 2:1 ratio for the Travel Agents works as well as it does. It seems like it would be too much pull. If my numbers are even in the ballpark I would expect 3:2 to be a better ratio for Travel Agents. Yet I've used them and they worked very well.
My Bikes
My Bikes
Just measured my Campag veloce 10 spd (and these are identical to all 10sp campag levers I think) and the pivot radius is 24mm.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
My measurement system is I mount the brakes and levers I want to use and then try them.
By riding.
If they stop to my satisfaction then the measurements are good, if not, they are bad.
Haven't made any mistakes yet...
By riding.
Today, I believe my jurisdiction ends here...
